Is this psu too much power for my setup
ended up going
Amazon.com: MEAN WELL LRS-350-24 350.4W 24V 14.6 Amp Single Output Switchable Power : Electronics
About 6Amp would be enough for three motors.
Leo..
Even that seems to be a little bit oversized :wink:
its 4 motors i have a z axis or torch height control
ill run 7 amp fuse four steppers 1.7 amps per stepper 6.8 amps will leave me some headroom for upgrade later
Note that a driver set to 1.7Amp won't draw 1.7Amp from the power supply.
Leo..
It isn't that easy with stepper drivers :wink: .To calculate the needed PSU power, you cannot simply add the set amps of the driver, as @Wawa already stated. You must calculate the power the stepper needs. That's why you need the electrical characteristics of your steppers - not only the rated current.
Let's start with the stepper that Leo linked in #10 ( I'm not quite shure if it is the correct one, because the pictures differ - but anyway ...). The rated power per coil is I² * R = 1.7² * 1.2 = 3,47W ( fairly few for a NEMA 17 ... ). With 2 coils you need 7W. Double this to get headroom for losses and mechanical work. So your PSU needs to deliver 14W per motor. 4 motors = 56W. With a 24V PSU, this means >2.5A is sufficent.
But be shure to get the correct datasheet for your steppers. Usually a NEMA 17 needs about 5W per coil.
i thought they will only pull what they need
Steppers work very very differently from DC-motors. The A4988 defines the current through the coils. The motor itself 'pulls' nothing. Stepper drivers like the A4988 work very similar to a (short-circuited) buck converter. High current at the coil side, Low current from the PSU.
