ISR Timer Counter during deepSleep
hello,
i'm working on mkrfox 1200,
my code use T4 to count pulses on external pin D10.
But in deepsleep, T4 seems to be deactivated.
How can i manage to let T4 working during deepsleep or sleep
thanks...
 * https://forum.arduino.cc/t/isr-timer-capture-on-samd21/685456/11
 * Count the number of pulses on pin D10 (PA19)
 * MKRFOX 1200 pins D10 -> PA19
#include <ArduinoLowPower.h>
#define Serial Serial1
  Serial.begin(115200);                         // Initialise the native serial port
  while(!Serial); // Wait for the console to open
  Serial.println("Setup...");
  PM->APBCMASK.reg |= PM_APBCMASK_EVSYS;           // Switch on the event system peripheral
  // Generic Clock Initialisation
  GCLK->GENDIV.reg =  GCLK_GENDIV_DIV(1) |          // Select clock divisor to 1
                      GCLK_GENDIV_ID(4);            // Select GLCK4
  GCLK->GENCTRL.reg = GCLK_GENCTRL_IDC |            // Set the duty cycle to 50/50 HIGH/LOW
                      GCLK_GENCTRL_GENEN |          // Enable GCLK
                      GCLK_GENCTRL_SRC_XOSC32K |    // Select GCLK source as external 32.768kHz crystal (XOSC32K)
                      GCLK_GENCTRL_ID(4);           // Select GCLK4
  while (GCLK->STATUS.bit.SYNCBUSY);                // Wait for synchronization
  GCLK->CLKCTRL.reg = GCLK_CLKCTRL_CLKEN |          // Enable generic clock
                      GCLK_CLKCTRL_GEN_GCLK0 |      // GCLK0 at 48MHz
                      GCLK_CLKCTRL_ID_TC4_TC5;      // As a clock source for TC4 and TC5
                      GCLK_CLKCTRL_GEN_GCLK4 |      // GCLK4 at 32.768kHz
                      GCLK_CLKCTRL_ID_TCC2_TC3;     // As a clock source for TCC2 and TC3
  // TC4 Initialisation - measurement counter: counts the number incoming of pulses
  PORT->Group[PORTA].PINCFG[19].bit.PMUXEN = 1;                            // Enable the port multiplexer on port pin PA19 (D10)
  PORT->Group[PORTA].PMUX[19 >> 1].reg |= PORT_PMUX_PMUXO_A;               // Set-up PA19 (D10) as an EIC (interrupt)
  EIC->EVCTRL.reg |= EIC_EVCTRL_EXTINTEO3;                                 // Enable event output on external interrupt 3
  EIC->CONFIG[0].reg |= EIC_CONFIG_SENSE3_HIGH;                            // Set event detecting a HIGH level
  EIC->INTENCLR.reg = EIC_INTENCLR_EXTINT3;                                // Clear the interrupt flag on channel 3
  EIC->CTRL.bit.ENABLE = 1;                                                // Enable EIC peripheral
  while (EIC->STATUS.bit.SYNCBUSY);                                        // Wait for synchronization
  EVSYS->USER.reg = EVSYS_USER_CHANNEL(1) |                                // Attach the event user (receiver) to channel 0 (n + 1)
                    EVSYS_USER_USER(EVSYS_ID_USER_TC4_EVU);                // Set the event user (receiver) as timer TC4 event
  EVSYS->CHANNEL.reg = EVSYS_CHANNEL_EDGSEL_NO_EVT_OUTPUT |                // No event edge detection
                       EVSYS_CHANNEL_PATH_ASYNCHRONOUS |                   // Set event path as asynchronous
                       EVSYS_CHANNEL_EVGEN(EVSYS_ID_GEN_EIC_EXTINT_3) |    // Set event generator (sender) as external interrupt 3
                       EVSYS_CHANNEL_CHANNEL(0);                           // Attach the generator (sender) to channel 0
  TC4->COUNT32.EVCTRL.reg = TC_EVCTRL_TCEI |         // Enable TC4 event input
                            TC_EVCTRL_EVACT_COUNT;   // Increment the TC4 counter upon receiving an event
  TC4->COUNT32.CTRLA.reg = TC_CTRLA_MODE_COUNT32;    // Chain TC4 with TC5 to create a 32-bit timer
  TC4->COUNT32.CTRLA.bit.ENABLE = 1;                 // Enable TC4
  while (TC4->COUNT32.STATUS.bit.SYNCBUSY);          // Wait for synchronization
  TC4->COUNT32.READREQ.reg = TC_READREQ_RCONT |      // Enable a continuous read request
                             TC_READREQ_ADDR(0x10);   // Offset of the 32-bit COUNT register
//analogWrite(6,127);
//pinMode(7,INPUT_PULLUP);
  delay(2000);
  Serial.println("deepsleep");
  delay(1);
  TC4->COUNT32.COUNT.reg = 0;
  LowPower.deepSleep(2000);
  uint32_t count = TC4->COUNT32.COUNT.reg;// Read the COUNT register
  delay(1);
  Serial.println("wakeup");
  Serial.println(count);
