Hi there!
Been struggling on a my first Arduino project.
Basically I have a controller that is supposed to light up specific LEDs on a strip.
When I run the application, I am able to connect via blue tooth and trigger the commands to light up the LED (I was able to confirm this using the serial monitor in VS Code)
However, no matter what I do, I can't actually get the LEDs to light up.
Here is the setup of my board at the moment (excuse the exposed wiring! Been testing with multimeter when I took image)
The description of the LEDS I purchased were "25cm wire spacing 50pcs DC5V 12mm WS2811 led smart pixel node,with RGB wire(18AWG),IP68 rated;RGB addressable full color".
Here is a link to the board I purchased: https://www.digikey.ca/en/products/detail/arduino/ABX00030/10239969
Things I have done to troubleshoot so far
Ensured LEDs were getting voltage by using using multimeter at the terminal end of the LED pigtail
Added a resistor in the data line (it's not in the image)
Tried changing data pin in source code to a different one (and moving the data wire accordingly)
I have 4 strips of LEDs, I have cycled through a few strands to see if that has any impact
Tried flashing with NeoPixel strandtest (Adafruit_NeoPixel/strandtest.ino at master · adafruit/Adafruit_NeoPixel · GitHub) and moving data to pin 6 to see if that works (to be honest, I have no idea if I did this one correctly)
Code:
#include <HardwareBLESerial.h>
#include <NeoPixelBus.h>
#include <config.h>
HardwareBLESerial &bleSerial = HardwareBLESerial::getInstance();
#ifdef GRB
NeoPixelBus<NeoGrbFeature, Neo800KbpsMethod> strip(PixelCount, PixelPin);
#else
NeoPixelBus<NeoRgbFeature, Neo800KbpsMethod> strip(PixelCount, PixelPin);
#endif
RgbColor red(brightness, 0, 0);
RgbColor green(0, brightness, 0);
RgbColor blue(0, 0, brightness);
RgbColor violet(additionalledbrightness, 0, additionalledbrightness);
RgbColor black(0);
int state = 0; // Variable to store the current state of the problem string parser
String problemstring = ""; // Variable to store the current problem string
bool useadditionalled = false; // Variable to store the additional LED setting
if (!bleSerial.beginAndSetupBLE("MoonBoard A")) { // Initialize BLE UART and check if it is successful
// This should never happen as it means that the BLE setup failed and the program cannot run!
while (true) {
Serial.println("BLE setup failed!");
strip.Begin(); // Initialize LED strip
strip.Show(); // Good practice to call Show() in order to clear all LEDs
// Test LEDs by cycling through the colors red, green, blue, violet and then turning the LEDs off again
strip.SetPixelColor(0, red);
for (int i = 0; i < PixelCount; i++) {
strip.ShiftRight(1);
strip.Show();
delay(10);
strip.SetPixelColor(0, green);
strip.Show();
delay(10);
strip.SetPixelColor(0, blue);
strip.Show();
delay(10);
strip.SetPixelColor(0, violet);
strip.Show();
delay(10);
strip.ClearTo(black);
strip.Show();
// Wait for the MoonBoard App to connect
while (!bleSerial);
// Read messages from the BLE UART
bleSerial.poll();
// Check if message parts are available on the BLE UART
while (bleSerial.available() > 0) {
char c = bleSerial.read();
// State 0: wait for configuration instructions (sent only if V2 option is enabled in app) or beginning of problem string
if (state == 0) {
if (c == '~') {
state = 1; // Switch to state 1 (read configuration)
continue;
if (c == 'l') {
state = 2; // Switch to state 2 (read problem string)
continue;
// State 1: read configuration option (sent only if V2 option is enabled in app)
if (state == 1) {
if (c == 'D') {
useadditionalled = true;
continue;
if (c == 'l') {
continue;
// State 2: wait for the second part of the beginning of a new problem string (# after the lower-case L)
if (state == 2) {
if (c == '#') {
state = 3; // Switch to state 3
continue;
// State 3: store hold descriptions in problem string
if (state == 3) {
if (c == '#') { // problem string ends with #
state = 4; // Switch to state 4 (start parsing and show LEDs)
continue;
problemstring.concat(c); // add current character to problem string
// State 4: complete problem string received, start parsing
if (state == 4) {
strip.ClearTo(black); // Turn off all LEDs in LED string
Serial.println("\n---------");
Serial.print("Problem string: ");
Serial.println(problemstring);
Serial.println("");
String problemstringstore = problemstring; // store copy of problem string
if (useadditionalled) { // only render additional LEDs in first loop
Serial.println("Additional LEDs:");
while(true){
int pos = problemstring.indexOf(','); // Hold descriptions are separated by a comma (,)
String hold;
if (pos > 0) { // Still holds left in the problem string
hold = problemstring.substring(0, pos); // Extract one hold description
else { // Last hold in the problem string
hold = problemstring;
char holdtype = hold.charAt(0); // Hold descriptions consist of a hold type (S, P, E) ...
int holdnumber = hold.substring(1).toInt(); // ... and a hold number
int lednumber = ledmapping[holdnumber];
int additionallednumber = lednumber + additionalledmapping[holdnumber];
if (additionalledmapping[holdnumber] != 0) {
Serial.print(holdtype);
Serial.print(holdnumber);
Serial.print(" --> ");
Serial.print(additionallednumber);
if (holdtype == 'S') { // Start hold
strip.SetPixelColor(additionallednumber, violet);
Serial.println(" (violet)");
if (holdtype == 'P') { // Progress hold
// Finish holds don't get an additional LED!
if (pos == -1) { // Last hold has been processed!
Serial.println("");
problemstring = problemstring.substring(pos+1, problemstring.length()); // Remove processed hold from string
problemstring = problemstringstore; // Restore problem string for rendering normal hold LEDs
Serial.println("Problem LEDs:");
while(true){ // render all normal LEDs (possibly overriding additional LEDs)
String hold;
Serial.print(lednumber);
strip.SetPixelColor(lednumber, green);
Serial.println(" (green)");
strip.SetPixelColor(lednumber, blue);
Serial.println(" (blue)");
if (holdtype == 'E') { // End hold
strip.SetPixelColor(lednumber, red);
Serial.println(" (red)");
strip.Show(); // Light up all hold (and additional) LEDs
problemstring = ""; // Reset problem string
useadditionalled = false; // Reset additional LED option
state = 0; // Switch to state 0 (wait for new problem string or configuration)
Serial.println("---------\n");
I'm running out of ideas. haha. Hoping I am just overlooking something here.
