Issue using the ArduinoMqttClient.h library
Hello guys, I'm curretnly trying to write data from an Arduino Uno WiFi Rev2 to MQTT. The problem is that my broker requires an username and password to connect to it. I'm using the ArduinoMqttClient.h library and can't find how to configurate an username.
GitHub - arduino-libraries/ArduinoMqttClient: ArduinoMqttClient Library for Arduino
My program :
#include <ArduinoMqttClient.h>
#include <WiFiNINA.h>
//#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
const char ssid[] = "xx"; // your network SSID (name)
const char pass[] = "xx"; // your network password (use for WPA, or use as key for WEP)
WiFiClient wifiClient;
MqttClient mqttClient(wifiClient);
const char broker[] = "xx";
int port = 1883;
const char topic[] = "xx";
const char topic2[] = "xx";
const char topic3[] = "xx";
//set interval for sending messages (milliseconds)
const long interval = 8000;
unsigned long previousMillis = 0;
int count = 0;
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// attempt to connect to Wifi network:
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
while (WiFi.begin(ssid, pass) != WL_CONNECTED) {
// failed, retry
Serial.print(".");
delay(5000);
Serial.println("You're connected to the network");
Serial.print("Attempting to connect to the MQTT broker: ");
Serial.println(broker);
if (!mqttClient.connect(broker, port)) {
Serial.print("MQTT connection failed! Error code = ");
Serial.println(mqttClient.connectError());
while (1);
Serial.println("You're connected to the MQTT broker!");
// call poll() regularly to allow the library to send MQTT keep alive which
// avoids being disconnected by the broker
mqttClient.poll();
if (currentMillis - previousMillis >= interval) {
// save the last time a message was sent
//record random value from A0, A1 and A2
int Rvalue = analogRead(A0);
int Rvalue2 = analogRead(A1);
int Rvalue3 = analogRead(A2);
Serial.print("Sending message to topic: ");
Serial.println(topic);
Serial.println(Rvalue);
Serial.println(topic2);
Serial.println(Rvalue2);
Serial.println(Rvalue3);
// send message, the Print interface can be used to set the message contents
mqttClient.beginMessage(topic);
mqttClient.print(Rvalue);
mqttClient.endMessage();
mqttClient.beginMessage(topic2);
mqttClient.print(Rvalue2);
mqttClient.beginMessage(topic3);
mqttClient.print(Rvalue3);
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Have you looked at the examples that come with the library ?
  // You can provide a username and password for authentication
  // mqttClient.setUsernamePassword("username", "password");
