I have a setup of 2 x (Lora modules RFM95 + ESP32) that exchange messages between each other. The issue is that the max range I can get is around 100m. I suspect the antenna being wrongly used. The attached picture shows how I connected the RFM95 antenna to the PCB.
I used the antenna connector shown in this picture:
How how you oriented the antennas? Monopole antennas radiate perpendicularly, with almost zero power coming out of the ends. So definitely don’t point them at each other - they need to be more like parallel to work.
Did you design the PCB, it would have been better if you positioned the RFM closer to the antenna socket.
What frequency is your RFM unit?
Are you using the correct aerial?
Have you checked out the hoperf site for info on antennas and applications?
Hi Tom,
Thank you for the document. I will try to read it during this weekend. The RFM unit's frequency is 868MHz. I am using an antenna described by aliexpress as: 868MHz SMA Connector Antenna for Lora Board IOT Lora32u4 II Wifi Lora32 Lora Module RCmall
#include <SPI.h>
#include <LoRa.h>
//define the pins used by the transceiver module
#define ss 5
#define rst 14
#define dio0 2
int counter = 0;
//initialize Serial Monitor
while (!Serial);
Serial.println("LoRa Sender");
//setup LoRa transceiver module
LoRa.setPins(ss, rst, dio0);
//replace the LoRa.begin(---E-) argument with your location's frequency
//433E6 for Asia
//866E6 for Europe
//915E6 for North America
while (!LoRa.begin(866E6)) {
Serial.println(".");
// Change sync word (0xF3) to match the receiver
// The sync word assures you don't get LoRa messages from other LoRa transceivers
// ranges from 0-0xFF
LoRa.setSyncWord(0xF3);
Serial.println("LoRa Initializing OK!");
Serial.print("Sending packet: ");
Serial.println(counter);
//Send LoRa packet to receiver
LoRa.beginPacket();
LoRa.print("hello ");
LoRa.print(counter);
LoRa.endPacket();
counter++;
delay(10000);
While answering you question, I could notice that in the sketch I have 866E6 as frequency and my RFM module uses 868MHz. Maybe I should change the line: while (!LoRa.begin(866E6)) {
to while (!LoRa.begin(868E6)) {
One cause of extreme short range with LoRa modules, is that the transmitter module is damaged because it was operated, even for a short time, with no or a faulty antenna. Such damadged modules may not work very well as transmitters but are often OK for receivers.
Yes I added the change. The communication between the 2 Lora transceivers is fine.
I will try to bring the antenna plug as near as possible to the antenna pin (ANT) of the RFM module and test.
The design of the PCB track which carries the signal from the rfm95 to the antenna connector can also be important. If not done correctly, there will be an impedance mismatch which will reduce the range. The impedance of the PCB track should be 50 ohm to match your antenna. As mentioned already, shorter is better. But you also have to use the correct track width to get as close as you can to 50 ohm, and that depends on the copper track thickness, the PCB thickness, the dielectric constant of the PCB material, whether you have a ground plane on the other side of the PCB... There are calculators on-line to help you. Search for "microstrip calculator".
It can sometimes be useful to know what settings have been applied to a LoRa device as this can have a very significant impact on range.
There is a library that will print out the current settings of a LoRa device like this;
Lora Device found
SX1278_PABOOST,434000000hz,SF7,BW125000,CR4:5,LDRO_Off,SyncWord_0x12,IQNormal,Preamble_8
SX1278_PABOOST,SLEEP,Version_12,PacketMode_LoRa,Explicit,CRC_On,AGCauto_On,LNAgain_1
In the top arrangement the signal from each antenna will be received by the other one, but in the bottom one it is unlikely you will get any signal other than when the antennas are very close together.
