Issues Uploading Code to ATTiny 84 with Sparkfun AVR Pocket Programmer
Hello everyone,
I am getting back into programming with Arduino and built a POV fidget spinner inspired by an instructable by MakersBox. I am using the SparkFun AVR Pocket Programmer and an ATTiny84 (8MHz internal clock) with ATTinyCore as the board manager.
I attempted to upload the code to my board today. I am connecting to the board via a pogo pin adapter. I have the 'USBTinyISP (ATTinyCore) FAST, for parts running >= 2MHz' programmer selected as this SparkFun tutorial instructed to select the USBTinyISP programmer. If I hook my board up, I am able to load the bootloader and get the done loading message, but it is far too fast. My board does not show as connected nor as having a bootloader installed and as soon as I try and upload code, the IDE just states "Upload error: A programmer is required to upload" (See below for full error).
Sketch uses 6612 bytes (80%) of program storage space. Maximum is 8192 bytes.
Global variables use 232 bytes (45%) of dynamic memory, leaving 280 bytes for local variables. Maximum is 512 bytes.
I even switched the pogo ISP connector backwards to see what would happen (may have been a dumb idea). The same error message was shown.
Does anyone know what is going on?
Sure, you have to select "Upload using programmer" instead of "Upload" if you want to use the programmer. For such board you usually don't install a bootloader and always use the programmer to install a new sketch.
I am pretty sure I did that but will try again tonight and see if it works. Thank you!
I got it to work. Thank you! Why is it that we do not normally use a bootloader with the ATTiny 84? What is the difference between Optiboot, Micronucleus, and California STEAM in theATTinyCore board manager package?
Thanks again!
These are different bootloaders.
Because the bootloader uses quite some flash space so most users consider that unnecessary. If you don't need to upload bigger sketches and want the convenience of an upload possibility by an UART connection (and you don't use those pins for other stuff), you're free to use a bootloader.
Another limitation originating from the bootloader is the higher delay after power up and/or reset until the normal code executes (because the bootloader waits for new code to arrive).
That makes sense.
On a related note, my board randomly stopped working completely and now will not accept code. I replaced the ATTiny 84 with a new chip but am still getting the same error while uploading.
Sketch uses 6610 bytes (80%) of program storage space. Maximum is 8192 bytes.
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
Failed programming: uploading error: exit status 1
Do you have any idea what is causing this? I am choosing 'Upload Using Programmer'.
Thank you!
Franklin
Also, if you hook the ISP connections up backwards, does it fry the chip?
Lastly, when soldering the ATTiny84 into a PCB, what temp is fair to use on your soldering iron? Is 400 degrees F too high?
Hello all,
As an update, I tried to upload again today to no avail. I installed another new chip and the same happened. If anyone has any idea as to what is going on, I would really appreciate some help. The error and code are below. Thank you!
Error:
         this check.
Code:
cd C:\Users\MakersBox\Downloads\arduino-1.6.4\hardware\tools\avr\bin
avrdude -C ..\etc\avrdude.conf -P COM8 -b 19200 -c avrisp -p attiny84 -v -e -U lfuse:w:0xE2:m -U hfuse:w:0xD7:m -U efuse:w:0xFf:m  -U flash:w:SMD_spinner_THT_R2b.cpp.hex
Attiny Core:
https://github.com/SpenceKonde/ATTinyCore
Board: Attiny 24/44/84
Pin Mapping: Counter-Clockwise
Chip: Attiny 84
Clock: 8 MHz (internal)
// ATMEL ATTINY84 / ARDUINO
//                     VCC  1|    |14  GND
//             (D  0)  PB0  2|    |13  AREF (D 10)
//             (D  1)  PB1  3|    |12  PA1  (D  9)
//                     PB3  4|    |11  PA2  (D  8)
//  PWM  INT0  (D  2)  PB2  5|    |10  PA3  (D  7)
//  PWM        (D  3)  PA7  6|    |9   PA4  (D  6)
//  PWM        (D  4)  PA6  7|    |8   PA5  (D  5)        PWM
#include <EEPROMex.h>
#include <avr/pgmspace.h>
#include <avr/sleep.h>
#include "font.h"
#include "textAndShapes.h"
// clear and set interup routines
#ifndef cbi
  #define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#endif
#ifndef sbi
  #define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#endif
unsigned long debounceDelay = 50;
const int charHeight = 8;
const int charWidth = 5;
int rows= 8;		                 // Total LED's in a row
bool STATES[] = {LOW, LOW, LOW, LOW, LOW, LOW, LOW, LOW};
int LEDS[] = {10, 9, 8, 7, 6, 5, 4, 3};  // Port A
byte magPin = 2;                 // Hall effect sensor, pulled-up, goes low when magnet passes
byte buttonPin = 0;
char charArray[6];                       // holds characters to display
unsigned long lastTimeUs;                // time (us) magnet sensed
unsigned long revTimeUs;                 // time (us) of last full rotation
unsigned long dwellTimeUs;               // time (us) between LED changes (based on rotation speed)
volatile unsigned long revolutions = 0;  // track number of revolutions since last start
long totalRevolutions;                   // track total number of revolutions (stored in EEPROM)
bool spinning = true;                    // track reset of time & counts
unsigned long startTimeUs;               // time (us) current spinning started
int mode;                                // current operating mode, stored in EEPROM
int modes = 8;                           // number of modes available
  // 0 -> text "Hello World!"
  // 1 -> RPM
  // 2 -> time in seconds
  // 3 -> spin count
  // 4 -> spin count (total)
  // 5 -> "lilly pad" pattern
  // 6 -> shape 1 (heart)
  // 7 -> shape 2 (smile)
volatile boolean rotationFlag = false;  // modified by ISR
void setup(){
  // setup inputs
  pinMode(buttonPin, INPUT_PULLUP);
  //digitalWrite(buttonPin, HIGH);
  pinMode(magPin, INPUT_PULLUP);
  //digitalWrite(magPin, HIGH);
  // setup other LEDs
  for(int LED=0; LED<(sizeof(LEDS)/sizeof(int)); LED++){
    pinMode(LEDS[LED], OUTPUT);
    digitalWrite(LEDS[LED], STATES[LED]);
  // Interupt setting
  GIMSK  = bit (PCIE1);   // Pin change interrupt enable
  PCMSK1 = bit (PCINT10); // Enable interupt on PCINT10 (D2)
  sei();                  // enables interrupts
  // get saved mode from eeprom
  mode = EEPROM.read(0);
  if (mode >= modes) {
    mode = 0; // may be very large first time
  // get saved revolution total from eeprom
  totalRevolutions = EEPROMReadlong(1);
  if (totalRevolutions < 0 || totalRevolutions > 999999UL){ // will be -1 first time.
    totalRevolutions = 0;
    EEPROMWritelong(1, 0);
  // show we are alive and what mode is active
  blipLEDs();
  lastTimeUs = micros();
void loop(){
  int sigFigs = 5;               // number of significant figures to display
  unsigned long curTimeUs;
  int seconds;
  unsigned int rpm;
  checkButton();
  if ((micros() - lastTimeUs) > 20000000UL){  // sleep after 20 seconds - time variables measured in microseconds
    digitalWrite(LEDS[0], HIGH);
    ledsOff();
    system_sleep();
  if (((micros() - lastTimeUs) > 2000000UL)){ // less than 1 rev / sec
    if (spinning){
      spinning = false;
      totalRevolutions = totalRevolutions + revolutions;
      EEPROMWritelong(1, totalRevolutions);
      revolutions = 0;
      clearArray();
      blipLEDs();
      digitalWrite(LEDS[mode], LOW);
      //system_sleep();
    else {
      //digitalWrite(LEDS[mode], LOW);
  if (mode == 5){  // lilly pad pattern, show regardles of magnet.
       digitalWrite(LEDS[LED], HIGH);
       delay(1);
       digitalWrite(LEDS[LED], LOW);
    for(int LED=(sizeof(LEDS)/sizeof(int))-1; LED >= 0; LED--){
       delay(1);
  else if (rotationFlag){ // we are spinning!
    if (!spinning){
      spinning = true;
      startTimeUs = micros();
    curTimeUs = micros();
    revTimeUs = curTimeUs - lastTimeUs;
    dwellTimeUs = revTimeUs * 3UL / 360UL;   // 3 degrees
    seconds = (curTimeUs - startTimeUs) / 1000000UL;
    rpm = 60000 * 1000 / revTimeUs;
    lastTimeUs = curTimeUs;
    clearArray();
    if (mode == 0){
      strcpy (charArray, text);
      //sprintf(charArray, "%lu", dwellTimeUs);
    else if (mode == 1){
      sprintf(charArray, "%d", rpm);
      sigFigs = 3;
    else if (mode == 2){
      sprintf(charArray, " %d", seconds);
    else if (mode == 3){
      sprintf(charArray, " %lu", revolutions);
    else if (mode == 4){
      sprintf(charArray, "%lu", totalRevolutions + revolutions);
    else if (mode == 6 || mode ==7){ // shapes 1 or 2
      dwellTimeUs = revTimeUs * 5UL / 360UL;   // 5 degrees
      for(int k=0; k< sizeof(shape_1);k++){
        if (rotationFlag){
        int i = k + 26; // advancing because of magnet location
        if(i >= sizeof(shape_1)){
          i = i - sizeof(shape_1);
        char b;
        if (mode == 6){
          b = pgm_read_byte_near(&(shape_1[i]));
        else{
          b = pgm_read_byte_near(&(shape_2[i]));
        //for (int j=0; j<charHeight; j++) {
        //  digitalWrite(LEDS[j], bitRead(b, j));
        PORTA = b;
        delayMicroseconds(dwellTimeUs);
    // Text in top half
    if (mode < 5) {
      int digits = 0;
      for(int k=0; k< sizeof(charArray); k++){
        char c = charArray[k];
        if (rotationFlag){
        if(c){
          if(mode==0){
            printLetter(c);
          else{
            if (digits < sigFigs){
              printLetter(c);
              //digits += 1;
            else{
              printLetter('0');
            digits += 1;
      // Handle display in lower section
      clearArray();
      if(1 && (revTimeUs < 200000)){
        char * ptr = (char *) pgm_read_word (&string_table[mode]);
        //char buffer [6]; // must be large enough!
        strcpy_P (charArray, ptr);
        // wait for it . . .
        while((micros() < (lastTimeUs + revTimeUs / 2 - 5 * dwellTimeUs)) && !rotationFlag){};
        // show it
        for (int k=sizeof(charArray)-1; k>=0; k--){
          if (rotationFlag){
          printLetterLower(charArray[k]);;
ISR(PCINT1_vect){  // Magnet sensed
  if (!digitalRead(magPin)){
    rotationFlag = true;             // Increment volatile variables
    revolutions += 1;
void ledsOff(){
void dwellDelay(){ // avoid glitch on first rotation having erronious value
  if (dwellTimeUs > 2000){
    dwellTimeUs = 2000;
  if (dwellTimeUs < 100){
    dwellTimeUs = 100;
void printLetter(char ch){
// https://github.com/reger-men/Arduion-POV-clock/blob/master/clock.ino
  // make sure the character is within the alphabet bounds (defined by the font.h file)
  // if it's not, make it a blank character
  if (ch < 32 || ch > 126){
    ch = 32;
  // subtract the space character (converts the ASCII number to the font index number)
  ch -= 32;
  // step through each byte of the character array
  for (int i=0; i<charWidth; i++) {
    char b = pgm_read_byte_near(&(font1[ch][i]));
    //  digitalWrite(LEDS[j], bitRead(b, 7-j));
    PORTA = b;
    dwellDelay();
  //clear the LEDs
  PORTA = 0;
  //for (int i = 0; i < rows; i++){
  //  digitalWrite(LEDS[i] , LOW);
  dwellDelay();
  dwellDelay();
void printLetterLower(char ch){
    ch = 32;
  ch -= 32;
  for (int i=charWidth-1; i>-1; i--) {
    char b = pgm_read_byte_near(&(font[ch][i]))<<1;
    PORTA = b;
    //  digitalWrite(LEDS[j+1], bitRead(b, j));
    dwellDelay();
  //clear the LEDs
  for (int i=0; i<rows; i++){
    digitalWrite(LEDS[i], LOW);
  //PORTA = 0;
  // space between letters
  dwellDelay();
  dwellDelay();
bool touched(){
  // returns true if touched, false if not.  Light LED until touch released
  bool touchVal = digitalRead(buttonPin);
  if (!touchVal){
    while(!digitalRead(buttonPin)){ // wait till touch release
      delay(debounceDelay);
    //digitalWrite(LEDS[0], LOW);
    return (true);
  else{
    return (false);
void checkButton(){
  // check button for mode change and display current mode
  if (touched()){
    mode += 1;
    if (mode >= modes){
      mode = 0;
    EEPROM.write(0, mode);
    blipLEDs();
void blipLEDs(){
  // something to show we are alive
    delay(10);
  for(int LED=sizeof(LEDS)/sizeof(int); LED>mode; LED--){
    delay(10);
  digitalWrite(LEDS[mode], HIGH);
void EEPROMWritelong(int address, long value)  {
  //This function will write a 4 byte (32bit) long to the eeprom at
  //the specified address to address + 3.
  //https://playground.arduino.cc/Code/EEPROMReadWriteLong
  //Decomposition from a long to 4 bytes by using bitshift.
  //One = Most significant -> Four = Least significant byte
  // OxFF is the hexadecimal value equal to 00000000 00000000 00000000 11111111
  byte four = (value & 0xFF); // AND bitwise operator combines two binary values such that only two 1s equal a 1. This is taking only the last byte of the 32 bit long (4 bytes)
  byte three = ((value >> 8) & 0xFF);
  byte two = ((value >> 16) & 0xFF);
  byte one = ((value >> 24) & 0xFF);
  //Write the 4 bytes into the eeprom memory.
  EEPROM.write(address, four);
  EEPROM.write(address + 1, three);
  EEPROM.write(address + 2, two);
  EEPROM.write(address + 3, one);
long EEPROMReadlong(long address){
  //Read the 4 bytes from the eeprom memory.
  long four = EEPROM.read(address);
  long three = EEPROM.read(address + 1);
  long two = EEPROM.read(address + 2);
  long one = EEPROM.read(address + 3);
  //Return the recomposed long by using bitshift.
  return ((four << 0) & 0xFF) + ((three << 8) & 0xFFFF) + ((two << 16) & 0xFFFFFF) + ((one << 24) & 0xFFFFFFFF);
void clearArray(){
  for(int i=0; i<sizeof(charArray); i++){      // clear array
    charArray[i] = 0;
// set system into the sleep state
// system wakes up when watchdog is timed out
void system_sleep() {
  cbi(ADCSRA,ADEN);                    // switch Analog to Digitalconverter OFF
  set_sleep_mode(SLEEP_MODE_PWR_DOWN); // sleep mode is set here
  sleep_enable();
  sleep_mode();                        // System sleeps here
  sleep_disable();                     // System continues execution here when watchdog timed out
  sbi(ADCSRA,ADEN);                    // switch Analog to Digitalconverter ON
Most probably a problem in the connection or wrong fuse selection. The fuse selection must match your hardware, otherwise your chip is gone (at least if you don't have a high voltage parallel programmer available).
It might. I never tried myself but the datasheet would allow that interpretation.
That depends on your soldering skills.
Okay. I have tried 7 chips now so I do not think that is the issue. It did work for a while but ever since I have not yet been able to get code to upload. Kind of at a loss here but will keep trying.
I am using the "USBtinyISP (ATtinyCore) FAST, for parts running >= 2MHz" ATTinyCore programmer option. If helpful, the verbose upload output is below:
avrdude: Version 6.3-20201216
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\Franklin Marquette\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2/avrdude.conf"
         Using Port                    : usb
         Using Programmer              : usbtiny
         Setting bit clk period        : 0.3
avrdude: usbdev_open(): Found USBtinyISP, bus:device: bus-0:\\.\libusb0-0001--0x1781-0x0c9f
         AVR Part                      : ATtiny84
         Chip Erase delay              : 15000 us
         PAGEL                         : P00
         BS2                           : P00
         RESET disposition             : possible i/o
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65     6     4    0 no        512    4      0  4000  4500 0xff 0xff
           flash         65     6    32    0 yes      8192   64    128  4500  4500 0xff 0xff
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
         Programmer Type : USBtiny
         Description     : USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
avrdude: programmer operation not supported
avrdude: Setting SCK period to 1 usec
         this check.
avrdude done.  Thank you.
I was able to get it to upload using the "USBtinyISP (ATtinyCore) SLOW, for new or 1 MHz parts" programmer option in the ATTinyCore. This does not show an error but the board does not work at all. The LEDs are half on, half off and not doing what they are supposed to. The code and board worked before using the "USBtinyISP (ATtinyCore) FAST, for parts running >= 2MHz" programmer option in USBTinyCore. I truly do not know what is going on and would appreciate anyone's input or assistance.
Thank you,
Franklin
Below is the verbose output from the upload using USBtinyISP (ATtinyCore) SLOW, for new or 1 MHz parts".
         Using Port                    : usb
         Setting bit clk period        : 8.0
         AVR Part                      : ATtiny84
         PAGEL                         : P00
         BS2                           : P00
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
avrdude: Setting SCK period to 8 usec
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e930c (probably t84)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "C:\Users\Franklin Marquette\AppData\Local\Temp\arduino-sketch-4EAF56BB7511F62510449A44864EEF99/SMD_spinner.ino.hex"
avrdude: writing flash (6440 bytes):
Writing | ################################################## | 100% 15.64s
avrdude: 6440 bytes of flash written
avrdude: verifying flash memory against C:\Users\Franklin Marquette\AppData\Local\Temp\arduino-sketch-4EAF56BB7511F62510449A44864EEF99/SMD_spinner.ino.hex:
avrdude: load data flash data from input file C:\Users\Franklin Marquette\AppData\Local\Temp\arduino-sketch-4EAF56BB7511F62510449A44864EEF99/SMD_spinner.ino.hex:
avrdude: input file C:\Users\Franklin Marquette\AppData\Local\Temp\arduino-sketch-4EAF56BB7511F62510449A44864EEF99/SMD_spinner.ino.hex contains 6440 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 24.64s
avrdude: verifying ...
avrdude: 6440 bytes of flash verified
You can use that option only if you already uploaded a bootloader to that chip. Have tried the slower option? Does that work?
if that doesn't work enable verbose output during upload in the preferences and post the output you get.
