Issues uploading to ATtiny 85
I'm attempting to upload a sketch to an ATtiny85. Using a known good programmer that has been used before on this batch of chips. Have attempted to load to several chips and have gotten same error each time. I got a lot of information that I don't understand and googling it made the confusion worse. Could one of you fine people interpret this for me please.
The error code message:`
Arduino: 1.8.19 (Windows 10), Board: "ATtiny25/45/85, ATtiny25, Internal 1 MHz"
Sketch uses 1390 bytes (67%) of program storage space. Maximum is 2048 bytes.
Global variables use 13 bytes (10%) of dynamic memory, leaving 115 bytes for local variables. Maximum is 128 bytes.
C:\Users\machine\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\machine\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -pattiny25 -cstk500v1 -PCOM10 -b19200 -Uflash:w:C:\Users\machine\AppData\Local\Temp\arduino_build_835427/module1_ATtiny85_v5.2.ino.hex:i
avrdude: Version 6.3-20190619
     Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Users\machine\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
     Using Port                    : COM10
     Using Programmer              : stk500v1
     Overriding Baud Rate          : 19200
     AVR Part                      : ATtiny25
     Chip Erase delay              : 4500 us
     PAGEL                         : P00
     BS2                           : P00
     RESET disposition             : possible i/o
     RETRY pulse                   : SCK
     serial program mode           : yes
     parallel program mode         : yes
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       eeprom        65     6     4    0 no        128    4      0  4000  4500 0xff 0xff
       flash         65     6    32    0 yes      2048   32     64  4500  4500 0xff 0xff
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
       lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
       lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
       hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
       efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
     Programmer Type : STK500
     Description     : Atmel STK500 Version 1.x firmware
     Hardware Version: 2
     Firmware Version: 1.18
     Topcard         : Unknown
     Vtarget         : 0.0 V
     Varef           : 0.0 V
     Oscillator      : Off
     SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
An error occurred while uploading the sketch
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e930b (probably t85)
avrdude: Expected signature for ATtiny25 is 1E 91 08
     Double check chip, or use -F to override this check.
avrdude done. Thank you.
option enabled in File -> Preferences.
You'll see it in a moment.
Seriously. Read the error messages. They'll almost always tell you what you are doing wrong.
Well I was expecting a long involved troubleshoot but merely setting the IDE to program the right chip does make a difference. Note to self check the simple stuff first before dragging out the tool box and tearing it apart. Thanks for the assist. machinetech
And you gave yourself the solution? Feel free to figure out your next problem by yourself.
