Issues with Alexa Connecting to Arduino
I am trying to connect my alexa to an arduino to control an EV charger with relays. I am trying to setup my arduino code so i can send a command to my alexa saying "Power my home with my EV." I believe i setup everything correctly but I cannot get the alexa app to find my arduino. Can you help me? Code Pasted Below.
My Code:
#include "thingProperties.h"
// Pin connected to the relay
const int relayPin = 7;
// Timing variables
unsigned long lastManualInteraction = 0;
const unsigned long manualOverrideTimeout = 2 * 60 * 60 * 1000; // 2 hours in milliseconds
  // Initialize serial and wait for port to open:
  delay(1500);
  // Initialize the relay pin
  pinMode(relayPin, OUTPUT);
  // Set the relay to the correct state according to the schedule at startup
  updateRelayState();
  // Defined in thingProperties.h
  initProperties();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  ArduinoCloud.update();
  // Automatically resume schedule after 2 hours of no manual interaction
  if (millis() - lastManualInteraction > manualOverrideTimeout) {
    updateRelayState();
void updateRelayState() {
  // Get the current local time in seconds since the Unix epoch
  unsigned long currentTime = ArduinoCloud.getLocalTime();
  // Convert seconds to a tm structure
  time_t rawTime = currentTime;
  struct tm *timeInfo = localtime(&rawTime);
  int currentHour = timeInfo->tm_hour;
  if (currentHour >= 7 && currentHour < 21) {
    // Between 7 AM and 9 PM, the vehicle should be discharging (relay off)
    digitalWrite(relayPin, LOW);
    Serial.println("Vehicle is discharging, home is being powered by the EV.");
    // All other times, the vehicle should be charging (relay on)
    digitalWrite(relayPin, HIGH);
    Serial.println("Vehicle is charging.");
// Function called when ChargerFunction changes from the IoT Cloud dashboard or Alexa
void onChargerFunctionChange() {
  if (chargerFunction) {
    Serial.println("Charger turned on manually via dashboard or Alexa.");
    Serial.println("Charger turned off manually via dashboard or Alexa.");
  // Record the time of manual interaction
  lastManualInteraction = millis();
// Function called when the Alexa CloudSwitch changes
void onPowermyhomewithmyevChange() {
  if (powermyhomewithmyev) {
    digitalWrite(relayPin, LOW); // Turn off the relay to power the home with EV
    Serial.println("Alexa command: Powering home with EV.");
    digitalWrite(relayPin, HIGH); // Turn on the relay to start charging the EV
    Serial.println("Alexa command: Charging EV.");
Here are the thing properties:
// Code generated by Arduino IoT Cloud, DO NOT EDIT.
#include <ArduinoIoTCloud.h>
#include <Arduino_ConnectionHandler.h>
const char SSID[]     = SECRET_SSID;    // Network SSID (name)
const char PASS[]     = SECRET_OPTIONAL_PASS;    // Network password (use for WPA, or use as key for WEP)
void onPowermyhomewithmyevChange();
void onChargerFunctionChange();
CloudSwitch powermyhomewithmyev;
bool chargerFunction;
void initProperties(){
  ArduinoCloud.addProperty(powermyhomewithmyev, READWRITE, ON_CHANGE, onPowermyhomewithmyevChange);
  ArduinoCloud.addProperty(chargerFunction, READWRITE, ON_CHANGE, onChargerFunctionChange);
WiFiConnectionHandler ArduinoIoTPreferredConnection(SSID, PASS);
