Issues with I2C Communication on Waveshare RP2040-Zero
Hi everyone,
I'm working with a Waveshare RP2040-Zero module and attempting to establish I2C communication with an RTC module. Despite my efforts, I'm encountering issues with the I2C setup.
Specifically, I manually designated the SDA and SCL pins using Wire.setSDA(6) and Wire.setSCL(7). Following this, the USB port became unresponsive, leading to the module itself not responding. To resolve this, I had to reflash the original .uf2 file from the CircuitPython website, which revived the device.
Could anyone offer insights or guidance on establishing a successful I2C communication with the RTC module under these circumstances?
Thanks in advance for your help!
Behic.
Can you buy a Raspberry Pi Pico that everyone uses and make your project with that board ?
Which board have you installed ?
If you followed the tutorial by Waveshare, then you have installed the "earlephilhower" board.Do you use Arduino C++ or MicroPython or CircuitPython ?
Does Waveshare give the schematic for that board ?
Where are the specific settings for this board ? For example to find the default SDA and SCL pin.
Hi I am using Arduino IDE 1.8.19 and I downloaded the board core to Arduino IDE and I selected Waveshare RP2040-Zero.
Also I figured out the problem. If you use Wire the module uses the pin 4 and 5. If you use Wire1 then module uses pin 26,27. There is no need to use setSDA() and setSCL() functions So my problem is over.
Thank you for your effort
