Issues with ILI9341
Hello all, I'm very new to the electronic scene and processors and wanted to have a small feature for a project I'm working on. Unfortunately I'm working with many different tutorials on basic set up but none of them have exactly what I need.
I'm working with an ESP32-S3 and a 3.2 in ILI9341 LCD. I went into the user setup files in the TFT_espi library to recode the pins and undefine some conditions I didn't need but I can't tell if my issue is hardware or software or user error.
Using the IDE software I'm able to use the correct Dev module and upload an example onto the board (light blinks blue). However, after the upload is complete my LCD (currently only white screen) doesn't change in display.
Any help would be appreciated, I have no idea what I'm doing but would love to learn.
Welcome to the forum
Please post your full sketch, using code tags when you do
Posting your code using code tags prevents parts of it being interpreted as HTML coding and makes it easier to copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
It is also helpful to post error messages in code tags as it makes it easier to scroll through them and copy them for examination
You need to post code and schematics.
The sticky post "How to get the best out of this forum" tells You how to do it.
whivh version of the ESP32 core are you using?
when using TFT_eSPI the ESP32S3 goes into a reset loop when built with newer versions of the ESP32 core
the last working version was ESP32 core 2.0.14
  Example for TFT_eSPI library
  Created by Bodmer 11/03/17
  Make sure LOAD_GFXFF is defined in the used User_Setup file
  within the library folder.
  --------------------------- NOTE ----------------------------------------
  The free font encoding format does not lend itself easily to plotting
  the background without flicker. For values that changes on screen it is
  better to use Fonts 1- 8 which are encoded specifically for rapid
  drawing with background.
  ###### DON'T FORGET TO UPDATE THE User_Setup.h FILE IN THE LIBRARY ######
  ######   TO SELECT YOUR DISPLAY TYPE, PINS USED AND ENABLE FONTS   ######
// Note the the tilde symbol ~ does not exist in some fonts at the moment
#define TEXT "abc MWy 123 |" // Text that will be printed on screen in any font
#include "SPI.h"
#include "TFT_eSPI.h"
// Stock font and GFXFF reference handle
#define GFXFF 1
#define FF18 &FreeSans12pt7b
// Custom are fonts added to library "TFT_eSPI\Fonts\Custom" folder
// a #include must also be added to the "User_Custom_Fonts.h" file
// in the "TFT_eSPI\User_Setups" folder. See example entries.
#define CF_OL24 &Orbitron_Light_24
#define CF_OL32 &Orbitron_Light_32
#define CF_RT24 &Roboto_Thin_24
#define CF_S24  &Satisfy_24
#define CF_Y32  &Yellowtail_32
// Use hardware SPI
TFT_eSPI tft = TFT_eSPI();
void setup(void) {
  Serial.begin(250000);
  tft.begin();
  tft.setRotation(1);
  // Show custom fonts
  // Where font sizes increase the screen is not cleared as the larger fonts overwrite
  // the smaller one with the background colour.
  // We can set the text datum to be Top, Middle, Bottom vertically and Left, Centre
  // and Right horizontally. These are the text datums that can be used:
  // TL_DATUM = Top left (default)
  // TC_DATUM = Top centre
  // TR_DATUM = Top right
  // ML_DATUM = Middle left
  // MC_DATUM = Middle centre <<< This is used below
  // MR_DATUM = Middle right
  // BL_DATUM = Bottom left
  // BC_DATUM = Bottom centre
  // BR_DATUM = Bottom right
  // L_BASELINE = Left character baseline (Line the 'A' character would sit on)
  // C_BASELINE = Centre character baseline
  // R_BASELINE = Right character baseline
  //Serial.println();
  // Set text datum to middle centre (MC_DATUM)
  tft.setTextDatum(MC_DATUM);
  // Set text colour to white with black background
  // Unlike the stock Adafruit_GFX library, the TFT_eSPI library DOES draw the background
  // for the custom and Free Fonts
  tft.setTextColor(TFT_WHITE, TFT_BLACK);
  tft.fillScreen(TFT_MAGENTA);            // Clear screen
  tft.setFreeFont(FF18);                 // Select the font
  tft.drawString("Yellowtail 32", 160, 60, GFXFF);// Print the string name of the font
  tft.setFreeFont(CF_Y32);                 // Select the font
  tft.drawString(TEXT, 160, 120, GFXFF);// Print the string name of the font
  delay(2000);
  tft.fillScreen(TFT_BLUE);            // Clear screen
  tft.drawString("Satisfy 24", 160, 60, GFXFF);// Print the string name of the font
  tft.setFreeFont(CF_S24);                 // Select the font
  tft.drawString(TEXT, 160, 120, GFXFF);// Print the test text in the custom font
  delay(2000);
  tft.fillScreen(TFT_RED);            // Clear screen
  tft.drawString("Roboto 24", 160, 60, GFXFF);// Print the string name of the font
  tft.setFreeFont(CF_RT24);                 // Select the font
  delay(2000);
  tft.fillScreen(TFT_DARKGREY);            // Clear screen
  tft.drawString("Orbitron 24", 160, 60, GFXFF);// Print the string name of the font
  tft.setFreeFont(CF_OL24);                 // Select the font
  delay(2000);
  // Here we do not clear the screen and rely on the new text over-writing the old
  tft.drawString("Orbitron 32", 160, 60, GFXFF);// Print the string name of the font
  tft.setFreeFont(CF_OL32);                 // Select the font
  delay(2000);
  // Here we use text background padding to over-write the old text
  tft.fillScreen(TFT_YELLOW);            // Clear screen
  tft.setTextPadding(tft.width() - 20); // Blanked area will be width of screen minus 20 pixels
  tft.drawString("Orbitron 32 with padding", 160, 60, GFXFF);// Print the string name of the font
  delay(2000);
  // Use 80 pixel wide padding so old numbers over-write old ones
  // One of the problrms with proportionally spaced numbers is that they jiggle position
  tft.setTextPadding(80);
  for( int i = 100; i > 0; i--)
    tft.drawNumber( i, 160, 200);
  // Reset text padding to zero (default)
  tft.setTextPadding(0);
My apologies, I just uploaded the sketch I'm trying to run. It's just one of the basic ones with fonts. One of the other comments mentioned trying an earlier version which sounds like a solid solution. If there's anything else I'm missing let me know and I'll upload it asap.
which version of the ESP32 core are you using?
does the code compile/link and load?
if it runs what happens? e.g. blank scree? white screen? reset loop?
EDIT: if I run your program of post 5 on a CYD 2.8 inch ESP32 module ESP32-2432S028R display it compiles/link/loads and runs
note: it is running on a ESP32 microcontroller
I'm not sure what you mean by ESP core. I'm operating on a ESP32-S3 if that helps. But when I loaded this code it would verify and appear to load into the ESP. The light on the esp would blink blue as it uploads and the IDE would read that it has finished uploading. The screen does not change in the slightest. The screen LEDs are on (white) when the system is connected to my computer, but stays white even after trying to run the code.
Can you post the edited User_Setup.h and any other files that you modified?
the ESP32 core is the basic support code for the ESP32 series of microcontrollers
to check which version you have click Tools>Board>Board Manager then enter ESP32
you should see the current version, e.g. in the following case ESP32 core 2.3.0
click on the drop down box (pointed too by arrow in above screen image)
it will show you the available cores - select the one you wish to load, e.g. selecting 2.0.17
there are problems using the TFT_eSPI library with more up to date cores - if you look at the serial monitor it will show the ESP32S3 is in a continuous reset loop
loading ESP32 core 2.0.14 should fix the reset problem
what does the Serial Monitor show? is it in a reset loop?
also, as requested by @david_2018 , what is your User_Setup?
have you posted a link to the specific ILI9341 TFT display?
//                            USER DEFINED SETTINGS
//   Set driver type, fonts to be loaded, pins used and SPI control method etc.
//   See the User_Setup_Select.h file if you wish to be able to define multiple
//   setups and then easily select which setup file is used by the compiler.
//   If this file is edited correctly then all the library example sketches should
//   run without the need to make any more changes for a particular hardware setup!
//   Note that some sketches are designed for a particular TFT pixel width/height
// User defined information reported by "Read_User_Setup" test & diagnostics example
#define USER_SETUP_INFO "User_Setup"
// Define to disable all #warnings in library (can be put in User_Setup_Select.h)
//#define DISABLE_ALL_LIBRARY_WARNINGS
// Section 1. Call up the right driver file and any options for it
// Define STM32 to invoke optimised processor support (only for STM32)
//#define STM32
// Defining the STM32 board allows the library to optimise the performance
// for UNO compatible "MCUfriend" style shields
//#define NUCLEO_64_TFT
//#define NUCLEO_144_TFT
// STM32 8-bit parallel only:
// If STN32 Port A or B pins 0-7 are used for 8-bit parallel data bus bits 0-7
// then this will improve rendering performance by a factor of ~8x
//#define STM_PORTA_DATA_BUS
//#define STM_PORTB_DATA_BUS
// Tell the library to use parallel mode (otherwise SPI is assumed)
//#define TFT_PARALLEL_8_BIT
//#defined TFT_PARALLEL_16_BIT // **** 16-bit parallel ONLY for RP2040 processor ****
// Display type -  only define if RPi display
//#define RPI_DISPLAY_TYPE // 20MHz maximum SPI
// Only define one driver, the other ones must be commented out
#define ILI9341_DRIVER       // Generic driver for common displays
//#define ILI9341_2_DRIVER     // Alternative ILI9341 driver, see https://github.com/Bodmer/TFT_eSPI/issues/1172
//#define ST7735_DRIVER      // Define additional parameters below for this display
//#define ILI9163_DRIVER     // Define additional parameters below for this display
//#define S6D02A1_DRIVER
//#define RPI_ILI9486_DRIVER // 20MHz maximum SPI
//#define HX8357D_DRIVER
//#define ILI9481_DRIVER
//#define ILI9486_DRIVER
//#define ILI9488_DRIVER     // WARNING: Do not connect ILI9488 display SDO to MISO if other devices share the SPI bus (TFT SDO does NOT tristate when CS is high)
//#define ST7789_DRIVER      // Full configuration option, define additional parameters below for this display
//#define ST7789_2_DRIVER    // Minimal configuration option, define additional parameters below for this display
//#define R61581_DRIVER
//#define RM68140_DRIVER
//#define ST7796_DRIVER
//#define SSD1351_DRIVER
//#define SSD1963_480_DRIVER
//#define SSD1963_800_DRIVER
//#define SSD1963_800ALT_DRIVER
//#define ILI9225_DRIVER
//#define GC9A01_DRIVER
// Some displays support SPI reads via the MISO pin, other displays have a single
// bi-directional SDA pin and the library will try to read this via the MOSI line.
// To use the SDA line for reading data from the TFT uncomment the following line:
// #define TFT_SDA_READ      // This option is for ESP32 ONLY, tested with ST7789 and GC9A01 display only
// For ST7735, ST7789 and ILI9341 ONLY, define the colour order IF the blue and red are swapped on your display
// Try ONE option at a time to find the correct colour order for your display
//  #define TFT_RGB_ORDER TFT_RGB  // Colour order Red-Green-Blue
//  #define TFT_RGB_ORDER TFT_BGR  // Colour order Blue-Green-Red
// For M5Stack ESP32 module with integrated ILI9341 display ONLY, remove // in line below
// #define M5STACK
// For ST7789, ST7735, ILI9163 and GC9A01 ONLY, define the pixel width and height in portrait orientation
// #define TFT_WIDTH  80
// #define TFT_WIDTH  128
// #define TFT_WIDTH  172 // ST7789 172 x 320
// #define TFT_WIDTH  170 // ST7789 170 x 320
// #define TFT_WIDTH  240 // ST7789 240 x 240 and 240 x 320
// #define TFT_HEIGHT 160
// #define TFT_HEIGHT 128
// #define TFT_HEIGHT 240 // ST7789 240 x 240
// #define TFT_HEIGHT 320 // ST7789 240 x 320
// #define TFT_HEIGHT 240 // GC9A01 240 x 240
// For ST7735 ONLY, define the type of display, originally this was based on the
// colour of the tab on the screen protector film but this is not always true, so try
// out the different options below if the screen does not display graphics correctly,
// e.g. colours wrong, mirror images, or stray pixels at the edges.
// Comment out ALL BUT ONE of these options for a ST7735 display driver, save this
// this User_Setup file, then rebuild and upload the sketch to the board again:
// #define ST7735_INITB
// #define ST7735_GREENTAB
// #define ST7735_GREENTAB2
// #define ST7735_GREENTAB3
// #define ST7735_GREENTAB128    // For 128 x 128 display
// #define ST7735_GREENTAB160x80 // For 160 x 80 display (BGR, inverted, 26 offset)
// #define ST7735_ROBOTLCD       // For some RobotLCD Arduino shields (128x160, BGR, https://docs.arduino.cc/retired/getting-started-guides/TFT)
// #define ST7735_REDTAB
// #define ST7735_BLACKTAB
// #define ST7735_REDTAB160x80   // For 160 x 80 display with 24 pixel offset
// If colours are inverted (white shows as black) then uncomment one of the next
// 2 lines try both options, one of the options should correct the inversion.
// #define TFT_INVERSION_ON
// #define TFT_INVERSION_OFF
// Section 2. Define the pins that are used to interface with the display here
// If a backlight control signal is available then define the TFT_BL pin in Section 2
// below. The backlight will be turned ON when tft.begin() is called, but the library
// needs to know if the LEDs are ON with the pin HIGH or LOW. If the LEDs are to be
// driven with a PWM signal or turned OFF/ON then this must be handled by the user
// sketch. e.g. with digitalWrite(TFT_BL, LOW);
// #define TFT_BL   32            // LED back-light control pin
// #define TFT_BACKLIGHT_ON HIGH  // Level to turn ON back-light (HIGH or LOW)
// We must use hardware SPI, a minimum of 3 GPIO pins is needed.
// Typical setup for ESP8266 NodeMCU ESP-12 is :
// Display SDO/MISO  to NodeMCU pin D6 (or leave disconnected if not reading TFT)
// Display LED       to NodeMCU pin VIN (or 5V, see below)
// Display SCK       to NodeMCU pin D5
// Display SDI/MOSI  to NodeMCU pin D7
// Display DC (RS/AO)to NodeMCU pin D3
// Display RESET     to NodeMCU pin D4 (or RST, see below)
// Display CS        to NodeMCU pin D8 (or GND, see below)
// Display GND       to NodeMCU pin GND (0V)
// Display VCC       to NodeMCU 5V or 3.3V
// The TFT RESET pin can be connected to the NodeMCU RST pin or 3.3V to free up a control pin
// The DC (Data Command) pin may be labelled AO or RS (Register Select)
// With some displays such as the ILI9341 the TFT CS pin can be connected to GND if no more
// SPI devices (e.g. an SD Card) are connected, in this case comment out the #define TFT_CS
// line below so it is NOT defined. Other displays such at the ST7735 require the TFT CS pin
// to be toggled during setup, so in these cases the TFT_CS line must be defined and connected.
// The NodeMCU D0 pin can be used for RST
// Note: only some versions of the NodeMCU provide the USB 5V on the VIN pin
// If 5V is not available at a pin you can use 3.3V but backlight brightness
// will be lower.
// ###### EDIT THE PIN NUMBERS IN THE LINES FOLLOWING TO SUIT YOUR ESP8266 SETUP ######
// For NodeMCU - use pin numbers in the form PIN_Dx where Dx is the NodeMCU pin designation
// #define TFT_MISO  PIN_D6  // Automatically assigned with ESP8266 if not defined
// #define TFT_MOSI  PIN_D7  // Automatically assigned with ESP8266 if not defined
// #define TFT_SCLK  PIN_D5  // Automatically assigned with ESP8266 if not defined
// #define TFT_CS    PIN_D8  // Chip select control pin D8
// #define TFT_DC    PIN_D3  // Data Command control pin
// #define TFT_RST   PIN_D4  // Reset pin (could connect to NodeMCU RST, see next line)
//#define TFT_RST  -1     // Set TFT_RST to -1 if the display RESET is connected to NodeMCU RST or 3.3V
//#define TFT_BL PIN_D1  // LED back-light (only for ST7789 with backlight control pin)
//#define TOUCH_CS PIN_D2     // Chip select pin (T_CS) of touch screen
//#define TFT_WR PIN_D2       // Write strobe for modified Raspberry Pi TFT only
// ######  FOR ESP8266 OVERLAP MODE EDIT THE PIN NUMBERS IN THE FOLLOWING LINES  ######
// Overlap mode shares the ESP8266 FLASH SPI bus with the TFT so has a performance impact
// but saves pins for other functions. It is best not to connect MISO as some displays
// do not tristate that line when chip select is high!
// Note: Only one SPI device can share the FLASH SPI lines, so a SPI touch controller
// cannot be connected as well to the same SPI signals.
// On NodeMCU 1.0 SD0=MISO, SD1=MOSI, CLK=SCLK to connect to TFT in overlap mode
// On NodeMCU V3  S0 =MISO, S1 =MOSI, S2 =SCLK
// In ESP8266 overlap mode the following must be defined
//#define TFT_SPI_OVERLAP
// In ESP8266 overlap mode the TFT chip select MUST connect to pin D3
//#define TFT_CS   PIN_D3
//#define TFT_DC   PIN_D5  // Data Command control pin
//#define TFT_RST  PIN_D4  // Reset pin (could connect to NodeMCU RST, see next line)
// ###### EDIT THE PIN NUMBERS IN THE LINES FOLLOWING TO SUIT YOUR ESP32 SETUP   ######
// For ESP32 Dev board (only tested with ILI9341 display)
// The hardware SPI can be mapped to any pins
//#define TFT_MISO 19
#define TFT_MOSI 12
#define TFT_SCLK 18
#define TFT_CS   15  // Chip select control pin
#define TFT_DC    5  // Data Command control pin
#define TFT_RST   4  // Reset pin (could connect to RST pin)
#define TFT_RST  -1  // Set TFT_RST to -1 if display RESET is connected to ESP32 board RST
// For ESP32 Dev board (only tested with GC9A01 display)
//#define TFT_MOSI 15 // In some display driver board, it might be written as "SDA" and so on.
//#define TFT_SCLK 14
//#define TFT_CS   5  // Chip select control pin
//#define TFT_DC   27  // Data Command control pin
//#define TFT_RST  33  // Reset pin (could connect to Arduino RESET pin)
//#define TFT_BL   22  // LED back-light
//#define TOUCH_CS 21     // Chip select pin (T_CS) of touch screen
//#define TFT_WR 22    // Write strobe for modified Raspberry Pi TFT only
// For the M5Stack module use these #define lines
//#define TFT_MOSI 23
//#define TFT_SCLK 18
//#define TFT_CS   14  // Chip select control pin
//#define TFT_BL   32  // LED back-light (required for M5Stack)
// ######       EDIT THE PINs BELOW TO SUIT YOUR ESP32 PARALLEL TFT SETUP        ######
// The library supports 8-bit parallel TFTs with the ESP32, the pin
// selection below is compatible with ESP32 boards in UNO format.
// Wemos D32 boards need to be modified, see diagram in Tools folder.
// Only ILI9481 and ILI9341 based displays have been tested!
// Parallel bus is only supported for the STM32 and ESP32
// Example below is for ESP32 Parallel interface with UNO displays
// Tell the library to use 8-bit parallel mode (otherwise SPI is assumed)
// The ESP32 and TFT the pins used for testing are:
//#define TFT_CS   33  // Chip select control pin (library pulls permanently low
//#define TFT_DC   15  // Data Command control pin - must use a pin in the range 0-31
//#define TFT_RST  32  // Reset pin, toggles on startup
//#define TFT_WR    4  // Write strobe control pin - must use a pin in the range 0-31
//#define TFT_RD    2  // Read strobe control pin
//#define TFT_D0   12  // Must use pins in the range 0-31 for the data bus
//#define TFT_D1   13  // so a single register write sets/clears all bits.
//#define TFT_D2   26  // Pins can be randomly assigned, this does not affect
//#define TFT_D3   25  // TFT screen update performance.
//#define TFT_D4   17
//#define TFT_D5   16
//#define TFT_D6   27
//#define TFT_D7   14
// ######       EDIT THE PINs BELOW TO SUIT YOUR STM32 SPI TFT SETUP        ######
// The TFT can be connected to SPI port 1 or 2
//#define TFT_SPI_PORT 1 // SPI port 1 maximum clock rate is 55MHz
//#define TFT_MOSI PA7
//#define TFT_MISO PA6
//#define TFT_SCLK PA5
//#define TFT_SPI_PORT 2 // SPI port 2 maximum clock rate is 27MHz
//#define TFT_MOSI PB15
//#define TFT_MISO PB14
//#define TFT_SCLK PB13
// Can use Ardiuno pin references, arbitrary allocation, TFT_eSPI controls chip select
//#define TFT_CS   D5 // Chip select control pin to TFT CS
//#define TFT_DC   D6 // Data Command control pin to TFT DC (may be labelled RS = Register Select)
//#define TFT_RST  D7 // Reset pin to TFT RST (or RESET)
// OR alternatively, we can use STM32 port reference names PXnn
//#define TFT_CS   PE11 // Nucleo-F767ZI equivalent of D5
//#define TFT_DC   PE9  // Nucleo-F767ZI equivalent of D6
//#define TFT_RST  PF13 // Nucleo-F767ZI equivalent of D7
//#define TFT_RST  -1   // Set TFT_RST to -1 if the display RESET is connected to processor reset
                        // Use an Arduino pin for initial testing as connecting to processor reset
                        // may not work (pulse too short at power up?)
// Section 3. Define the fonts that are to be used here
// Comment out the #defines below with // to stop that font being loaded
// The ESP8366 and ESP32 have plenty of memory so commenting out fonts is not
// normally necessary. If all fonts are loaded the extra FLASH space required is
// about 17Kbytes. To save FLASH space only enable the fonts you need!
#define LOAD_GLCD   // Font 1. Original Adafruit 8 pixel font needs ~1820 bytes in FLASH
#define LOAD_FONT2  // Font 2. Small 16 pixel high font, needs ~3534 bytes in FLASH, 96 characters
#define LOAD_FONT4  // Font 4. Medium 26 pixel high font, needs ~5848 bytes in FLASH, 96 characters
#define LOAD_FONT6  // Font 6. Large 48 pixel font, needs ~2666 bytes in FLASH, only characters 1234567890:-.apm
#define LOAD_FONT7  // Font 7. 7 segment 48 pixel font, needs ~2438 bytes in FLASH, only characters 1234567890:-.
#define LOAD_FONT8  // Font 8. Large 75 pixel font needs ~3256 bytes in FLASH, only characters 1234567890:-.
//#define LOAD_FONT8N // Font 8. Alternative to Font 8 above, slightly narrower, so 3 digits fit a 160 pixel TFT
#define LOAD_GFXFF  // FreeFonts. Include access to the 48 Adafruit_GFX free fonts FF1 to FF48 and custom fonts
// Comment out the #define below to stop the SPIFFS filing system and smooth font code being loaded
// this will save ~20kbytes of FLASH
#define SMOOTH_FONT
// Section 4. Other options
// For RP2040 processor and SPI displays, uncomment the following line to use the PIO interface.
//#define RP2040_PIO_SPI // Leave commented out to use standard RP2040 SPI port interface
// For RP2040 processor and 8 or 16-bit parallel displays:
// The parallel interface write cycle period is derived from a division of the CPU clock
// speed so scales with the processor clock. This means that the divider ratio may need
// to be increased when overclocking. It may also need to be adjusted dependant on the
// display controller type (ILI94341, HX8357C etc.). If RP2040_PIO_CLK_DIV is not defined
// the library will set default values which may not suit your display.
// The display controller data sheet will specify the minimum write cycle period. The
// controllers often work reliably for shorter periods, however if the period is too short
// the display may not initialise or graphics will become corrupted.
// PIO write cycle frequency = (CPU clock/(4 * RP2040_PIO_CLK_DIV))
//#define RP2040_PIO_CLK_DIV 1 // 32ns write cycle at 125MHz CPU clock
//#define RP2040_PIO_CLK_DIV 2 // 64ns write cycle at 125MHz CPU clock
//#define RP2040_PIO_CLK_DIV 3 // 96ns write cycle at 125MHz CPU clock
// For the RP2040 processor define the SPI port channel used (default 0 if undefined)
//#define TFT_SPI_PORT 1 // Set to 0 if SPI0 pins are used, or 1 if spi1 pins used
// For the STM32 processor define the SPI port channel used (default 1 if undefined)
//#define TFT_SPI_PORT 2 // Set to 1 for SPI port 1, or 2 for SPI port 2
// Define the SPI clock frequency, this affects the graphics rendering speed. Too
// fast and the TFT driver will not keep up and display corruption appears.
// With an ILI9341 display 40MHz works OK, 80MHz sometimes fails
// With a ST7735 display more than 27MHz may not work (spurious pixels and lines)
// With an ILI9163 display 27 MHz works OK.
// #define SPI_FREQUENCY   1000000
// #define SPI_FREQUENCY   5000000
// #define SPI_FREQUENCY  10000000
// #define SPI_FREQUENCY  20000000
#define SPI_FREQUENCY  27000000
// #define SPI_FREQUENCY  40000000
// #define SPI_FREQUENCY  55000000 // STM32 SPI1 only (SPI2 maximum is 27MHz)
// #define SPI_FREQUENCY  80000000
// Optional reduced SPI frequency for reading TFT
#define SPI_READ_FREQUENCY  20000000
// The XPT2046 requires a lower SPI clock rate of 2.5MHz so we define that here:
#define SPI_TOUCH_FREQUENCY  2500000
// The ESP32 has 2 free SPI ports i.e. VSPI and HSPI, the VSPI is the default.
// If the VSPI port is in use and pins are not accessible (e.g. TTGO T-Beam)
// then uncomment the following line:
//#define USE_HSPI_PORT
// Comment out the following #define if "SPI Transactions" do not need to be
// supported. When commented out the code size will be smaller and sketches will
// run slightly faster, so leave it commented out unless you need it!
// Transaction support is needed to work with SD library but not needed with TFT_SdFat
// Transaction support is required if other SPI devices are connected.
// Transactions are automatically enabled by the library for an ESP32 (to use HAL mutex)
// so changing it here has no effect
// #define SUPPORT_TRANSACTIONS
Sketch uses 342301 bytes (26%) of program storage space. Maximum is 1310720 bytes.
Global variables use 19272 bytes (5%) of dynamic memory, leaving 308408 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.5.1
Serial port COM5
Connecting...
Chip is ESP32-S3 (revision v0.2)
Features: WiFi, BLE
Crystal is 40MHz
MAC: f0:9e:9e:21:67:d8
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Flash will be erased from 0x00000000 to 0x00003fff...
Flash will be erased from 0x00008000 to 0x00008fff...
Flash will be erased from 0x0000e000 to 0x0000ffff...
Flash will be erased from 0x00010000 to 0x00063fff...
Compressed 15104 bytes to 10401...
Writing at 0x00000000... (100 %)
Wrote 15104 bytes (10401 compressed) at 0x00000000 in 0.4 seconds (effective 302.6 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 146...
Writing at 0x00008000... (100 %)
Wrote 3072 bytes (146 compressed) at 0x00008000 in 0.1 seconds (effective 309.3 kbit/s)...
Compressed 8192 bytes to 47...
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 482.6 kbit/s)...
Compressed 342672 bytes to 190244...
Writing at 0x00010000... (8 %)
Writing at 0x00017ac5... (16 %)
Writing at 0x00022600... (25 %)
Writing at 0x0002e66b... (33 %)
Writing at 0x00034073... (41 %)
Writing at 0x00039be6... (50 %)
Writing at 0x0003f1d0... (58 %)
Writing at 0x00044772... (66 %)
Writing at 0x00049eae... (75 %)
Writing at 0x000525ae... (83 %)
Writing at 0x0005a79d... (91 %)
Writing at 0x0005fec6... (100 %)
Wrote 342672 bytes (190244 compressed) at 0x00010000 in 3.4 seconds (effective 808.3 kbit/s)...
Leaving...
Hard resetting via RTS pin...
Ahh, I'm unfamiliar with the terminology. Yes, I have the esp32 core set to 2.0.14 and the latest version of TFT_espi. But I'm still encountering an issue. I replied with the user_setup.h file I am currently using. As well as the Output on the IDE. Additionally I copied the link of the exact model of LCD I purchased.
where did you get these pin definitions from?
I assume you have setup Documents\Arduino\libraries\TFT_eSPI\User_Setup_Select.h to reference the appropriate User_Setup.h file
which specific ESP32S3 module are you using? give us a link?
My apologies, yes these are the pins I have set up on the board. Assuming I set up everything correctly on the hardware side I don't see why it shouldn't work.
I think I set up the Documents\Arduino\libraries\TFT_eSPI\User_Setup_Select.h but I'm not entirely sure. Where would I input that if it isn't set up automatically?
with the ESP32-S3-DevKitC-1 and a ILI9341 I usedSetup70b_ESP32_S3_ILI9341
// Setup for the ESP32 S3 with ILI9341 display
// Note SPI DMA with ESP32 S3 is not currently supported
#define USER_SETUP_ID 70
// See SetupX_Template.h for all options available
#define TFT_CS   SS     // 10
#define TFT_MOSI MOSI   // 11
#define TFT_SCLK SCK    // 12
#define TFT_MISO MISO   // 13
#define TFT_DC   9
#define TFT_RST  4
//#define TOUCH_CS 16 // Optional for touch screen
#define LOAD_GLCD
#define LOAD_FONT2
#define LOAD_FONT4
#define LOAD_FONT6
#define LOAD_FONT7
#define LOAD_FONT8
#define LOAD_GFXFF
#define SMOOTH_FONT
// FSPI (or VSPI) port (SPI2) used unless following defined. HSPI port is (SPI3) on S3.
//#define SPI_FREQUENCY  27000000
#define SPI_FREQUENCY  40000000   // Maximum for ILI9341
#define SPI_READ_FREQUENCY  6000000 // 6 MHz is the maximum SPI read speed for the ST7789V
You really should only have one of the defines for TFT_RST un-commented. At it is, -1 indicates that no reset line is connected.
Wow, changing that one one thing completely fixed it. I appreciate all the help from everyone. Holy crap, that took way too much trail and error. I just needed to undefine the reset pin.
