it is possible to disable the internal led of the pin 13?
I use the all pins to light up this thing:
but the pin 13 the brightness is smaller than the rest...
my guess is because the internal led lights up together, dividing the current, so I want to know if I can disable the internal led in this case
  pinMode(13, OUTPUT);
  digitalWrite(13 HIGH);
diogo_zanardini:
If you dont want the LED connected to pin 13 to activate when pin 13 is used, then you need to disconnect the pin13 LED or its series resistor.
It depends on which Arduino you have. Many of them have a buffer on pin 13 to drive the LED. If the LED is directly connected to the pin and you need to use 13 as an input, the inputting device is forced to drive the LED.
If you have a soldering iron you can attempt to remove the LED. You will always destroy it in the process, so there's no need to be gentle. On many Arduinos, such as the Micro, it's actually easier to remove the resistor instead of the LED. Even without a soldering iron you can grip it with pliers and tear it off the board, but that has a risk of damaging other parts nearby.
