Bonjour j'ai un petit projet perso "db mètre " j'ai utiliser un code deja fait :
mais en le modifiant j'arrive a avoir des erreurs :
Arduino : 1.8.4 (Windows 10), Carte : "Arduino/Genuino Uno"
C:\Users\Mrlog42\Desktop\Dose_Le_Son.V.2\Code\Code led\Code_LED\Code_LED.ino: In function 'void soundISR()':
Code_LED:22: error: too many arguments to function 'void digitalWrite(uint8_t, uint8_t)'
digitalWrite (PIN_LED_R, PIN_LED_V, PIN_LED_J, pin_val);
In file included from sketch\Code_LED.ino.cpp:1:0:
C:\Users\Mrlog42\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino/Arduino.h:134:6: note: declared here
void digitalWrite(uint8_t, uint8_t);
C:\Users\Mrlog42\Desktop\Dose_Le_Son.V.2\Code\Code led\Code_LED\Code_LED.ino: In function 'void loop()':
Code_LED:55: error: 'PIN_LED_j' was not declared in this scope
digitalWrite(PIN_LED_j,LOW);
Code_LED:56: error: 'PIN_LED_r' was not declared in this scope
digitalWrite(PIN_LED_r,LOW);
Code_LED:63: error: 'PIN_LED_j' was not declared in this scope
digitalWrite(PIN_LED_j,HIGH);
Code_LED:64: error: 'PIN_LED_r' was not declared in this scope
Code_LED:70: error: 'PIN_LED_j' was not declared in this scope
Code_LED:71: error: 'PIN_LED_r' was not declared in this scope
digitalWrite(PIN_LED_r,HIGH);
exit status 1
le code en question :
* GND → GND
* VCC → 5V
* Gate → Pin 2
* Envelope → A0
* ledr 12
* ledj 10
* ledv 11
// Define hardware connections
#define PIN_GATE_IN 2
#define IRQ_GATE_IN 0
#define PIN_LED_R 12
#define PIN_LED_V 11
#define PIN_LED_J 10
#define PIN_ANALOG_IN A0
void soundISR()
int pin_val;
pin_val = digitalRead(PIN_GATE_IN);
digitalWrite (PIN_LED_R, PIN_LED_V, PIN_LED_J, pin_val); //l'erreur est sur cette ligne!!
// Configure LED pin as output
pinMode(PIN_LED_R, OUTPUT);
pinMode(PIN_LED_V, OUTPUT);
pinMode(PIN_LED_J, OUTPUT);
// configure input to interrupt
pinMode(PIN_GATE_IN, INPUT);
attachInterrupt(IRQ_GATE_IN, soundISR, CHANGE);
// Display status
Serial.println("Initialized");
int value;
// Check the envelope input
value = analogRead(PIN_ANALOG_IN);
// Convert envelope value into a message
Serial.print("Status: ");
if(value <= 10)
Serial.println("Quiet.");
digitalWrite(PIN_LED_V,HIGH);
else if( (value > 10) && ( value <= 30) )
Serial.println("Moderate.");
else if(value > 30)
Serial.println("Loud.");
merci d'avance
ciao les makers
01000100 01101001 01110100 01100101 01110011 00100000 01101101 01101111 01101110 00100000 01101110 01101111 01101101 00100000 00101000 01101000 01100101 01101001 01110011 01100101 01101110 01100010 01100101 01110010 01100111 00101001 00100000 00101000 01000010 01110010 01100101 01100001 01101011 01101001 01101110 01100111 00100000 01000010 01100001 01100100 00101001
