JY MCU Bluetooth board
Im having trouble doing anything with this board.
http://www.ebay.com/itm/221235959823?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
I basically want to do this
This is the app
https://play.google.com/store/apps/details?id=com.app.control&feature=search_result&rdid=com.app.control&rdot=1
Please help me with this project
What trouble are you having precisely?
My phone wont connect with the JY-MCU, I put in the pin and it wont connect with it. IT says paired but not connected
If you search for them there are several threads about this problem..I found a sketch for some testing. I think I have a copy but I've never used it so good luck. Apparently it's for the open pilot project of which I know nothing... I downloaded it to test my BT modules easily and quickly... I hope when I get to them.
Doc
Bluetooth_Programmer_v1_2.zip (4.27 KB)
Okay I did everything and when i upload it, it says
VERIFICATION FAILED!!!, No answer from the BT module
Check your connections and/or baud rate
Entering Command mode, you can now attempt a manual configuration
Sneath4122:
What is "IT"?
I ment It as in the bluetooth module
Sneath4122:
So the bluetooth module has a screen on it? Or it talks? How did it say "paired but not connected"
When i try and connect to it with my phone, my phone says paired but not connected
Did you by any chance remember to swap RX and TX lines? If you connect TX to TX and RX to RX you can have the problem because although they might be 'paired' that is a very low level RF/Data condition where one BT device identifies another via the rf link.
