k-line arduino project, speed and brake lights
Hello.
I have a simple task to achieve, I guess, but I'm stuck. I'm using the setup from the attached image. All I need to do is to read the Speed of the vehicle using data from the obd2 k-line pin, and then to send a command to blink the brake lights when a certain decrease in speed is detected (e.g. more than 2km/h/s). I can not initialize the k-line and I am not able to red anything on the serial monitor on arduino :(. After I manage to read the raw data I am planing to figure out what's the code for turning on the brake lights by just simply pressing the brake pedal. The vehicle is an 2004 BMW E60, but I guess this is not an issue.
Question... Are the TX/RX pins connected as it shod on the arduino board?
Thank you. Ant help would be appreciated. I need this for a school project and a have a deadline :(((
You can have only one thing connected to the hardware serial port (pins 0 and 1) so you can't read and write to the interface chip and the serial monitor at the same time on the same port. The Arduino Mega has 3 hardware serial ports so may be a better board for your project.
There are software serial libraries for the Uno, but I don't know if they are fast enough.
look at the red wire in your drawing and see if you can tell if anything is amiss...
Hello.
catasbox:
Hello.
RX K-line -----> TX Arduino
TX K-line -----> RX Arduino
123Splat:
Yeah... ignore that red line... it's not connected.
@catasbox, stop hijacking.
@catasbox, stop cross-posting.
