Keep getting the "a function-definition is not allowed here before '{' token" error
I keep getting this error "A function definition is not allowed here before '{' token" It is my first time using Arduino Uno. I have looked at this topic before but I don't get it. It is probably a simple answer I just don't get it.
< void setup() {
// code to control continuous rotation servo with potentiometer
#include <Servo.h>
Servo myservo; // create servo object to control a servo
int pot; // variable for potentiometer analog reading, 0-123
int speed; // variable for servo speed, 0-180.
// servo is STOPPED at speed = 90
// full speed in either direction at 0 or 180.
// this is NOT the servo's angular position
// setup code that only runs once
myservo.attach(8); // use pin 8 to control the servo
// code that loops repeatedly
pot = analogRead(A0); // read analog voltage from potentiometer
speed = map(pot, 0, 1023, 0, 180); // convert analog reading 0-1023 to speed 0-180
myservo.write(speed); // send control signal to servo
sorry i don't really know how to put code in here
Is this your code ?
#include <Servo.h>
@LarryD 's code (fixed) does compile
yes
how did you fix it
well i keep getting this error and i have been told that it worked for other ppl but it is not working for me. this is also my first time using arduino and i have posted this question before. if it works for you can you please tell me how you fixed it.
#include <Servo.h>
put your main code here, to run repeatedly:
type or paste code here
Your sketch has two loop() functions in it when it must have only one
To make thinks worse one is defined inside the other and to make things even worse you have two setup() functions as well
Your two or more topics on the same or similar subject have been merged.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
