I’m using an ftdi to usb convertor with a stand alone 328 to program it .
The 328 is powered and the ftdi 5v and Ov are connected too.
The Tx and Rx are only connected to the ftdi . A 0.1uF cap and 10k pull up is used to reset off the DTR line.
I’ve broken a couple of the ftdi devices when programming . They still output 3v3 or 5v , the fault appears to be the rx side has died - no led flash from it when performing a loop back, although the Tx led lights . windows still finds the adapter .
Can’t figure this out , but as a long shot any thoughts ???
