It's a bit difficult to follow your wiring from those pics. Can you do a quick hand-drawn sketch of your wiring, exactly as you have it, including the power for the motor and the chip, and the chip enable?
edit.... you sure you have voltage on the ends of the battery wires?
Give some more information.
What motor are you (trying to be) using ?
Do you know that these 9 volt batteries really suck for powering a motor ?
Do you know the L293D can control no more that 600 mA, and that it drops (eats) about 3 volts ?
PP3-sized 9V batteries are not designed to power motors at all and may struggle
to do anything.
What voltage is the motor? What is its stall current? Do you realise that if
the motor pulls enough current to crowbar the output voltage of the 9V
battery it will pull current from the Arduino instead, probably resetting it.
Something like 4 to 6 quality NiMH rechargable AA cells are a good supply for
small 6V motors.
