L298 dual h bridge driver not driving DC motor
Hi
I have L298 dual h bridge driver connected to a DC motor
https://www.amazon.com/Helion-HLNA0057-Dominus-Motor-Brushed/dp/B00DUDYBFO
https://www.osepp.com/electronic-modules/breakout-boards/92-osepp-motor-driver-module
Motor and and battery ( 11.1 V LiPo ) are connected as follows
Battery + terminal = VCC on driver
Battery - terminal = GND on driver + GND on Arduino
ENA = pin 3
IN1 = pin 8
IN2 = pin 9
Arduino code (obtained from driver's company) :
/* L298N DC motor example */
int IN1=8;
int IN2=9;
int ENA=3;
 pinMode(IN1,OUTPUT);
 pinMode(IN2,OUTPUT);
 analogWrite(ENA, 200);// motor speed
 digitalWrite(IN1,LOW);// rotate forward
 digitalWrite(IN2,HIGH);
 delay(2000);
 digitalWrite(IN1,HIGH);// rotate reverse
 digitalWrite(IN2,LOW);
 delay(2000);
Driver has a red light on but the motor does not move
Any ideas why would this happen ?
Have you got the jumper on or otherwise supplying 5V to the 298 logic?
edit: oh wait, the red led means there's 5V present I think.
Have you put the motor straight on the battery to test it's ok?
nyphot:
Yes. The motor runs perfectly when hooked up directly to battery
That motor is a high power RC motor, an L298 is way too low current for it.
MarkT:
Ok so it seems that pins on the arduino was flipped
I got a smaller motor to work
but when I hook the big one it keeps beebing
is this due to the low current ?
MarkT:
Is there still a way to use this driver for a high power motor ?
Im getting this error too! I am using this H-bridge to control two motors using a potentiometer. When I run i, there is a red light that shines and the motor barely runs it and rather beeps instead of runinng.
inabhani:
Ask the same question you'll get the same answer but in capitals.
That motor is a high power RC motor, an L298 is WAY TOO LOW CURRENT FOR IT.
so it wont work at all?
@MarkT, don't shout too much at inhabani, it's Bull Engineer necro-ing this thread asking pretty much the same question that he (BE) has been asking all over :wink:
You simply didn't setup the ENA pin as an OUTPUT, duh
AyaAj:
And you, AyaAj, simply didn't rtfm:
You do not need to call pinMode() to set the pin as an output before calling analogWrite().
So you might like to retract that "duh"?
