hey, I have the same motor driver. Do you check the ground ? If you use a different power source to power arduino and a different power source to power L298N you have to have COMMON ground. But ONLY ground.
I connected the L298N board back to the ground on my battery and then added another cable from the ground on my battery back to the ground on the Arduino and it worked!!!
Please read the first post in any forum entitled how to use this forum. http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
I'm using the l298n motor driver for my sensor based car
the sensor is working but the motor is not rotating when I check
the voltage at out1 and out2 it is zero then I had used to power source one connected Arduino and another to l298
still not working
I am encountering the same problem, also I tried (How to test L298N motor driver board - Tutorial - YouTube) mentioned way to test the l298n motor driver which I bought from robotbanao.com.Niether the mentioned way is working or with arduino uno. Please help me I have my project to be submitted by 20th february
