L298N and Arduino ground
Im just baffled, I'm working in with L298N and arduino this picture is my reference, the thing is if the the ground of the arduino is connected to the ground of the L298N, the L298N is not working properly(btw im using different power supply for arduino and L298N), But if i disconnect the ground the L298N works just fine
How is power connected to the Arduino? How much power? Show a picture. Perhaps the external power supply ground is very noisy, making ground fluctuate.
the arduino is powered by USB which connected to my PC, the L298N is powered by 12V 2A DC adaptor
It sounds like you have it wired correctly, but I think the condition of the wiring is the problem. I think your moving wires causes the good/bad to happen, not the fact that you are removing the required common ground. Verify all jumper wire connections are good. Upload a picture of your project.
I moved your topic to an appropriate forum category @berto55 .
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Hi, @berto55
Welcome to the forum.
Can you post some images of your project?
So we can see your component layout.
Rather than a Fritzy image.
Thanks.. Tom... :smiley: :+1: :coffee: :australia:
