L298N motor controlling controlling isues (code problems)
Hi everybody
I got a huge problem concerning my school project.
i am controlling an ROV using a arduino Mega, whose purpose is to control 3 L298N hooked up to 4 DC engines and 2 halogen light bulbs.
The L298N are activated by momentary switches. 9, where 8 are to the motors and 1 are for the lights. they are connected on digital inputs 36-44
The speed of which the motors are going to be runing on are determined by two 100K potentiometers,one for light one for motorspeed , their inputs are connected to A0-A1. where the inputs are beeing read. those values are mapped (0 - 1023 converted to 0 - 255) and so they can be sent as an output.
a visual aid is added for the user to se how high, or low, the value is. this is done by two rows of seven LED's. they are controlled on output 22-35. when the value is at a certain point a ''high'' signal is sent to an ULN2003A darlington transistor array, which turns the LED's on.
to help you understand how i control this i have drawn a simple sketch, showing the hookup
The switches are connected with a pulldown resistor, so the instead of a floating value the value is pulled down to zero.
this hookup is maid on a PCB, and testet working, each switch, pot and LED is testet working propper. the dual H-bridges are also working fine.
THE PROBLEM IS THE CODE
i can get the led's flashing when the pots are at a certain value, this is done by a series of if statements.
now my thoughts were i could do the same with controling the engines, i just had to enable the circuit on the L298N and send a PWM signal to input 1 or 2 on it.
the problem is, it will only work if there is only one if statement in the code when concerning the L298N (since the LEDs and darlington arrays are working perfectly).
for an example. pushing the ''forward'' switch activates the two engines pushing forward. no problem their.
but when i write a new if statement for, lets say reverse, the DC motor won't respond. and yes, the l298N boards are tested and working.
and then i can't figure out a code for the light so when the switch is pushed the lights stay on, until the switch is pushed again the lights go off. this i find tricky to do, since i can't work out a proper code that will handle the debounce of the switch, and making it read the analog value from the pot when activated at the same time.
so i am wondering if it is the code, i could really need some adivce on maybe another command i could use to easen this.
i am fairly new to this arduino programming so feel free to comment and tell me if i am totally of course using on if statements.
const int analogLightPin = A0;    // pin that the sensor is attached to
const int analogMotorPin = A1;
  // initialize the LED pin as an output:
  pinMode(22, OUTPUT);
  pinMode(23, OUTPUT);
  pinMode(24, OUTPUT);
  pinMode(25, OUTPUT);
  pinMode(26, OUTPUT);
  pinMode(27, OUTPUT);
  pinMode(28, OUTPUT);
  pinMode(29, OUTPUT);
  pinMode(30, OUTPUT);
  pinMode(31, OUTPUT);
  pinMode(32, OUTPUT);
  pinMode(33, OUTPUT);
  pinMode(34, OUTPUT);
  pinMode(35, OUTPUT);
  pinMode(36, INPUT);
  pinMode(37, INPUT);
  pinMode(38, INPUT);
  pinMode(39, INPUT);
  pinMode(40, INPUT);
  pinMode(41, INPUT);
  pinMode(42, INPUT);
  pinMode(43, INPUT);
  pinMode(44, INPUT);
  // initialize serial communications:
  // read the value of the potentiometer:
  int analogMotorValue = analogRead(analogMotorPin);
  int analogLightValue = analogRead(analogLightPin);
  if (analogLightValue > 170) {
    digitalWrite(22, HIGH);
  else {
    digitalWrite(22, LOW);
  if (analogLightValue > 340) {
    digitalWrite(23, HIGH);
  else {
    digitalWrite(23, LOW);
  if (analogLightValue > 510) {
    digitalWrite(24, HIGH);
  else {
    digitalWrite(24, LOW);
  if (analogLightValue > 680) {
    digitalWrite(25, HIGH);
  else {
    digitalWrite(25, LOW);
  if (analogLightValue > 850) {
    digitalWrite(26, HIGH);
  else {
    digitalWrite(26, LOW);
  if (analogLightValue > 900) {
    digitalWrite(27, HIGH);
  else {
    digitalWrite(27, LOW);
  if (analogLightValue > 1000) {
    digitalWrite(28, HIGH);
  else {
    digitalWrite(28, LOW);
  if (analogMotorValue > 170) {
    digitalWrite(29, HIGH);
  else {
    digitalWrite(29, LOW);
  if (analogMotorValue > 340) {
    digitalWrite(30, HIGH);
  else {
    digitalWrite(30, LOW);
  if (analogMotorValue > 510) {
    digitalWrite(31, HIGH);
  else {
    digitalWrite(31, LOW);
  if (analogMotorValue > 680) {
    digitalWrite(32, HIGH);
  else {
    digitalWrite(32, LOW);
  if (analogMotorValue > 850) {
    digitalWrite(33, HIGH);
  else {
    digitalWrite(33, LOW);
  if (analogMotorValue > 900) {
    digitalWrite(34, HIGH);
  else {
    digitalWrite(34, LOW);
  if (analogMotorValue > 1000) {
    digitalWrite(35, HIGH);
  else {
    digitalWrite(35, LOW);
int outputMotorValue = map(analogMotorValue, 0, 1023, 0, 255);
  if (digitalRead(36) == HIGH)
    digitalWrite(45, HIGH);
    digitalWrite(46, HIGH);
    analogWrite(2, outputMotorValue);
    analogWrite(4, outputMotorValue);
    digitalWrite(45, LOW);
    digitalWrite(46, LOW);
  if (digitalRead(37) == HIGH)
    analogWrite(3, outputMotorValue);
    analogWrite(5, outputMotorValue);
  if (digitalRead(38) == HIGH)
  if (digitalRead(39) == HIGH)
  if (digitalRead(40) == HIGH)
    digitalWrite(48, HIGH);
    analogWrite(9, outputMotorValue);
    digitalWrite(48, LOW);
  if (digitalRead(41) == HIGH)
    analogWrite(10, outputMotorValue);
  if (digitalRead(42) == HIGH)
    digitalWrite(47, HIGH);
    analogWrite(6, outputMotorValue);
    digitalWrite(47, LOW);
  if (digitalRead(43) == HIGH)
    analogWrite(8, outputMotorValue);
int outputLightValue = map(analogLightValue, 0, 1023, 0, 255);
  if (digitalRead(44) == HIGH)
    digitalWrite(49, HIGH);
    analogWrite(11, outputLightValue);
    digitalWrite(49, LOW);
  Serial.println(analogMotorValue);
  Serial.println(analogLightValue);
btw, the serial readings are for my check on my laptop that the led's are working
i really need to get this working by monday, so could really need some advice
Sincerly,
Mikkel
The motor drivers are cut off the picture, so I can 't see the actual connections, but I see two possible problems.
You are never turning off the motor drive signals, only turning them on.
When the switch on channel 36 is HIGH you set a value on channels 2 & 4. That works just fine. But when the switch on channel 37 is HIGH you set values on 3 & 5. You now have PWM signals on all four channels. Is that what you want? Shouldn't you turn channels 2 & 4 off before you turn 3 & 5 on? The same thing seems to be true of 6, 8, 9, 10 and 11. I don't see where they ever turn off.
I would suggest something like this
    analogWrite(2, 0);
    analogWrite(3, 0);
    analogWrite(4, 0);
    analogWrite(5, 0);
    analogWrite(2, 0);
    analogWrite(3, 0);
    analogWrite(4, 0);
    analogWrite(5, 0);
That way only the commanded outputs will be on. All others will be off. You may need to change the value to 255 depending on the polarity of the signal. You can also accomplish this with a digitalWrite.
Are you driving both sides of the H-Bridge with a PWM (In1 & In2 on the L298). Generally when driving an H-Bridge you turn one transistor on and PWM the other. You can get strange behavior when you PWM both sides if the signals are not synchronized correctly. I assume you are using a regular DC motor (not a stepper motor). When you want to drive the motor forward, set In1 high and PWM (analogWrite) In2. When you want to reverse the direction set In1 low and PWM In2.
I think you may be right about that, i will try to implement your code
But for the record
The connections to the l298n is defined:
41 enables one H-bridge circuit on the board and 2-3 are the outputs which the PWM signals Should be sent to.
42 enables the second H-bridge circuit on the board, where 4-5 are the outputs with PWM.
This continues for 3 boards
I still have no Clue on how the lights Should be controlled, how i turn the on with the switch and handle the debounce, and still PWM the lights
