L298n questions
Questions on l298n motor driver. Set up is as follows:
2 motors with it's own 7.4 volt battery supply
2560 mega board powered by 9 volt battery or USB port
l298n has 5 led lights 1-- marked 5 volt and 4 marked L1--L2--L3--L4
On the back of it there is + terminal and - terminal that are hooked to the 7.4 battery plus one terminal marked 5 volt
On the front are 6 pins marked 5 volt--ground--IN1--IN2--IN3--IN4
Wire 5 volt pin on back to 5 volt pin on the 2560
wire from - terminal on back to grd on 2560
Wire on front 5 volt to 5 volt pin on 2560
GRN to GRN pin on 2560
IN1 to pin 5 on 2560
IN2 to pin 6 on 2560
IN3 to pin 9 on 2560
IN4 to pin 11 on 2560
When I first power up the 2560 the 5 volt led on the l298n comes on and stays on and the leds marked L1 to L4 flash and then go out.
I started by testing both motors by jumping on the terminal on the back of the l298n ( worked great)
Next I took a jumper wire from the 5 volt pin on the 2560 and touched each of the pins marked LN1 to LN4, as I touched each pin the led for that pin lighted up and the motor turned ( forward/back/left/right)
Next I unplugged ( 1 by 1) the wires from the 2560, when I pulled the wire from pin 5--6--9--11 the led on the l298n came on the the motor turned.
BUT no motor movement when I move the joystick.
I don't think is a programing problem. I went on the old stand by (youtube) and it appears that all of the leds should stay lit when powered up.
I'm I wrong/did I get a bad L298n/ did I short some thing out ????????????
In my opinion they are all bad. Ancient and inefficient wasters of power. Much better modern motor drivers are available. I like Pololu because the prices are reasonable and they have good instructional pages on the use of their products.
Did you program the Arduino to do anything?
If so, what?
Very very simple program, joystick up motors turn forward/joystick back goes backwards, I think it came from Dronebot workshop
So post the program then we can tell if that's not the problem. And post a link to the motor driver board you are using (there are many different ones) and a connection diagram so we know what we're dealing with.
Steve
What L298 module do you have?
A link to where you purchased it will help.
A picture of the module will help also.
Thanks... Tom... :slight_smile:
