L298N with Nano board, PWM is not working
I recently get started to learn basic stuff. I use a nano board and an L298N to explore a little DC motor control. I want to control the PWM and I'm so sure everything is connected correctly. but I got no luck the motor is not running at all. and so far I have done it, I used a MEGA2560 and It's working perfectly! My question is why the nano board is not working PWM on the L298N? I use 4 lithium battery and dc to dc to regulate the voltage at 12V.
UPDATE!! I just used a multimeter to measure the PWM pin of the nano board and I found it's changing!(the voltage is jumping up and down like this) But just wondering why it is not working.
Author  : Andrea Lombardo
Site    : https://www.lombardoandrea.com
Source  : https://github.com/AndreaLombardo/L298N/
Based on Arduino Basic Fade example.
Speed range go from 0 to 255, default is 100.
Use setSpeed(speed) to change.
Sometimes at lower speed motors seems not running.
It's normal, may depends by motor and power supply.
Wiring schema in file "L298N - Schema_with_EN_pin.png"
// Include the library
#include <L298N.h>
// Pin definition
const unsigned int IN1 = 7;
const unsigned int IN2 = 6;
const unsigned int EN = 10;
// Create one motor instance
L298N motor(EN, IN1, IN2);
int speedness = 0;
int speedAmount = 1;
  // Used to display information
  // Wait for Serial Monitor to be opened
  while (!Serial)
    //do nothing
  // Apply faded speed to both motors
  motor.setSpeed(speedness);
  // Tell motor A to go forward (may depend by your wiring)
  motor.forward();
  // Alternative method:
  // motor.run(L298N::FORWARD);
  //print the motor status in the serial monitor
  printSomeInfo();
  // Change the "speedness" for next time through the loop:
  speedness = speedness + speedAmount;
  // Reverse the direction of the fading at the ends of the fade:
  if (speedness <= 0 || speedness >= 255)
    speedAmount = -speedAmount;
  // Wait for 30 milliseconds to see the dimming effect
  delay(30);
Print some informations in Serial Monitor
void printSomeInfo()
  Serial.print("Motor is moving = ");
  Serial.print(motor.isMoving() ? "YES" : "NO");
  Serial.print(" at speed = ");
  Serial.println(motor.getSpeed());
Where is PWM in your schematic?
It's pin 10. the same code works just fine on a MEGA 2560
@tony-zh Installation and Troubleshooting is for Problems with the Arduino IDE itself NOT your project. It says so in the description of the section.
Therefore I have moved your post here. Please be more careful where you post in future.
You may want to read this before you proceed:-
how to get the best out of this forum
Thank you Grumpy. I'll pay attention to my future post.
Please include ALL hardware, component names and pin labels.
Have you got gnd of the Nano connected to gnd of the 298?
Tom... :smiley: :+1: :coffee: :australia:
HI,Tom. I did this drawing. hopefully it helps
Check with your DMM that IN1 and IN2 are working?
Without the library, you should be able to wire write some simple code to make the driver work.
Delete this and see what happens;
  while (!Serial)
    //do nothing
Thanks.. Tom... :smiley: :+1: :coffee: :australia:
Let me give it a try. :laughing:
I can't see in your picture - is ENA jumper set or no?
The En jumper is removed. I connect the pin to a nano pin 10 and got no luck. But it’s working on a mega2560 board. How? I also measured the pin10 and there’s jumping voltage up and down. That’s what its supposed to be. But why the L298 no any action with it. So weird.
I do not know the library but use pin 5 and 6 instead of 6 and 7.
Why? perhaps in1 needs to be a pwm able pin.
On a mega pin 6 and 7 are pwm able pins and with a nano is 7 not a pwm able pin
You mean I need use all PWM pins to the l298?
It depends on the library and as I said earlier I do not know that one.
If it works with all pwm, than you can search the one(s) thats neccesary
I actually didn’t use L298 library at very beginning as I tested very basic code . I still got no luck. But anyway I’ll keep trying tomorrow. Hopefully I could get it done. Thank you for your reply.
What about pins 6 and 7?
Tom.... :smiley: :+1: :coffee: :australia:
I tried also. No luck. And I’m gonna try it from pin d2 to d13. Hopefully I will figure it out soon. :joy:
Try this code, it compiles but is untested.
Look in the IDE serial monitor at 9600buad and see what it displays.
Your motor should stop, spin one way, stop, spin the otherway, etc etc.
// Pin definition
  Serial.println(" Motor Test Code  ");
  pinMode(EN, OUTPUT);
  pinMode(IN1, OUTPUT);
  pinMode(IN2, OUTPUT);
  digitalWrite(EN, LOW);
  digitalWrite(IN1, LOW);
  digitalWrite(IN2, LOW);
  Serial.println("Motor Stop");
  digitalWrite(EN, HIGH);
  digitalWrite(IN1, HIGH);
  Serial.println("Motor spins one way");
  digitalWrite(IN2, HIGH);
  Serial.println("Motor spins other way");
PS. I'm off to bed, its 1:45am here.. :sleeping: :sleeping: :sleeping: :sleeping: :sleeping:
Thanks mate! I’ll try it tomorrow.
the program from tom is for full trottle and with it you can check the basic functionality. After this you can expand the program with pwm but make sure you use analogwrite then
