Large, simple display for Mega
Hi all,
I am looking for a relatively large display, around 50x30cm, to be controlled by a Mega.
LED matrix, LCD, anything will do, I need to display simple characters and not much more. B/W is fine too. Size and brightness are the only important factors for this project.
But I cannot find anything bigger than a 30x16cm, 64x32 dot matrix.
Any idea?
Thanks!
You could search for "dot matrix display" on AliExpress,
Dot Matrix Display - Tools - Aliexpress - The best dot matrix display
and combine e.g. 3 of https://www.aliexpress.com/item/32810789401.html
This is the cheapest solution, I think.
For easy solution, you can chain six 8x32 ws2812 led matrix panels together just like led strips..
https://www.aliexpress.us/item/3256807032434058.html
Thanks!
Out of complete ignorance, how do you control something like this with the Arduino? I2C?
the MAX7219 is more or less SPI. You will find libraries for that, start with MD_MAX72XX .
HDMI display running on a Raspberry Pi Zero. Connect the Pi to the Mega over a serial port and send your data that way.
That's probably the easiest, and also least expensive way to do it.
With
around 50x30cm
Are there any inexpensive 24" HDMI displays? (~60cm / 2.56)
Nice idea. I guess you could skip Mega as well if resources of Pi Zero are sufficient for rest of the setup?
But 6x ws2812 panels make $30...
I've seen some on Aliexpress but the aspect ratio is kind of weird.
Hi all,
Thanks a lot for the feedback.
I'll give a shot to the 6x 8x32 ws2812, hopefully the Mega will manage. Otherwise I'll have to go with the Esp32 but my C is inexistent, so it will be steeper...
