blh64:
Here is a [untested] cleaned up version that removes so many of the if/else statements so it is a bit easier to follow
Wiring is simple on Wemos D1 R2
Just 4 connections:
5v -> 5v
Gnd -> Gnd
SCA -> SCA
SCL -> SCL
unsigned long curMillis;
unsigned long prevMillis = 0;
const unsigned long displayDuration = 10000UL;
const unsigned long displayBlankDuration = 500UL;
unsigned long prevFetchMillis = 0;
const unsigned long fetchDelay = 300000UL;
enum { INFO, INFECTED, DECEASED, REGION, INFECTED_REGION, DECEASED_REGION, LAST_STATE };
int displayState;
int infected;
int deceased;
int regionInfectedCount;
int regionDeceasedCount;
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#include <WiFiUdp.h>
#include <String.h>
#include <Wire.h>
#include <ArduinoJson.h>
#include <WiFiClientSecure.h>
#include <SSD1306.h>
#include <SSD1306Wire.h>
#include <NTPClient.h>
#include <Time.h>
#include <TimeLib.h>
#include <Timezone.h>
LiquidCrystal_I2C lcd(0x27, 16, 2); //or try 0x3f Create an instance of the lcd screen
// Define NTP properties
#define NTP_OFFSET 60 * 60 // In seconds
#define NTP_INTERVAL 60 * 1000 // In miliseconds
#define NTP_ADDRESS "pool.ntp.org" // change this to whatever pool is closest (see ntp.org)
// Set up the NTP UDP client
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP, NTP_ADDRESS, NTP_OFFSET, NTP_INTERVAL);
const char *ssid = "XXXX"; // insert your own ssid such as BTHub4-9X99
const char *password = "XXXX"; // and your wifi password
String date; //create the string for the date which will be printed on the lcd screen below
String t; // create the string for the time
const char *months[] = {"01", "02", "03", "04", "05", "06", "07", "08", "09", "10", "11", "12"};
//void welcome()
// lcd.setCursor(0, 0);
// lcd.print("Clock");
// lcd.setCursor(0, 1);
// lcd.print("COVID-19");
// delay(5000);
void clearLCDLine(int line)
lcd.setCursor(0, line);
for (int n = 0; n < 16; n++) // 20 indicates symbols in line. For 2x16 LCD write - 16
lcd.print(" ");
Serial.begin(115200); // most ESP-01's use 115200 but this could vary. Included for serial monitor debugging
timeClient.begin(); // Start the NTP UDP client
prevFetchMillis = millis() - fetchDelay; // so we fetch the first time through loop()
prevMillis = millis() - displayDuration;
///////////////////// The section below is to connect the esp8266 to your wifi
int cursorPosition = 0;
lcd.begin();
lcd.backlight();
Wire.begin();
lcd.print("Polacz");
lcd.print(ssid);
// Connect to wifi
Serial.println("");
Serial.print("Laczenie z ");
Serial.print(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
Serial.println("");
Serial.print("Polaczono z WiFi ");
Serial.print(WiFi.localIP());
Serial.println("");
///////////////////////|end wifi connection set up
//////////////////////// The first part of the loop is for the internet clock
curMillis = millis();
if (WiFi.status() == WL_CONNECTED) //Check WiFi connection status
refreshTime();
// Display the date and time
Serial.println("");
Serial.print("Local date: ");
Serial.print(date);
Serial.println("");
Serial.print("Local time: ");
Serial.print(t);
//lcd.clear();
lcd.print(t);
lcd.setCursor(6, 0);
lcd.print(date);
// check if it is time to refresh information
if (curMillis - prevFetchMillis >= fetchDelay)
fetchData();
prevFetchMillis = curMillis;
// check if it is time to blank the line to prepare for next state
if ((curMillis - prevMillis) >= displayDuration - displayBlankDuration)
clearLCDLine(1);
// check if it is time to display the next bit of information
if ( curMillis - prevMillis >= displayDuration )
// move to next display state
prevMillis = curMillis;
displayState++;
if(displayState == LAST_STATE) displayState = 0;
switch ( displayState ) {
case INFO:
lcd.print("Polska COVID-19");
case INFECTED:
lcd.print("Chorych:");
lcd.setCursor(9, 1);
lcd.print(infected, DEC);
case DECEASED:
lcd.print("Zgonow:");
lcd.setCursor(8, 1);
lcd.print(deceased, DEC);
case REGION:
lcd.print("WIELKOPOLSKIE");
case INFECTED_REGION:
lcd.print(regionInfectedCount, DEC);
case DECEASED_REGION:
lcd.print(regionDeceasedCount, DEC);
else // this part is a step to attempt to connect to wifi again if disconnected
lcd.clear();
//display.display();
//display.drawString(0, 24, "Connected.");
lcd.clear();
lcd.print("Polacz.");
delay(1000); //Send a request to update every 10 sec (= 10,000 ms)
} //end void loop
void refreshTime()
date = ""; // clear the variables
t = "";
// update the NTP client and get the UNIX UTC timestamp
timeClient.update();
unsigned long epochTime = timeClient.getEpochTime();
// convert received time stamp to time_t object
time_t local, utc;
utc = epochTime;
// Then convert the UTC UNIX timestamp to local time
//TimeChangeRule usEDT = {"EDT", Second, Sun, Mar, 2}; //UTC - 5 hours - change this as needed
// TimeChangeRule usEST = {"EST", First, Sun, Nov, 2, -60}; //UTC - 6 hours - change this as needed
// Timezone usEastern(usEDT, usEST);
// local = usEastern.toLocal(utc);
TimeChangeRule CEST = {"CEST", Last, Sun, Mar, 2, 60}; //Central European Summer Time
TimeChangeRule CET = {"CET ", Last, Sun, Oct, 3, 0}; //Central European Standard Time
Timezone CE(CEST, CET);
local = CE.toLocal(utc);
// now format the Time variables into strings with proper names for month, day etc
date += day(local);
date += ".";
date += months[month(local) - 1];
date += ".";
date += year(local);
// format the time to 12-hour format with AM/PM and add seconds. t (time) is made up of the variables below which are then printed as a string
if (hour(local) < 10)
t += " ";
t += hour(local);
t += ":";
if (minute(local) < 10) // add a zero if minute is under 10
t += "0";
t += minute(local);
// t += ":";
// if (second(local) < 10)
// t += "0";
// t += second(local);
//t += ampm[isPM(local)];
void fetchData()
HTTPClient http;
http.begin("http://api.apify.com/v2/key-value-stores/3Po6TV7wTht4vIEid/records/LATEST?disableRedirect=true");
int httpCode = http.GET();
if (httpCode > 0)
const size_t capacity = JSON_ARRAY_SIZE(16) + 16 * JSON_OBJECT_SIZE(3) + JSON_OBJECT_SIZE(6) + 1080;
DynamicJsonDocument doc(capacity);
deserializeJson(doc, http.getString());
JsonArray infectedByRegion = doc["infectedByRegion"];
// Parameters
infected = doc["infected"];
deceased = doc["deceased"];
JsonObject infectedByRegion_14 = infectedByRegion[14];
//const char *infectedByRegion_14_region = infectedByRegion_14["region"]; // "wielkopolskie"
regionInfectedCount = infectedByRegion_14["infectedCount"];
regionDeceasedCount = infectedByRegion_14["deceasedCount"];
http.end(); //Close connection
Thank you for your work! The program works as I wanted. Your code will help me learn programming. I will study it.
Now I'm thinking how to add an alarm buzzer. I was thinking about adding if infected! = Infected tone buzzer. It's a good idea? But where to implement the function
