LCD + battery connecting issue
Hello,
I am a beginner using Arduino and electronics. I am aware that the current running through the LCD in the backlight should not be more than 20mA, though when I try to connect backlight pin to the 5V port in the Arduino it does not run. When connecting backlight pin to top rail that has 9V battery running through, I use a resistor, when using a 350 Ohm resistor to top rail, to get to the 20mA, the LCD does show lettering.
though now I would have the 9V Battery running to the bottom rail. Is it okay to do it this way or will it overload the LCD? wo the 9V running to bottom rail, then the lcd has no power and wont run, though when connecting the lcd VCC to the 5v port and ground to ground on ariduno is does not get enough power. (ignore the temp sensor, im using it in place of a hall sensor that i have irl but not on tinkercad.. sensor works properly on real circuit)
I am just trying to get all my components to work together, and not overload the circuit.
Code
#include <LiquidCrystal.h> // Include the LiquidCrystal library for display control
const int fanPin = 9; // Define digital pin 9 for motor PWM control
const int hallPin = 2; // Define digital pin 2 for Hall sensor (Hardware Interrupt Pin)
const int buttonPin = A0; // Define analog pin A0 for the arcade button
LiquidCrystal lcd(11, 12, 6, 3, 4, 5); // Initialize LCD: RS(11), E(12), D4(6), D5(3), D6(4), D7(5) - Ports on Ardiuno Board
volatile int magnetCount = 0; // Initialize volatile integer to store lever arm passes over hall sensor / magnet passes (must be volatile for interrupts)
bool systemActive = false; // Initialize boolean to track system running state - Is it runnning currently
bool lastButtonState = HIGH;// Initialize state variable as HIGH (required for INPUT_PULLUP), low when pressed and high when released
unsigned long lastDebounceTime = 0; // Initialize timer for debouncing the button - Need this for making sure that the button clicked once, only tells program once, and not multiple times
const unsigned long debounceDelay = 50; // Set debounce delay constant to 50 milliseconds - wait 50ms then recheck if button is really clicked or not - need because button may register hundreds of rapid clicks
int motorSpeedPWM = 127; // Define PWM speed constant (127 is roughly 50% power - 255 is full power)
void setup() // Main setup function, runs once at startup
  lcd.begin(16, 2); // Initialize the 16x2 character LCD display
  pinMode(fanPin, OUTPUT); // Set the motor pin as an output
  pinMode(hallPin, INPUT_PULLUP); // Set Hall pin as input with internal pull-up resistor
  pinMode(buttonPin, INPUT_PULLUP); // Fixed syntax error: pinMode only accepts two arguments, configured with internal pull-up
  attachInterrupt(digitalPinToInterrupt(hallPin), countMagnet, FALLING); // Attach interrupt to pin 2 to trigger on falling edge
  lcd.print("Press to Start"); // Display initial startup text on LCD
} // End of setup function
void loop() // Main loop, runs repeatedly
  handleButton(); // Call the function to monitor button presses
  if (systemActive) // Check if the system is currently running
    lcd.setCursor(0, 0); // Set cursor to top-left
    lcd.print("Rotations: "); // Display count label
    lcd.print(magnetCount); // Display current magnet count value
    lcd.print("      "); // Clear remaining characters
    lcd.setCursor(0, 1); // Set cursor to bottom row
    lcd.print("System Running"); // Display status
  else // If system is not running
    lcd.print("Stopped        "); // Display status
  } // End of if-else check
} // End of loop
void countMagnet() // Interrupt Service Routine (ISR) to count pulses
  if (systemActive) // Only count pulses if the system is running
    magnetCount++; // Increment the global counter variable
  } // End of activation check
} // End of interrupt function
void handleButton() // Function to handle button logic and debouncing
  int reading = digitalRead(buttonPin); // Read the state of the button on pin A0
  if (reading != lastButtonState) // Check if the button state has changed
    lastDebounceTime = millis(); // Reset the debounce timer
  } // End of state change check
  if ((millis() - lastDebounceTime) > debounceDelay) // Check if sufficient time has passed for debounce
    if (reading == LOW) // If reading is LOW, the button is pressed (ACTIVE LOW)
      if (systemActive) // If the system is currently running
        systemActive = false; // Set state to false
        analogWrite(fanPin, 0); // Turn off the motor
        lcd.clear(); // Clear the LCD screen
        lcd.print("Restarting."); // Display status
        delay(1000); // Wait 1 second
        lcd.clear(); // Clear the screen
      else // If system is currently stopped
        magnetCount = 0; // Reset magnet count to 0
        systemActive = true; // Set state to true
        analogWrite(fanPin, motorSpeedPWM); // Turn on the motor
        lcd.print("Starting..."); // Display status
        delay(500); // Wait 0.5 seconds
      } // End of active state logic
    } // End of low read logic
  } // End of debounce timing check
  lastButtonState = reading; // Update the last button state for the next loop
} // End
Welcome
The 20 mA rating normally applies only to the LCD backlight LED, not to the complete LCD module.
The LCD logic should normally be connected directly to the Arduino 5 V and GND pins. Do not power the LCD module from 12 V through a resistor. Applying 12 V to the LCD supply or signal pins can damage both the LCD and the Arduino.
If connecting the LCD to 5 V causes a short circuit, stop applying power. Either the LCD is wired incorrectly, the breadboard rails are not what you think they are, or the LCD may already be damaged.
Post an annotated schematic showing every connection, the exact LCD part number or module type, and the measured resistance between its VCC and GND pins with power disconnected. A picture of the breadboard alone is not enough to determine what is connected.
It is possible the LCD is usable but be 100% sure the wiring is correct.
Then your LCD module does not have a builtin resistor. Try connecting to 5V through a 200 ohm resistor.
If your diagram is accurate, it would appear that you are supplying 9V to the LCD's Vdd and Vo pins. If that is true, good-bye LCD.
It seems like connecting the LCD to power via the 5v port is working. It seems okay to do it this way?
See post #3
