LCD l2c have some voltage problem
The problem I have with LCD l2c screen when connected to an arduino and a button is that when the screen is connected to pin 13 and I run the code. I press the button and nothing happends... I change pin 13 to pin 5V and press the button it shows "PRESSED" and i change back to pin 13 then it turn on and off the screen but no text is displayed.
I think it is some voltage problem but i do not know what to change. This is how it is connected now.
IMG_0537
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 20, 4);  // set the LCD address to 0x27
const int buttonPin = A1;
int lastButtonState;
void testButton() {
  int currentButtonState = digitalRead(buttonPin);
  if ((currentButtonState == LOW) && (lastButtonState == HIGH)) {
    digitalWrite(LED_BUILTIN, HIGH);
    lcd.print(F("PRESSED"));
    delay(15); // poor's man anti-bounce
  } else if ((currentButtonState == HIGH) && (lastButtonState == LOW)) {
    digitalWrite(LED_BUILTIN, LOW);
  lastButtonState = currentButtonState;
  pinMode(LED_BUILTIN, OUTPUT);
  pinMode(buttonPin, INPUT_PULLUP);
  // initialize the lcd
  lcd.init();
  lcd.backlight();
    lcd.setCursor(0, 0);
  lastButtonState = digitalRead(buttonPin);
  testButton();
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advice on) your project :wink: See About the Installation & Troubleshooting category.
You might need to add some delay after writing pin13 to HIGH so that the LCD display will become stable after which you can print anything on the LCD. I have seen that in the code there is no delay after enabling pin13.
Regards,
I wonder if the display is still initialised after it was power cycled. Maybe a new lcd.begin() is needed before printing.
You will also have to do a current measurement to find out how much current your display draws; it might be too much for an Arduino pin.
