Hello guys
I'm working on a project where I use an LCD to display menu and submenu with 3 push buttons (up, down and select) the buttons work on the menu so well but they are not functional on submenu (can't scroll up and down)
I hope someone could help me on this because I really need that and thank u.
Did you forget something?
Yeah it must be something
Would u be able to help me if I shared the code with you?
It'll be impossible if you don't.
Can I get ur email so I can share it with you
Certainly not.
Then can u tell me how to share it here
Cuz I'm new and don't know how to do that here
Are you for real?
Start here
#include <LiquidCrystal.h>
#include<Wire.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int page_counter=1 ; //To move beetwen items of main menu
int subpage_counter=0; //To move between items of submenu 1
int subpage2_counter=0; //To move between items of submenu 2
int upButton = 8;
int downButton = 9;
int selectButton = 10;
boolean current_up = LOW;
boolean last_up=LOW;
boolean current_sel = LOW;
boolean last_sel = LOW;
boolean last_down = LOW;
boolean current_down = LOW;
byte heart[8] = {
0b00000,
0b00000,
0b01010,
0b11111,
0b01110,
0b00100,
0b00000,
0b00000
byte arrow[8] = {
0b00000,
0b00100,
0b00110,
0b11111,
0b00110,
0b00100,
0b00000,
0b00000
pinMode(upButton,INPUT_PULLUP);
pinMode(downButton,INPUT_PULLUP);
pinMode(selectButton,INPUT_PULLUP);
lcd.begin(16,2);
lcd.createChar(1, heart);
lcd.createChar(2, arrow);
//---- De-bouncing function for all buttons----//
boolean debounce(boolean last, int pin)
boolean current = digitalRead(pin);
if (last != current)
delay(5);
return current;
current_up = debounce(last_up, upButton); //Debounce for Up button
current_sel = debounce(last_sel, selectButton); //Debounce for Select button
current_down = debounce(last_down, downButton); //Debounce for Down button
if(subpage_counter==0 && subpage2_counter==0){
if (last_down== LOW && current_down == HIGH){
lcd.clear();
if(page_counter <2){
page_counter= page_counter +1;
else{
page_counter= 1;
last_down = current_down; //Save down button last state
if (last_up== LOW && current_up == HIGH){
lcd.clear();
if(page_counter >1){
page_counter= page_counter -1;
else{
page_counter= 2;
last_up = current_up;
switch (page_counter) {
case 1: { //Design of page 1
lcd.setCursor(0,0);
lcd.write(byte(2));
lcd.setCursor(1,0);
lcd.print("heart");
lcd.setCursor(1,1);
lcd.print("lung");
if (last_sel== LOW && current_sel == HIGH){ //select button pressed
subpage_counter=1;
if(subpage_counter==1){
page_counter=0;
lcd.setCursor(0,0);
lcd.write(byte(2));
lcd.setCursor(1,0);
lcd.print("disease1");
lcd.setCursor(1,1);
lcd.print("disease2");
Serial.println(page_counter);
lcd.clear();
if(subpage_counter <2){
subpage_counter= subpage_counter +1;
else{
subpage_counter= 1;
Serial.println(subpage_counter);
if(subpage_counter==2){
lcd.setCursor(1,0);
lcd.setCursor(0,1);
lcd.write(byte(2));
lcd.setCursor(1,1);
last_sel=current_sel; //Save last state of select button
case 2: { //Design of page 2
lcd.setCursor(1,0);
lcd.print("heart");
lcd.setCursor(0,1);
lcd.write(byte(2));
lcd.setCursor(1,1);
lcd.print("lung");
}//switch end
Someone help please
Post the sketch in code tags "</>".
Thank you but this is not the problem I have problem with the code can u help me with that?
You just set it to one . . . and then you test to see if it is one?
Do u suggest any solution
Cuz all I want is to pass to the submenu with all the buttons being functional
The select button should pass me to the submenu and eliminate the main menu but if I set the page_counter to 0 the buttons will be disabled.
I couldn't find any solution
And thanks for ur time I really appreciate that
Hello amal18
I did a little code review.
Do not use magic numbers. C++ provides the enum statement to create names for cases easily. The swich/case statement can be used nested.
All in all, take some time, study the IPO model, take a piece of paper and a pencil and make a re-design. There is no other way to untie the knot.
You may design objects for the LCD and for other common things.
I'd start by using the IDE's auto-format tool to make the structure clearer.
Maybe some comments...
Maybe revise your understanding of the values a bool can take.
a few suggestions
- separate recognizing a button press rom the code using and determining what to do
- four buttons are commonly used with a menu: up and down buttons to scroll thru a set of menus at some level, select button to select the menu item or sub-menu and a 4th to go up to the next higher menu level (
enum { Bnul, Bup, Bdown, Bsel, Bmenu };) - use a switch statement to determine what to do for each of the four buttons
- use a tables and sub-tables to manage you menus, possibly identifying a menu item by type: maintaining some value, variable, or performing some action, function pointer
- maintain a stack (i.e. array) to track menu levels
...or if you structure your code to match your menu structure, you get your stack for free.
