Lcd not showing blink values
Hello,
I have a problem in which my lcd display does not blink the cursor according to potientiometer movement. I have made a menu. Code Attatched here :-
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
int potPin1 = A1;
int potPin2 = A2;
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  analogWrite(3, 10);
  lcdf();
  int j1 = map(potPin1, 0, 1023, 1, 5);
  if (j1 = 2) {
    lcd.setCursor(5, 0);
    lcd.blink();
  if (j1 = 3) {
    lcd.setCursor(13, 0);
    lcd.blink();
  if (j1 = 4) {
    lcd.setCursor(5, 1);
    lcd.blink();
  if (j1 = 5) {
    lcd.setCursor(13, 1);
    lcd.blink();
void lcdf() {
  lcd.setCursor(0, 0);
  lcd.print("Vol+    Vol-");
  lcd.setCursor(0, 1);
  lcd.print("LED+    LED-");
pls check it and see if i have missed anything
very thanks,
Abeer
Oops (times four)
meaning?
it shows the places where the blink should be but it is on all 4 places. sorry if it's a dumb mistake as i am only a child
Meaning that you do not use a single equals sign to carry out a comparison
ohhh......i forgot as i dont do much coding nowadays
have another prob
it is not blinking....here is my updated code
int potPin1 = A1;
int potPin2 = A2;
  lcd.begin(16, 2);
  analogWrite(3, 10);
  lcdf();
  if (j1 == 2) {
    lcd.blink();
  if (j1 == 3) {
    lcd.blink();
  if (j1 == 4) {
    lcd.blink();
  if (j1 == 5) {
    lcd.blink();
void lcdf() {
pls help
What do you think that lcd.blink() does ?
it blinks the cursor i think?
Have you read
"Display the blinking LCD cursor. If used in combination with the cursor() function, the result will depend on the particular display."
in LiquidCrystal - Arduino Reference
Exactly which display do you have ?
You have a setCursor(), but not "cursor()"
16 by 2 white text on blue
Read this very carefully
Does your code use the cursor() function ?
So go study, and leave the hobby electronics for later.
Learn to prioritise.
um.....no.....
ok....i meant that my listening test is coming up
Did you read the quoted text carefully as I suggested ?
