LCD problem+video+code
Hello,
since 3 weeks ive been trying desperately to make my lcd run...
I try to realize a menu to monitor current position of a stepper and to enter/calibrate positions for auto drive.
The LCD crashes at some point and shows weird characters as seen in the video:
The first state of the display shows the main loop.
From there i call a function for menu and from there a second function for the calibration value input (where the error occurs).
Here the code, just before the function wich leads to the error is called:
case 1:
        lcd.clear();
        lcd.setCursor(0,0);
        lcd.print("Menu:");
        lcd.setCursor(0,1);
        lcd.print("2: Calibrate pos.?");
        delay(100);
        if(digitalRead(enterSwitchPin)==HIGH){
        steps=manualPosition();
and code from manualPosition(); function where the error occurs:
long manualPosition(){
  delay(200);
 lcd.clear();
  int stelle=0;
  int stelle0Value=0;
  int stelle1Value=0;
  int stelle2Value=0;
  int stelle3Value=0;
   lcd.print("TESTESTEST");
  delay(200);
long totalsteps=0;
    while(stelle==0){
      delay(200);
    speedpotiValue=analogRead(speedPotiPin);
     if(speedpotiValue<=100){
          lcd.setCursor(0,0);
          lcd.print("Enter Position:");
          lcd.setCursor(0,1);
            lcd.print("0x.xx cm");
      Serial.print("Pos 0x.xxcm\n");
      stelle0Value=0;
    if(speedpotiValue>100 && speedpotiValue<=200){
            lcd.setCursor(0,0);
          lcd.setCursor(0,1);
            lcd.print("1x.xx cm");
            Serial.print("Pos 1x.xxcm\n");
            stelle0Value=1;
     if(speedpotiValue>200 && speedpotiValue<=300){
       lcd.setCursor(0,0);
          lcd.setCursor(0,1);
            lcd.print("2x.xx cm");
            Serial.print("Pos 2x.xxcm\n");
            stelle0Value=2;
there follow many speedpoti value if conditions to check the value for calibration.
but it doesnt matter since lcd.print("TESTESTEST"); doesnt even work.
i need advice, please help me somehow
Have you considered turning your phone 90 degrees when you take your videos?
You really should show all of the code.
You should also show an in-focus picture of your entire setup.
Right now we have no idea which Arduino pins you are using for your display. For example if you are using pin 1 then the serial.print() can affect your LCD.
Don
#include <LiquidCrystal.h>
LiquidCrystal lcd(9,8,7,6,5,4);
const int cwccwSwitchPin=49;
const int clockSwitchPin=47;
const int enableSwitchPin=51;
const int speedPotiPin=A0;
const int menuSwitchPin=53;
const int enterSwitchPin=45;
const int backSwitchPin=43;
const int cwccwPin=12;
const int clockPin=13;
const int enablePin=11;
const int testPin=10;
long manualposValue=0;
int manualPositionValue=0;
int enterSwitchpinState=0;
int backSwitchPinState=0;
 int cwccwSwitchPinState=0;
 int clockSwitchPinState=0;
// int halffullSwitchPinState=0;
 int enableSwitchPinState=0;
 int prevcwccwSwitchPinState=0;
 int prevclockSwitchPinState=0;
 //int prevhalffullSwitchPinState=0;
 int prevenableSwitchPinState=0;
 int menuSwitchPinState=0;
 long steps=0;
 double manipulatortransmissionratio=0.005;
double translationdistance=0;
int x=0,y=0,z=0;
int richtung=0;
int schritt=0;
int schrittweite=0;
int enable=0;
int speedpotiValue=0;
void setup(){
lcd.begin(16,2);
lcd.clear();
  pinMode(menuSwitchPin,INPUT);
  pinMode(cwccwSwitchPin,INPUT);
  pinMode(clockSwitchPin,INPUT);
  //pinMode(halffullSwitchPin,INPUT);
  pinMode(enableSwitchPin,INPUT);
  pinMode(cwccwPin,OUTPUT);
  pinMode(clockPin,OUTPUT);
  //pinMode(halffullPin,OUTPUT);
  pinMode(enablePin,OUTPUT);
void loop(){
 //************MENU****
Serial.print("welcome to main loop\n");
lcd.setCursor(0,0);
lcd.print("Man. drive ");
if(richtung==0){            //direcLED aus aus=kammer raus =mehr skala=+1
  lcd.print("backw.");
  else{                          //direcLED an=kammer rein=weniger skala=-1
  lcd.print("forw.");
lcd.setCursor(0,1);
    lcd.print((steps*manipulatortransmissionratio)/10);
   lcd.print("cm");
 menuSwitchPinState=digitalRead(menuSwitchPin);
 if( menuSwitchPinState==1){
 mainMenu();
     Serial.print("lol");
  if(enable==1){  /
    digitalWrite(enablePin,HIGH);
    clockSwitchPinState=digitalRead(clockSwitchPin);
  //Serial.println(clockSwitchPinState);
  while(clockSwitchPinState==HIGH){
  clockSwitchPinState=manualDrive(clockSwitchPinState);
      analogWrite(clockPin,0);
  else{
   digitalWrite(enablePin,LOW);
  prevenableSwitchPinState=enableSwitchPinState;
//******manualDrive*******
int manualDrive(int x){
  if(speedpotiValue<300){
  digitalWrite(clockPin,HIGH);
  delay(100);
  digitalWrite(clockPin,LOW);
  Serial.print("min");
  x=digitalRead(clockSwitchPin);
  if(speedpotiValue>=300 && speedpotiValue<650){
  delayMicroseconds(100);
  Serial.print("med");
  if(speedpotiValue>=650){
  delayMicroseconds(1);
  Serial.print("max");
  if(richtung==0){            /
   // lcd.setCursor(0,1);
    steps+=1;
    //lcd.print((steps*manipulatortransmissionratio)/10);
    //lcd.print("cm");
  else{                          //direcLED an=kammer rein=weniger skala=-1 ,Zählt steps richtig rum
    //lcd.setCursor(0,1);
    steps-=1;
    //lcd.print("cm");
   lcd.print("                              ");
  lcd.setCursor(0,1);
  Serial.print((steps*manipulatortransmissionratio)/10);
    Serial.print("\n");
  return x;
//*********manualDirection*************
void manualDirection(){
        richtung=!richtung;
     delay(200);
  if(richtung==1){
  digitalWrite(cwccwPin,HIGH);
  else{
   digitalWrite(cwccwPin,LOW);
    return;
[color=red]//******************mainMenu*************[/color]
void mainMenu(){
  delay(100);
  while(backSwitchPinState==0){
   switch(menuSwitchPinState){
    case 0:
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("Menu:");
    lcd.setCursor(0,1);
    lcd.print("1: Drive to pos.?");
    Serial.print("manualDriveto\n");
      delay(100);
        manualposValue=manualPosition();
        Serial.print(manualposValue);
        Serial.print("vorautodrive\n");
        delay(2200);
        steps=autoDrive(manualposValue,steps);
        Serial.print("nachautodrive\n");
        delay(2200);
      if(digitalRead(menuSwitchPin)==HIGH){
       menuSwitchPinState+=1;
       if(digitalRead(backSwitchPin)==HIGH){
       backSwitchPinState=1;
    case 1:
        lcd.clear();
        lcd.setCursor(0,0);
        lcd.print("Menu:");
        lcd.setCursor(0,1);
       Serial.print("Calibrate\n");
        delay(100);
     [color=red]   steps=manualPosition();[/color]
        Serial.print(steps);
                Serial.print("steps nach steps=manualpos in case 1 hauptmenü\n");
        delay(2200);
    case 2:
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print("Menu:");
      lcd.setCursor(0,1);
      lcd.print("33: Drive to Pos?");
       Serial.print("menu2\n");
       delay(100);
    case 3:
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print("Menu:");
      lcd.setCursor(0,1);
      lcd.print("444: Drive to Pos?");
       Serial.print("menu3\n");
       delay(100);
  //Serial.print("lol");
 return;
[color=red]//*********manualPosition******
long manualPosition(){[/color]
  delay(200);
  lcd.clear();
  int stelle=0;
  int stelle0Value=0;
  int stelle1Value=0;
  int stelle2Value=0;
  int stelle3Value=0;
   lcd.print("umbrellaella");
  delay(2000);
long totalsteps=0;
    while(stelle==0){
      delay(200);
          lcd.setCursor(0,0);
          lcd.setCursor(0,1);
      stelle0Value=0;
            lcd.setCursor(0,0);
          lcd.setCursor(0,1);
            stelle0Value=1;
       lcd.setCursor(0,0);
          lcd.setCursor(0,1);
            stelle0Value=2;
   totalsteps=stelle0Value;
    totalsteps*=20000;
    totalsteps=totalsteps+(stelle1Value*1000 + stelle2Value*100 + stelle3Value*10)*2;
    Serial.print(totalsteps);
    Serial.print(" totalsteps ohne variablen\n");
  delay(2000);
    lcd.clear();
    delay(200);
 return totalsteps;
Heres the code. I still had to cut it because it exceeded 9500 chars.
LCD is a KS0066/hitachi kompatible one.
i connected pins like this:
1:gnd
2:+vcc
3:10k poti
4: pin 9 (arduino mega 2560)
5:gnd
6:pin 8
7:-
8:-
9:-
10:-
11:pin 7
12:pin 6
13:pin 5
14:pin 4
15:-
16:-
Okay i found the root of the Problem: i used too low pulldown Resistor for an Input switch. The LCD tilted because of that.
