LCD screen code implementation
I made the code for the program of the safe lock with the help of people from this forum. But I want to add the information, which display during the skanning the tag or closing the door. So, I try to do on my own.
However, when I start the program everything is ok, the LCD screen displays "Hello! SCAN Your Tag!", but when I scan the tags there is something like "Hel &**%#( SCAN Your Tag!" instead of "Authorized access". Why this is happening? How I should implement these function on the bottom of the code.
Thank You for Help.
Here is the code:
#include <LiquidCrystal.h>
const int rs = 5, en = 4, d4 = 3, d5 = 2, d6 = 1, d7 = 0;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
//LiBRARES
#include <SPI.h>
#include <MFRC522.h>
#include <Servo.h>
// DEFINED PINS
#define SS_PIN 10
#define RST_PIN 9
#define trigPin 7
#define echoPin 6
//ASSIGNING THE VARIABLE VALUES OF THE FUNCTION
boolean doorLocked = true;
boolean tagRead = false;
String content= "";
MFRC522 mfrc522(SS_PIN, RST_PIN); //
Servo myServo;                    //
void setup(){
  lcd.begin(16, 2);
  lcd.print("     Hello!");
  lcd.setCursor(0, 1);
  lcd.print(" SCAN Your Tag!");
  Serial.begin(9600);          //
  SPI.begin();                 //
  mfrc522.PCD_Init();          //
  myServo.attach(8);           // Servo attached to PIN 8
  lockDoor();                  // Function, which locks the door, when the system starts
  pinMode(trigPin, OUTPUT);    // Mode of TrigPIN of ultrasonic sesnor
  pinMode(echoPin, INPUT);     // Mode of EchoPIN of ultrasonic sesnor
   int doorClosedDistance = 4;         //Border distance 4cm
   int distanceToDoor = getDistance(); // disranceToDoor is equal to the function getDistance
   readTag();  //Function, which reads the tag
   if(distanceToDoor < doorClosedDistance)  // If distance to door is less than doorClosedDistance, then the door are locked
      if(!doorLocked)
         lockDoor();
         doorLocked = true;  //Variable, which is set after locking the door
   if(tagRead) // If tag is read, then there is a function, which check this tag and If the tag is proper, the function opens the door
      if(checkTag())
         openDoor();
         doorLocked = false; //Variable, which is set after opening the door
      tagRead = false; //Variable, which is set after this whole action above, to reset
int getDistance()  //Function, which read, what is the distance from ultrasonic sensor
  digitalWrite(trigPin, LOW);
  delayMicroseconds(5);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  unsigned long duration = pulseIn(echoPin, HIGH);
  int cm = (duration/2) / 29.1;
  return cm;
void openDoor() //Function, which opens the door
    myServo.write(180);
    delay(5000);
void lockDoor() //Function, which closes the door
    myServo.write(0);
bool checkTag() //Function, which checks the tag
  boolean goodTag = false;
  if (content.substring(1) == "F2 00 7C 1B")
    printAuthorizedAccess();
    goodTag = true;
    printAccessDenied();
    goodTag = false;
  content="";
  tagRead = false;
  return goodTag;
  printNormalMessage();
void readTag() // Function, which read the tag
 if (mfrc522.PICC_IsNewCardPresent())
   if (mfrc522.PICC_ReadCardSerial())
      for (byte i = 0; i < mfrc522.uid.size; i++)
        Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
        Serial.print(mfrc522.uid.uidByte[i], HEX);
        content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
        content.concat(String(mfrc522.uid.uidByte[i], HEX));
        tagRead=true;
   content.toUpperCase();
void printAuthorizedAccess() {
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print("Authorized access");
void printAccessDenied() {
  lcd.clear();
  lcd.print("Access denied");
void printNormalMessage() {
  lcd.clear();
  lcd.print("-Lock System On-");
  lcd.print("    SCAN NOW");
Model of LCD screen:
2x16 LCD display with blue backlight
Model 1170
Driver S6A0069
Which type arduino are you using? It appears you are using digital pins 0 and 1 for the LCD display, those pins are used on several arduino's for the serial monitor, and since you are using serial cannot be used for anything else at the same time.
I use Arduino Uno. I check if it is everything connected properly. I use for example "Hello World" and everything was ok.
So, you mean, that I shouldn't use pin 0 and 1? I will have a problem, because I have got only one free pin :confused: Pin 13
Are you using the analog inputs. Those pins are digital as well. They are numbered 14 (A0), 15 (A1),..., 19 (A5).
I did't know that, Thank You!!
