LCD Screen is not showing characters
  1. I’m using the lc1602 display. https://www.waveshare.com/datasheet/LCD_en_PDF/LCD1602.pdf
  2. I’m using the code from the hello word example but I have commented out the lines about the printing in void loop to troubleshoot. What I'm following.
  LiquidCrystal Library - Hello World
 Demonstrates the use a 16x2 LCD display.  The LiquidCrystal
 library works with all LCD displays that are compatible with the
 Hitachi HD44780 driver. There are many of them out there, and you
 can usually tell them by the 16-pin interface.
 This sketch prints "Hello World!" to the LCD
 and shows the time.
  The circuit:
 * LCD RS pin to digital pin 12
 * LCD Enable pin to digital pin 11
 * LCD D4 pin to digital pin 5
 * LCD D5 pin to digital pin 4
 * LCD D6 pin to digital pin 3
 * LCD D7 pin to digital pin 2
 * LCD R/W pin to ground
 * LCD VSS pin to ground
 * LCD VCC pin to 5V
 * 10K resistor:
 * ends to +5V and ground
 * wiper to LCD VO pin (pin 3)
 Library originally added 18 Apr 2008
 by David A. Mellis
 library modified 5 Jul 2009
 by Limor Fried (http://www.ladyada.net)
 example added 9 Jul 2009
 by Tom Igoe
 modified 22 Nov 2010
 by Tom Igoe
 modified 7 Nov 2016
 by Arturo Guadalupi
 This example code is in the public domain.
 https://docs.arduino.cc/learn/electronics/lcd-displays
// include the library code:
#include <LiquidCrystal.h>
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("hello, world!");
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  //lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  //lcd.print(millis() / 1000);
  1. I’m using the wiring shown in this picture but my potentiometer is not connected to +5v (when I connect it something goes wrong and I can’t control the contrast)
I’m sorry if my wiring is too messy.
  1. I’m currently just trying to print “Hello World”. When I play with potentiometer I go from seeing nothing to seeing only boxes. At no point do I see any text.
I’m sharing a link to a video where I show that. It will probably be down in 2 days so sorry for that. Watch PXL_20251031_180535595 | Streamable
Additional Question:
I have an hd44780 lcd display too. Is there some good tutorial you would recommend I follow for this particular display?
Well, you might begin by figuring out why that is.
I'm afraid I can't tell anything from that mess of wires. And you probably can't either. Taking a bit of time and making neat wiring so you can follow where the wires go makes figuring problems out much easier. Compare your pictures to the one below to see what I mean.
  • Difficult to follow the spaghetti wiring.
  • I am always suspicious of the non DuPont jumper wires, i.e. the ones with round housings, replace them one at a time in case one is bad.
  • @van_der_decken wire image is what you should strive for.
Pot may need to be connected as a variable resistor instead of potentiometer, post datasheet.
That’s the sheet https://components101.com/sites/default/files/component_datasheet/potentiometer%20datasheet.pdf
It is in fact a variable resistor - B10k.
What changes in the wiring?
Fair enough. I read in another post that might be better to do it that way because you have more control over the contrast.
I will try to fix the wiring and report back tomorrow.
OOPS! Should have said:
Post datasheet for display.
Datasheet was added the original post
I won’t have much time today to fix the wiring, I’ll report back for that
I agree with the others about your spaghetti wiring and use of unreliable Dupont connectors. But at least you are sensibly using a Nano, plugged into the breadboard (rather than, for example, Uno), and you have soldered pin headers to the display so that this can also be connected to the breadboard.
It looks like your pot has a metal shaft. This will be connected to the wiper physically and maybe also electrically. It looks like it could be touching the mounting holes on the display, which have copper pads around them which are probably connected to the ground pin. This may cause a short which is preventing you adjusting the contrast, and may also explain the problems when you connect the pot to 5V.
The LCD display in your photos is also 99.9% certainly an hd44780. Almost all 16x2 LCD displays use this driver chip.
