Lcd screen provides no output with my countdown timer function
I created a countdown timer function(s) for my arduino clock. After setting the countdown time, on activating the timer, the lcd screen just keeps blinking indefinitely with very low contrast. I think I made a mistake in the logic. Here is my code with all the unnecessary bits removed:
int timerH = 0, timerM = 0, timerS = 0;
int scroll = 1;
boolean timerActivate = false;
if (digitalRead(btnMode) == LOW) {
    digitalWrite(buzzer, LOW);
    delay(50);
    digitalWrite(buzzer, HIGH);
    mode++;
    if (mode == 6) {
      mode = 1;
    //The delays after every submode serves a purpose. If you remove them the modes changes very quickly while pressing the mode button
    //which makes it difficult to navigate to the desired mode
    submode = 0;
    lcd.clear();
    delay(100);
  switch (mode) {
    case 1:
      clockDisplay();
    case 2:
      weatherMode();
      delay(100);
    case 3:
      alarmMode();
      delay(100);
    case 4:
      timerInterface();
      timer();
      delay(100);
    case 5:
      updateRTC();
      delay(100);
    default:
boolean alarm(char alarmOrTimer) {
  if (alarmOrTimer == 'a')
    clockDisplay();
  else if (alarmOrTimer == 't') {
    lcd.clear();
    lcd.setCursor(4, 0);
    if (timerH < 10)
      lcd.print("0");
    lcd.print(timerH);
    lcd.print(":");
    if (timerM < 10)
      lcd.print("0");
    lcd.print(timerM);
    lcd.print(":");
    if (timerS < 10)
      lcd.print("0");
    lcd.print(timerS);
  for (int i = 0; i < 60; i++) {
    if (digitalRead(btnMode) == LOW || digitalRead(btnChange) == LOW || digitalRead(btnOK) == LOW || digitalRead(ir) == LOW)
      return true;
    lcd.noBacklight();
    delay(200);
    lcd.backlight();
    delay(200);
    lcd.noBacklight();
    delay(200);
    lcd.backlight();
    delay(400);
      return true;
void timerInterface() {
  if (timerActivate == false) {
    lcd.setCursor(0, 0);
    lcd.write(7);
    lcd.setCursor(2, 0);
    lcd.print("Set ||");
    lcd.setCursor(0, 1);
    lcd.print("Timer ||");
    lcd.setCursor(8, 1);
    //timer hour
    if (timerH < 10) {
      lcd.print("0");
      lcd.setCursor(9, 1);
    lcd.print(timerH);
    //timer minutes
    lcd.setCursor(10, 1);
    lcd.print(":");
    lcd.setCursor(11, 1);
    if (timerM < 10) {
      lcd.print("0");
      lcd.setCursor(12, 1);
    lcd.print(timerM);
    //timer seconds
    lcd.print(":");
    lcd.setCursor(14, 1);
    if (timerS < 10) {
      lcd.print("0");
      lcd.setCursor(15, 1);
    lcd.print(timerS);
    if (digitalRead(btnOK) == LOW) {
      scroll++;
      if (scroll > 5)
        scroll = 1;
      delay(100);
      lcd.clear();
    if (scroll == 1) {
      lcd.setCursor(8, 0);
      lcd.write(6);
      lcd.write(6);
      if (digitalRead(btnChange) == LOW) {
        timerH++;
        if (timerH > 24)
          timerH = 0;
        delay(200);
    if (scroll == 2) {
      lcd.setCursor(11, 0);
      lcd.write(6);
      lcd.write(6);
        timerM++;
        if (timerM > 59)
          timerH = 0;
        delay(200);
    if (scroll == 3) {
      lcd.setCursor(14, 0);
      lcd.write(6);
      lcd.write(6);
        timerS++;
        if (timerS > 59)
          timerS = 0;
        delay(200);
    if (scroll == 4) {
      lcd.clear();
      lcd.home();
      if (timerH == 0 && timerM == 0 && timerS == 0) {
        timerH = 23;
        timerM = 59;
        timerS = 59;
        lcd.print("Starting timer....");
        //delay(500);
        //lcd.clear();
        timerActivate = true;
void timer() {
  if (timerActivate == true) {
    lcd.clear();
    lcd.write(7);
    myRTC.updateTime();
    static uint8_t last_second = 0;
    if (last_second != myRTC.seconds) {
      last_second = myRTC.seconds;
      if (timerS < 0) {
        timerS = 59;
        timerM--;
      timerS--;
      if (timerM < 0) {
        timerM = 59;
        timerH--;
      if (timerH < 10)
        lcd.print("0");
      lcd.print(timerH);
      lcd.print(":");
      if (timerM < 10)
        lcd.print("0");
      lcd.print(timerM);
      lcd.print(":");
      if (timerS < 10)
        lcd.print("0");
      lcd.print(timerS);
        alarm('t');
I have added a google drive link to the video in case anyone is interested.
Link to video
Wrong decision. Please post the full code; replace irrelevant functions by empty functions (if so desired) for posting here.
I guess the timer() function gives the problem. That is because you constantly clear and update the display. Only clear/update when needed.
I previously tried removing the lcd.clear(); at the beginning of the timer() but didn't solve the issue.
Here's the full code:
//v3.7 brings the addition of a DH11 sensor module, which will output the temp and humidity.
//3.8-4.9 were failed attempts at making a special character font clock.
//v5.0 adds the BMP180 atm pressure and temp sensor
//Replaced dht11 temp readings with BMP180, as it is more accurate
//v5.1 removes 2 unrequired variables
//v5.2 adds switch case for the mode selectors and removes unnecessary brackets from if else statements
//v5.5 brings a new weather mode, giving all details about the current weather. also changes the temp, humidity and pressure readings a bit.
//removed some unused special characters, added some more like rain, sunny, clear. will display these characters if the weather is right.
//v5.6 tests out the hd44780 library
//the new hd44780 library works wonders. changed the layout of the clock face.
//v5.7 finally is capable of deactivating the alarm. Also shows if any alarms are active or not in the home face.
//rearranged the temp and humidity readings. fixed the avg pressure issue. increased time of ir detection to save bit more power.
//if humidity > 90% then it will show rain drops
//v5.8: 1)reduce delay times. 2)change pressure average timing
//v5.9: 1)removed boolean backlight() func. 2)changed the average logic by using weighted averages
//v6.0: 1)remove unwanted processing 2)improved the accuracy of the averagePressure part. 3) timer
#include <Wire.h>
#include <hd44780.h>                        // include hd44780 library header file
#include <hd44780ioClass/hd44780_I2Cexp.h>  // i/o expander/backpack class
hd44780_I2Cexp lcd;                         // auto detect backpack and pin mappings
#include <Arduino.h>
#include <EEPROM.h>
#include <virtuabotixRTC.h>
virtuabotixRTC myRTC(6, 7, 8);
//Libraries for DHT11(temp and humidity sensor) module
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <DHT_U.h>
#include <Math.h>
#define DHTPIN 12
#define DHTTYPE DHT11
DHT_Unified dht(DHTPIN, DHTTYPE);
//Libraries for BMP180 (Pressure and temp sensor)
#include <Adafruit_BMP085.h>
Adafruit_BMP085 bmp;
//button variables
const int btnChange = 9;
const int btnOK = 10;
const int btnMode = 11;
//buzzer
const int buzzer = 16;
//IR
const unsigned int ir = 17;
int buttonState = 0;
int oldButtonState = LOW;
boolean ledState = false;
unsigned long previousMillis = 0;
int alarmHour = 12;
int alarmMinutes = 0;
boolean hourMode = 0;
boolean alarmOn = 1;
boolean alrmState = false;
int M = 06;
int D = 01;
int Y = 2024;
int dy = 7;
int h = 00;
int m = 00;
int addrH[] = { 0, 1, 2, 3, 4 };
int addrM[] = { 5, 6, 7, 8, 9 };
int addrActive[] = { 10, 11, 12, 13, 14 };
int mode = 1;
int submode = 1;
int slot = 0;
int scroll = 1;
const static char* WeekDays[] = {
  "Sun",
  "Mon",
  "Tue",
  "Wed",
  "Thu",
  "Fri",
  "Sat"
uint8_t moon[8] = { B11100, B01110, B00111, B00111, B00111, B00111, B01110, B11100 };
uint8_t alarmChar[8] = { B00100, B01110, B01110, B01110, B11111, B00000, B00100, B00000 };
uint8_t sunny[8] = { B00100, B10101, B01110, B11011, B01110, B10101, B00100, B00000 };
uint8_t rain[8] = { B00100, B01110, B01110, B11111, B11111, B11111, B01110, B00000 };
uint8_t same[8] = { B01000, B11101, B10111, B00010, B01000, B11101, B10111, B00010 };
uint8_t temperature[8] = { B00100, B01010, B01010, B01010, B01010, B11101, B11111, B01110 };
uint8_t pressure[8] = { B01110, B01110, B01110, B01110, B01110, B11111, B01110, B00100 };
uint8_t hourGlass[8] = {  B11111,  B10001,  B11111,  B01110,  B00100,  B01010,  B10101,B11111};
float currentPressure;
float ave = 0.0;
boolean flag = false;
#define NO_BACKLIGHT
#define BACKLIGHT_ALWAYS_ON
#define BACKLIGHT_TIMEOUT 10000
  dht.begin();
  bmp.begin();
  lcd.begin(16, 2);
  pinMode(btnChange, INPUT_PULLUP);
  pinMode(btnOK, INPUT_PULLUP);
  pinMode(btnMode, INPUT_PULLUP);
  pinMode(buzzer, OUTPUT);
  pinMode(ir, INPUT_PULLUP);
  lcd.init();
  lcd.init();
  lcd.backlight();  // Turn on the blacklight
  lcd.createChar(0, moon);
  lcd.createChar(1, alarmChar);
  lcd.createChar(2, sunny);
  lcd.createChar(3, rain);
  lcd.createChar(4, same);
  lcd.createChar(5, temperature);
  lcd.createChar(6, pressure);
  lcd.createChar(7, hourGlass);
  lcd.setCursor(1, 0);  //initial splash screen
  lcd.print("Arduino Alarm");
  lcd.setCursor(2, 1);
  lcd.print("Clock v6.0");
  buttonState = digitalRead(ir);
  if (currentMillis - previousMillis >= 150) {
    if (buttonState != oldButtonState && buttonState == HIGH) {
      ledState = (ledState == false ? true : false);
      if (ledState == true)
        lcd.backlight();
        lcd.noBacklight();
    oldButtonState = buttonState;
    delay(50);
    mode++;
    if (mode == 6) {
      mode = 1;
    submode = 0;
    lcd.clear();
    delay(100);
  switch (mode) {
    case 1:
      clockDisplay();
    case 2:
      weatherMode();
      delay(100);
    case 3:
      alarmMode();
      delay(100);
    case 4:
      timerInterface();
      timer();
      delay(100);
    case 5:
      updateRTC();
      delay(100);
    // case 0:
    //   // alarm();
    //   // EEPROM.write(addrActive, 0);
    //   break;
    default:
  for (int x = 0; x < 5; x++)
    if (EEPROM.read(addrActive[x]) == 1) {
      alrmState = true;
      if (myRTC.hours == EEPROM.read(addrH[x]) && myRTC.minutes == EEPROM.read(addrM[x])) {
        EEPROM.write(addrActive[x], 0);
        alarm('a');
    clockDisplay();
    lcd.clear();
    if (timerH < 10)
      lcd.print("0");
    lcd.print(timerH);
    lcd.print(":");
    if (timerM < 10)
      lcd.print("0");
    lcd.print(timerM);
    lcd.print(":");
    if (timerS < 10)
      lcd.print("0");
    lcd.print(timerS);
      return true;
    lcd.noBacklight();
    delay(200);
    lcd.backlight();
    delay(200);
    lcd.noBacklight();
    delay(200);
    lcd.backlight();
    delay(400);
      return true;
////////////////////////////////////////////////////////////////CLOCK DISPLAY FUCNTION
void clockDisplay() {
  lcd.home();
  myRTC.updateTime();  //This allows for the update of variables for time.
    lcd.write(3);
    sensors_event_t event;
    dht.humidity().getEvent(&event);
    lcd.print(round(floor((event.relative_humidity))));
    lcd.print("% ");
    //Time
    if (myRTC.hours < 10) lcd.print('0');
    lcd.print(myRTC.hours);  // 00-23
    lcd.print(':');
    if (myRTC.minutes < 10) lcd.print('0');
    lcd.print(myRTC.minutes);  // 00-59
    lcd.print(' ');
    lcd.write(5);
    lcd.print(round(floor((bmp.readTemperature()))));
    lcd.write(B11011111);
    lcd.print("C");
    //2nd line
    if (alrmState == true)
      lcd.write(1);
      lcd.print(' ');
    //Day of the week
    lcd.print(WeekDays[myRTC.dayofweek - 1]);  // 1-7
    lcd.print(' ');
    lcd.print(myRTC.dayofmonth);  // 01-31
    switch (myRTC.dayofmonth % 10) {
      case 1:
        lcd.print("st");
      case 2:
        lcd.print("nd");
      case 3:
        lcd.print("rd");
      default:
        lcd.print("th");
    lcd.print(' ');
    switch (myRTC.month) {
      case 1:
        lcd.print("Jan");
      case 2:
        lcd.print("Feb");
      case 3:
        lcd.print("Mar");
      case 4:
        lcd.print("Apr");
      case 5:
        lcd.print("May");
      case 6:
        lcd.print("Jun");
      case 7:
        lcd.print("Jul");
      case 8:
        lcd.print("Aug");
      case 9:
        lcd.print("Sep");
      case 10:
        lcd.print("Oct");
      case 11:
        lcd.print("Nov");
      case 12:
        lcd.print("Dec");
      default:
    lcd.print(' ');
    int avgPrsr = avgPressure();
    currentPressure = round(bmp.readPressure() / 100);
    int pressureDelta = abs(avgPrsr - currentPressure);
    if (myRTC.hours >= 0 && myRTC.hours <= 3 || myRTC.hours > 17 && myRTC.hours <= 23)
      lcd.write(0);
      lcd.write(2);
    //low pressure
    if (pressureDelta > 2 && avgPrsr > currentPressure || event.relative_humidity > 90)
      lcd.write(3);
    //high pressure
    else if (pressureDelta > 2 && avgPrsr < currentPressure) {
        lcd.write(0);
        lcd.write(2);
    //similar pressure
    else if (pressureDelta <= 2 || avgPrsr == currentPressure) {
      lcd.setCursor(13, 1);
      lcd.write(4);
void weatherMode() {
  lcd.home();
  myRTC.updateTime();
    lcd.write(5);
    lcd.print(bmp.readTemperature());
    lcd.print("C ");
    lcd.write(3);
    lcd.print(round(event.relative_humidity));
    lcd.print("%");
    //lcd.print(countH);
    lcd.write(6);
    lcd.print(round(currentPressure));
    lcd.print("mB ");
    //lcd.setCursor(8, 1);
    lcd.print("A=");
    lcd.print(avgPressure());
    lcd.print("mB");
int avgPressure() {
  myRTC.updateTime();
    if (myRTC.seconds == 0 && flag == false) {
      flag = true;
      ave = ave * 0.9 + bmp.readPressure() / 100 * 0.1;
    if (myRTC.seconds == 5)
      flag = false;
    return ave;
    lcd.write(7);
    //timer hour
    if (timerH < 10) {
      lcd.print("0");
    lcd.print(timerH);
    //timer minutes
    lcd.print(":");
    if (timerM < 10) {
      lcd.print("0");
    lcd.print(timerM);
    //timer seconds
    lcd.print(":");
    if (timerS < 10) {
      lcd.print("0");
    lcd.print(timerS);
      scroll++;
      if (scroll > 5)
        scroll = 1;
      delay(100);
      lcd.clear();
    if (scroll == 1) {
      lcd.write(6);
      lcd.write(6);
        timerH++;
        if (timerH > 24)
          timerH = 0;
        delay(200);
    if (scroll == 2) {
      lcd.write(6);
      lcd.write(6);
        timerM++;
        if (timerM > 59)
          timerH = 0;
        delay(200);
    if (scroll == 3) {
      lcd.write(6);
      lcd.write(6);
        timerS++;
        if (timerS > 59)
          timerS = 0;
        delay(200);
    if (scroll == 4) {
      lcd.clear();
      lcd.home();
        timerH = 23;
        timerM = 59;
        timerS = 59;
        //delay(500);
        //lcd.clear();
void timer() {
    lcd.clear();
    lcd.write(7);
    myRTC.updateTime();
      if (timerS < 0) {
        timerS = 59;
        timerM--;
      timerS--;
      if (timerM < 0) {
        timerM = 59;
        timerH--;
      if (timerH < 10)
        lcd.print("0");
      lcd.print(timerH);
      lcd.print(":");
      if (timerM < 10)
        lcd.print("0");
      lcd.print(timerM);
      lcd.print(":");
      if (timerS < 10)
        lcd.print("0");
      lcd.print(timerS);
        alarm('t');
///////////////////////////////////////////////////////////////////   ALARM FUNCTION  ///////////////////////////////////////////
void alarmMode() {
  if (submode == 0) {
    lcd.write(1);
    lcd.print("Select:");
      slot++;
      if (slot > 4)
        slot = 0;
      delay(100);
    lcd.setCursor(10, 0);
    lcd.print("Slot#");
    lcd.print(slot + 1);
    if (EEPROM.read(addrH[slot]) > 23)
      EEPROM.write(addrH[slot], 0);
    if (EEPROM.read(addrM[slot]) > 59)
      EEPROM.write(addrM[slot], 0);
    if (EEPROM.read(addrActive[slot]) > 1)
      EEPROM.write(addrActive[slot], 0);
    if ((EEPROM.read(addrH[slot]) > 12 && EEPROM.read(addrH[slot]) < 22) || (EEPROM.read(addrH[slot]) > 0 && EEPROM.read(addrH[slot]) < 10))
      lcd.print("0");
    if (EEPROM.read(addrH[slot]) == 0) {
      lcd.print("12");
      alarmHour = 12;
    } else if (EEPROM.read(addrH[slot]) <= 12) {
      lcd.print(EEPROM.read(addrH[slot]));
      alarmHour = EEPROM.read(addrH[slot]);
      lcd.print(EEPROM.read(addrH[slot]) - 12);
      alarmHour = EEPROM.read(addrH[slot]) - 12;
    lcd.print(":");
    if (EEPROM.read(addrM[slot]) < 10)
      lcd.print("0");
    lcd.print(EEPROM.read(addrM[slot]));
    alarmMinutes = EEPROM.read(addrM[slot]);
    lcd.print(" ");
    if (EEPROM.read(addrH[slot]) < 12) {
      lcd.print("AM");
      hourMode = 0;
      lcd.print("PM");
      hourMode = 1;
    lcd.print("   ");
    if (EEPROM.read(addrActive[slot]) == 1)
      lcd.print("ON ");
      lcd.print("OFF");
    lcd.write(1);
    lcd.print("Alarm ||");
    if (alarmHour < 10) {
      lcd.print("0");
    lcd.print(alarmHour);
    lcd.print(":");
    if (alarmMinutes < 10) {
      lcd.print("0");
    lcd.print(alarmMinutes);
    if (hourMode == 0)
      lcd.print("AM");
      lcd.print("PM");
  //  lcd.print(alarmMinutes);
    submode++;
    if (submode > 4)
      submode = 0;
    delay(100);
    lcd.clear();
  if (submode == 1) {
    lcd.setCursor(9, 0);
    lcd.write(6);
    lcd.write(6);
      alarmHour++;
      if (alarmHour > 12)
        alarmHour = 1;
      delay(200);
  if (submode == 2) {
    lcd.setCursor(12, 0);
    lcd.write(6);
    lcd.write(6);
      alarmMinutes++;
      if (alarmMinutes >= 60)
        alarmMinutes = 0;
      delay(200);
  if (submode == 3) {
    lcd.write(6);
    lcd.write(6);
      hourMode = !hourMode;
      delay(200);
  while (submode == 4) {
    lcd.print("Activate Alarm?");
    lcd.print("Slot #");
    lcd.print("   ");
    if (alarmOn == 1)
      lcd.print("ON ");
      lcd.print("OFF");
      alarmOn = !alarmOn;
      delay(200);
    if (digitalRead(btnOK) == LOW && alarmOn == 1) {
      lcd.clear();
      lcd.print("Saving........");
      if (hourMode == 1 && alarmHour != 12) {
        EEPROM.write(addrH[slot], alarmHour + 12);
      } else if (hourMode == 0 && alarmHour == 12) {
        EEPROM.write(addrH[slot], alarmHour);
      EEPROM.write(addrM[slot], alarmMinutes);
      EEPROM.write(addrActive[slot], 1);
      submode = 0;
      mode = 1;
      lcd.clear();
    if (digitalRead(btnOK) == LOW && alarmOn == 0) {
      lcd.clear();
      lcd.print("Alarm Slot#");
      lcd.print(" OFF      ");
      submode = 0;
      mode = 1;
      lcd.clear();
///////////////////////////////////////////////////////////////////   SETTING DATE & TIME FUNCTION  ///////////////////////////////////////////
void updateRTC() {
    submode++;
    if (submode > 7) {
      submode = 0;
    delay(100);
    lcd.clear();
  if (submode == 0) {
    lcd.print(" Set Date/Time?");
    lcd.print("Press OK button");
  if (submode == 1) {
    lcd.print("Set Month");
    lcd.print("--> ");
      M++;
      if (M == 13) {
        M = 1;
      delay(100);
    switch (M) {
      case 1:
        lcd.print("January     ");
      case 2:
        lcd.print("February    ");
      case 3:
        lcd.print("March       ");
      case 4:
        lcd.print("April       ");
      case 5:
        lcd.print("May         ");
      case 6:
        lcd.print("June        ");
      case 7:
        lcd.print("July        ");
      case 8:
        lcd.print("August      ");
      case 9:
        lcd.print("September   ");
      case 10:
        lcd.print("October     ");
      case 11:
        lcd.print("November    ");
      case 12:
        lcd.print("December    ");
  if (submode == 2) {
    lcd.print("Set Day");
    lcd.print("--> ");
      D++;
      if (D == 32) {
        D = 1;
      delay(100);
    lcd.print(D);
    lcd.print(" ");
  if (submode == 3) {
    lcd.print("Set Year");
    lcd.print("--> ");
      Y++;
      if (Y == 2099) {
        Y = 2000;
      delay(100);
    lcd.print(Y);
  if (submode == 4) {
    lcd.print("Set Day of the Week");
    lcd.print("--> ");
      dy++;
      if (dy == 8) {
        dy = 1;
      delay(100);
    switch (dy) {
      case 1:
        lcd.print("Sunday      ");
      case 2:
        lcd.print("Monday      ");
      case 3:
        lcd.print("Tuesday     ");
      case 4:
        lcd.print("Wednesday   ");
      case 5:
        lcd.print("Thursday    ");
      case 6:
        lcd.print("Friday      ");
      case 7:
        lcd.print("Saturday    ");
  if (submode == 5) {
    lcd.print("Set Hour");
    lcd.print("--> ");
      h++;
      if (h == 24) {
        h = 0;
      delay(100);
    if (h > 12) {
      lcd.print(h - 12);
      lcd.print(" ");
    } else if (h == 0) {
      lcd.print("12");
      lcd.print(" ");
      lcd.print(h);
      lcd.print(" ");
    if (h >= 12) {
      lcd.print("PM");
      lcd.print("AM");
  if (submode == 6) {
    lcd.print("Set Minutes");
    lcd.print("--> ");
      m++;
      if (m == 60) {
        m = 0;
      delay(100);
    lcd.print(m);
    lcd.print(" ");
  if (submode == 7) {
    lcd.print("Date & Time");
    lcd.print("Updating......");
    myRTC.setDS1302Time(00, m, h, dy, D, M, Y);
    delay(200);
    lcd.clear();
    mode = 1;
That is very odd. Looking through the code, that function gets called every time through loop() and you certainly do not want to clear the display before redrawing the countdown timer. Did you try stripping all the other functionality out of the code and see if the problem persists?
Also,
writes a 0 to whatever address that array holds. Not what you probably want.
As some general feedback, it would be much better to use a button library to detect when your buttons are pressed, not if they are pressed.
You also have a lot of duplicated code in all your different functions for your various modes. Much better to do it all once each time through loop
  1. read all your buttons
  2. read all your sensors
  3. figure out your elapsed time
  4. then do your switch statement for the various modes
You can also google finite state machine to see a model for coding up all the modes.
I will strip away the functions asap. Meanwhile,
Do you mean that I should take the readings of my sensors in the void loop function instead of their respective functions?
I just found out about the Button Library and its genius! I will implement this to my code.
Unrelated to the problem, should I also try to remove the delays and replace them with millis() as delays? I thought about that but then realized, I would run out of memory if I create so many unsigned long variables. Would that be an issue or should I reuse those currentMillis and PrevMillis variables?
Thank you for going through my long code!!
Yes, you loop() should look something like this
  readButtons();
  readAllSensors();
  switch(mode) {
In reality, it will be a bit more complicated, but that's the idea.
Another common button library is the EZButton or bounce2
This was the issue. I carelessly forgot to end this if block with a '}'. Hence it kept looping infinitely, literally giving the lcd screen seizures.
Now the timer works fine, except after the timer ends, it restarts at 23hrs:59m:59s.
That code was there to prevent the timer from going to the negatives. I will have to find a way to fix that, if anyone got any ideas, do comment!
P.S: I tried using the button library, but now the button inputs have been super slow and irresponsive.
