LCD Text Not Displaying
Hello all,
I've never used an Arduino before, and I wanted to use the website "tinkercad" to create my project before re-creating it in real life.
In doing so, I am confident I have proper code and wiring to the LCD however it only turns on and does not display "Hello World" as instructed.
Pictures of circuit board:
(OFF) Imgur: The magic of the Internet
(ON) Imgur: The magic of the Internet
Potentiometer value: 250 ohms
Resistor value: 220 ohms
Code used in Arduino:
  LiquidCrystal Library - Hello World
 Demonstrates the use a 16x2 LCD display.  The LiquidCrystal
 library works with all LCD displays that are compatible with the
 Hitachi HD44780 driver. There are many of them out there, and you
 can usually tell them by the 16-pin interface.
 This sketch prints "Hello World!" to the LCD
 and shows the time.
  The circuit:
 * LCD RS pin to digital pin 12
 * LCD Enable pin to digital pin 11
 * LCD D4 pin to digital pin 5
 * LCD D5 pin to digital pin 4
 * LCD D6 pin to digital pin 3
 * LCD D7 pin to digital pin 2
 * LCD R/W pin to ground
 * LCD VSS pin to ground
 * LCD VCC pin to 5V
 * 10K resistor:
 * ends to +5V and ground
 * wiper to LCD VO pin (pin 3)
 Library originally added 18 Apr 2008
 by David A. Mellis
 library modified 5 Jul 2009
 by Limor Fried (http://www.ladyada.net)
 example added 9 Jul 2009
 by Tom Igoe
 modified 22 Nov 2010
 by Tom Igoe
 This example code is in the public domain.
 http://www.arduino.cc/en/Tutorial/LiquidCrystal
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("hello, world!");
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  lcd.print(millis() / 1000);
I appreciate your help in getting my LCD to display text, I have tried to watch tutorials and I don't understand where I went wrong and was directed to this community, hoping someone can help.
What happens if you remove the pot and connect the contrast pin (LCD pin 3) to ground with a 1K resistor?
The code works fine on my Uno with 1602 display. I have the contrast pin wired as above.
It works now!! Thank you so much :slight_smile:
On a real display there may be an advantage to using a pot versus a fixed resistor. If the supply voltage can vary then the contrast may need to be adjusted. The correct way to wire a pot is to wire one end of the pot to ground and the wiper to pin 3. The other end of the pot not connected or connected to the wiper. This is contrary to the standing, and incorrect, advice that the pot is wired to ground, Vcc and pin 3.
"OFF"
"ON"
Can't see any meaningful difference there! In any case,
groundFungus:
Well I am pleased!
I can take it a bit easier now, with others on to the matter of this long-standing and somewhat annoying muck-up. And this thread demonstrates that the 1k resistor is close enough to optimum to be a "working straight away" approach rather than needing to get the potentiometer set at least to the correct end of travel before you can even see any display. :grinning:
groundFungus:
Just to be clear about this we are talking about this special case where we desire a variable resistor (also known as a rheostat) and happen to have a potentiometer on hand.
In general the correct way to wire a potentiometer is to use all three terminals. When using only two terminals of a potentiometer you run the risk of exceeding its current carrying capabilities as you reduce the resistance down toward zero ohms. Rheostats are designed to minimize this risk.
In this case there are other resistors to limit the current so the risk is not present.
Don
Yeah!
