ldr,lcd,led measuring light intensity/led+ldr
Please see my code and help me to edit this code to correct form. I would like to do about the LDR,LCD,LED processing measuring light intensity.Please help me and give me advice.Thanks you very much.
Code led+ldr
int ldrIn=0;
int ledPin=3;
int value =0;
int sensorValue = 0;
void setup(){
pinMode (11,OUTPUT);
pinMode (10,OUTPUT);
pinMode (9,OUTPUT);
Serial.begin (9600);
void loop (){
for ( int i=0; i<5; i++){
value = analogRead(ldrIn);
value = map (value,610,760,0,20);
value = constrain (value,610,760);
int d = sensorValue;
Serial.println(sensorValue);
if(d==0){
digitalWrite(9,LOW);
digitalWrite(11,LOW);
digitalWrite(10,LOW);
if(d==5){
digitalWrite(9,HIGH);
if(d==10){
digitalWrite(10,HIGH);
if(d==20){
digitalWrite(11,HIGH);
Code Ldr+led+lcd
#include <LiquidCrystal.h>
int ldrIn=0;
int ledPin=3;
int value =0;
int fotoPin = A0;
int fotoValue = 0;
const int numRows = 2;
const int numCols = 20;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
void setup(){
pinMode (9,OUTPUT);
lcd.begin(numCols,numRows);
lcd.setCursor(2,0);
lcd.print("Comienza");
lcd.setCursor(2,1);
lcd.print("Medicion");
delay(2000);
lcd.clear();
void loop (){
if(d==0){
if(d==5){
if(d==10){
if(d==20){
fotoValue = analogRead(fotoPin);
fotoValue = map(fotoValue, 610, 760, 20, 0);
Serial.println(fotoValue);
lcd.setCursor(2,0);
lcd.print(fotoValue, DEC);
lcd.print(" lumens");
lcd.clear();
Thanks you for your help.
You will need to describe what the code is supposed to do and what it actually does.
Where does the variable sensorValue get its value?
...R
What happened to the code tags?
And the indentation?
