i use the digital pin as interrupts to wake up my arduino. that work fine but when i move my project to less light room it does not trigger well.(direct light <> darkness = oke, less light <> darkness = no trigger).
How can i make it more sensitief? i have try different potentiometer (10k,50k), LDR (GL5506,GL5537)
Or is there a beter LDR module then this one?
To get more range out of an LDR, I use two or three resistors to power the LDR. The resistors are connected to outputs of the Arduino. One output can have a 1k resistor and one output can have 100k resistor (or even more).
I power the outputs one by one, and average the result. With that, I can see the difference between a dark night and a night when the moon is shining.
I don't use such modules, and because of the high value of the 100k resistor, it needs to be close to the Arduino and I use delays before taking a sample with analogRead() and I do averaging of a number of samples.
I agree with knut_ny. Use a LDR and a resistor. If you ask me, desolder or cut the LDR from the board and toss the board away. Try a few different resistors and see what happens.
Did you know that a LDR costs 3 cents ? (when you buy 100 of them at aliexpress).
i wish i can do that but i need the digital trigger to wake my arduino (attachInterrupt()). that is why i purchased this module. digital trigger with threshold)
( i have read in forum someone have try LDR analog on an Interrupts Pin. its dont work because voltage range 1.0-5v)
