Hello everyone.
I am building an LED array for the first time and directly with different LEDs that require different amounts of mA.
I have a total of 81 LEDs. Of these, 48 require 20mA, 27 50mA and 6 100mA:
In addition, I used the Arduino Atmega 2560 which only supplies 5V.
I suspect that I need to use an external voltage source. I was also advised to use an LED driver. How can I limit the current for the different LEDs so that all LEDs are supplied with the appropriate current?
Now I have all this information, but I don't know exactly how to link everything together to build a working LED array. Can anyone give me a tip on the best way to go about this?
Cross-posting is against the Arduino forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum. It will help you get the best out of the forum in the future.
Thank you.
Do you want to keep the post in German or the post here in English ?. You can’t have both.
The leds do not require 100mA
100mA is their max. current.
What do you want to schieve with this array?
100mA leds are blinding bright. So not a signal led or part of a screen, but like a light source.
You will hardly see the 20mA leds next to it.
Did you experiment with different resistors?
Do the leds all have the same color (around the same voltage)?
I would like to build an LED array that covers LEDs with wavelengths from 430 nm to 935 nm. The LEDs in the higher wavelength range are operated at 50 nm or 100 nm.
A matrix driver or a constant current driver?
In case of matrix driver: in series with each and every led.
To reach the same current, red leds need higher resistor value than blue ones.
But it should not be about equal current, it should be about the eye's perception of equal brightness.
Yes, I mean a matrix driver. But isn't one resistor per row of LEDs enough? If I were to connect a resistor in front of each LED, I would need 81 resistors for my 81 LEDs.
