Led Code working on Arduino Uno but not on Arduino Leonardo Pro Micro
Hi I have a led strip that uses LPD8806 + Fastled 3.1
On my Arduino uno I have set the digital data pin to 2 and the clock pin to 3 and this works fine.
I wanted to make a mood lamp so wanted a smaller board to put the code on - so I bought an Arduino Leonardo Pro micro.
I tested the blink code to test that everything was ok and that worked fine on the Leonardo Pro micro, so I uploaded my sketch from my Arduino Uno to the Leonardo Pro micro - but it's not driving the led strip - just all the lights are white?
The digital pins are supposed to be the same and are numbered 2+3 so I thought the code would work fine. The Leonardo Pro micro has a 16mhz crystal and is 5v so the timing should be the same as the uno, here's the code:
#include <FastLED.h>
#define BRIGHTNESS 255   // 0-255, higher number is brighter.
#define SATURATION 255   // 0-255, 0 is pure white, 255 is fully saturated color
#define SPEED       15   // How fast the colors move.  Higher numbers = faster motion
#define STEPS        4   // How wide the bands of color are.  1 = more like a gradient, 10 = more like stripes
#define BUTTON_PIN   13  // switch leds modes
#define DATA_PIN 2       // Connect Led Stip Data Pin to this
#define CLK_PIN 3        // Connect Led Stip Clock Pin to this
#define LED_TYPE    LPD8806
#define COLOR_ORDER BRG  // Changes the colour order if leds display incorrectly - can be RGB/BRG/GBR etc...
#define NUM_LEDS 52      // Number of LED on our strip
CRGB leds[NUM_LEDS];
CRGBPalette16 currentPalette;
CRGBPalette16 targetPalette( RainbowStripeColors_p );
TBlendType    currentBlending;
int ledMode = 0;
// Start of confetti variables
int thishue = 50;
uint8_t   thisinc = 1;
uint8_t   thissat = 100;
uint8_t  thisfade = 20;
int       huediff = 256;
uint8_t   thisbri = 255;
// End of confetti variables
unsigned long keyPrevMillis = 0;
const unsigned long keySampleIntervalMs = 25;
byte longKeyPressCountMax = 80;    // 80 * 25 = 2000 ms
byte longKeyPressCount = 0;
byte prevKeyState = HIGH;         // button is active low
  delay(1000); // power-up safety delay
  FastLED.addLeds<LED_TYPE,DATA_PIN,CLK_PIN,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
  FastLED.setBrightness(BRIGHTNESS);
  currentBlending = LINEARBLEND;
  pinMode(BUTTON_PIN, INPUT_PULLUP);
//=====================================Start of main void loop=====================================
  byte currKeyState = digitalRead(BUTTON_PIN);
  if ((prevKeyState == LOW) && (currKeyState == HIGH))
    shortKeyPress();
  prevKeyState = currKeyState;
  switch (ledMode)
  case 0:
    rainbowstripe();
  case 1:
    forest();
  case 2:
    ocean();
  case 3:
    purple();
  case 4:
    rainbow();
  case 5:
    heat();
  case 6:
    party();
  case 7:
    lava();
  case 8:
    dude();
  case 9:
    Sparkels();
  case 10:
    juggle();
  case 11:
    pinkdots();
  case 12:
    confetti();
  FastLED.show();
//=====================================End of main void loop=====================================
void sequence()
{ //this was removed from the main loop so that other sequences would work properly
  static uint8_t startIndex = 0;
  startIndex = startIndex + 1; /* motion speed */
  // Above here was at the top of the loop
  // Below here was at the bottom of the loop
  FillLEDsFromPaletteColors( startIndex);
  FastLED.delay(1000 / SPEED);
void shortKeyPress()
  ledMode++;
  if (ledMode > 13)
  { // The more effects you add to the void loop - increase this number by 1 for each case added
    ledMode=0;
void rainbowstripe()
  sequence();
  currentPalette = RainbowStripeColors_p;    //Red & Yellow, Fire Colors
void forest()
  sequence();
  currentPalette = ForestColors_p;    //Foresty greens and yellows
void ocean()
  sequence();
  currentPalette = OceanColors_p;  //Oceans are pretty and filled with mermaids
void purple()
  sequence();
  currentPalette = PurpleColors_p;  //Custom pallete
void rainbow()
  sequence();
  currentPalette = RainbowColors_p;  //All the colors!
void heat()
  sequence();
  currentPalette = HeatColors_p;   //Rainbow stripes
void party()
  sequence();
  currentPalette = PartyColors_p; //All the colors except the greens, which make people look a bit washed out
void lava()
  sequence();
  currentPalette = LavaColors_p; //Set everything lava
void dude()
  sequence();
  currentPalette = DudeColors_p; //Set everything lava
void Sparkels()
  fadeToBlackBy( leds, NUM_LEDS, 42);
  int i = random16(NUM_LEDS);
  leds[i] += CHSV( random(), 255, 255);
  FastLED.delay(100 / SPEED);
void FillLEDsFromPaletteColors( uint8_t colorIndex)
  for( int i = 0; i < NUM_LEDS; i++)
    leds[i] = ColorFromPalette(currentPalette, colorIndex, BRIGHTNESS, currentBlending);
    colorIndex += STEPS;
void juggle()
  // eight colored dots, weaving in and out of sync with each other
  fadeToBlackBy( leds, NUM_LEDS, 20);
  byte dothue = 0;
  for( int i = 0; i < 8; i++)
  leds[beatsin16(i+7,0,NUM_LEDS)] |= CHSV(dothue, 200, 255);
  dothue += 32;
void pinkdots() //Pink dots moving from left to right with a trail
  fadeToBlackBy( leds, NUM_LEDS, 0); //change this to change the trail length.
  int pos = beatsin16(10,0,NUM_LEDS); //change this to adjust the speed.
  leds[pos] += CHSV( 240, 240, 240);
void confetti()
  uint8_t secondHand = (millis() / 1000) % 15; // IMPORTANT!!! Change '15' to a different value to change duration of the loop.
  static uint8_t lastSecond = 99; // Static variable, means it's only defined once. This is our 'debounce' variable.
  if (lastSecond != secondHand)
  { // Debounce to make sure we're not repeating an assignment.
    lastSecond = secondHand;
    switch(secondHand)
    case  0: thisinc=1; thishue=192; thissat=255; thisfade=2; huediff=256; break; // You can change values here, one at a time , or altogether.
    case  5: thisinc=2; thishue=128; thisfade=8; huediff=64; break;
    case 10: thisinc=1; thishue=random16(255); thisfade=1; huediff=16; break; // Only gets called once, and not continuously for the next several seconds. Therefore, no rainbows.
    case 15: break; // Here's the matching 15 for the other one.
  fadeToBlackBy(leds, NUM_LEDS, thisfade); // Low values = slower fade.
  int pos = random16(NUM_LEDS); // Pick an LED at random.
  leds[pos] += CHSV((thishue + random16(huediff))/4 , thissat, thisbri);  // I use 12 bits for hue so that the hue increment isn't too quick.
  thishue = thishue + thisinc; // It increments here.
Any ideas as to why it's not working?
Thanks
Ok sorry guys, I found the problem that the ground wasn't connected properly - all sorted now. Thanks.
