LED is oozing goo
Hi guys,
Today when I plugged my LEDs into the power suply, they started sizzling as I could here them. Then they started oozing a black liquid and crackings sounds started appering from the LED. Does anyone know what has happened? I have thrown away about 10 LEDs so far. I don't want this to continue.
Thanks for advice
you either have an AC supply(could be a DC supply gone bad, or you picked up the wrong wall wart from the junkpile), or you've forgotten to put series resistances in to limit the current through the LED.
Add a current limiting resistor.
R=V/I
Hi this happened because I wanted to test if my LEDs still worked. Can you please check my setup to make sure that there are no errors! I have a power supply module connected. I think that my power cable is causing all the trouble.
  • Wire simple LEDs as D1 and D2 are wired.
  • Why are you mixing 5V and 3V3 ?
  • Show us how the LED was inserted into the breadboard.
I pyt the Anode of the LED to the resistor and the red wire and the cathode of the led to the black wire which went to gnd
  • Sounds like you then had the following.
+5v——Anode[>|]Cathode——GND
+5v——[resistor]——+3v3
  • You basically had no series resistor for the LED, hence it burned up.
  • You want.
+5v——Anode-[>|]-Cathode—— [resistor] ——GND
Hi, @williamnumismatics
Do you have a DMM? (Digital MultiMeter)
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
3.3 and 5.0 swapped, but yeah.
Zooming in the on the picture, the potential circuit it looks much more confused than that:
+3.3V -+-- R ---- +5V
       +-- LED -- GND
  • OP, do you understand how the power supply is configurable ?
Oops. I didn't in #11. You were right about which was 5V and which was 3.3.
