UPDATE: Found a workable solution for what I need. Posted it down below for anyone who might need a similar effect.
I am trying to simulate a neon sign flickering on before going solid. I found this guys video and he posted his code in the comments. The problem is I can't make heads or tails of it since I didn't write it.
I just want to have the sketch run when I power on the arduino. No need for a button or anything. Any help would be appreciated.
#define DATA_PIN 3
#define BUTTON_PIN 4
boolean lightOn = 0;
pinMode(DATA_PIN, OUTPUT);
pinMode(BUTTON_PIN, INPUT);
const int blinkOn[] = {10, 20, 20, 240, 20, 40, 20, 100, 20, 20, 20, 260, 80, 20, 240, 60, 160, 20, 240, 20, 1000, 20, 20, 40, 100, 20, 2740, 340, 860, 20, 1400, 20, 60, 20};
void allOn(boolean on) {
digitalWrite(DATA_PIN, on);
void updateLeds() {
allOn(lightOn);
boolean myDelay(unsigned int ms) {
unsigned long startTime = millis();
unsigned long endTime = startTime+ms;
while(millis() < endTime) {
if(!digitalRead(BUTTON_PIN)) {
return 1;
// Update colour and intencity of leds updateLeds();
delay(1);
return 0;
void turnOn() {
// Don't flicker, if the light is already on
if(lightOn)
return;
// Start to flicker
for(int i=0; i<sizeof(blinkOn)/sizeof(int); ++i) {
lightOn = !(i&1);
if(myDelay(blinkOn[i])) {
// Button is no longer pushed
allOn(false);
lightOn = false;
return;
// Make sure the light is actually on
allOn(true);
lightOn = true;
void turnOff() {
lightOn = false;
allOn(false);
delay(100);
if(digitalRead(BUTTON_PIN))
turnOn();
turnOff();
