Led on arduino UNO dim while in delay ?
Hello,
Can someone tell me why my led's on my UNO are dim while the millis delay function is active. I am a beginner! The code works like I want it to but for some reason the led's go dim while the countdown is active. I'm supposing something in my code is incorrect. I am using pull-down resistors on my breadboard.
byte sensorOne = 2;
byte feedOne = 8;
byte augerOne = 16;
unsigned long feedEmptyMillis; // when feed level dropped below sensor
unsigned long turnOnDelay = 3000; // wait to turn on auger
unsigned long turnOffDelay = 10000; // turn off auger after this time
  pinMode (sensorOne, INPUT);
  pinMode (feedOne, OUTPUT);
  pinMode (augerOne, OUTPUT);
  boolean prox1 = digitalRead (sensorOne);
  if (prox1 == LOW)
    digitalWrite (feedOne, LOW);
    digitalWrite(augerOne, HIGH);
  if (prox1 == HIGH)
    feedEmptyMillis = currentMillis;
  if (currentMillis - feedEmptyMillis <= turnOnDelay)
    digitalWrite (augerOne, LOW);
  if (currentMillis - feedEmptyMillis <= turnOffDelay)
    digitalWrite (feedOne, HIGH);
Which LEDs are you concerned about ?
Ok my LED's are the augerOne and the feedOne outputs.
Because you switch them on and off at a high speed
  if (prox1 == LOW)
As long as prox equals low the second if results in true, augerOne goes HIGH / LOW all the time. Same for feedOne.
