I have a Led Arduino circuit that runs 4 parallel leds. They only run at max values of 255 of anything. Here is my code.
#include <Servo.h>
int redPin = 10;
int greenPin = 11;
int bluePin = 9;
int angle=0;
Servo serb;
serb.attach(8);//Associate serbiy with pin 9
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
int red, green, blue;
red = 0;
green = 0;
blue = 0;
for(green=0;green<=50;green+=1)
for(blue=255;blue>=0;blue=blue-1)
for(red=255;red>=0;red=red-1)
if (red==255) {
if (angle==0) {angle=180;
serb.write(angle);
analogWrite(redPin, red);//Turns on led at pin 13
analogWrite(greenPin, green);//Turns on led at pin 13
analogWrite(bluePin, blue);//Turns on led at pin 13
delay(250);
if (red==127) {
if (angle==180) {angle=0;
serb.write(angle);
delay(250);
delay(250);
Serial.print(red);
Serial.print(" , ");
Serial.print(green);
Serial.print(blue);
Serial.println(angle);
It is not safe to power any motor directly from an Arduino. Use a separate power supply with enough current capability for your motor.
There may be a problem with the placement of all the { and } in your code, but it difficult to be sure about that because the indentation is a mess. Please Auto-Format the code and re-post it.
It's possible that the Servo library is attempting to use the same timer that your PWM pins use. Try using different PWM pins.
#include <Servo.h>
int redPin = 10;
int greenPin = 11;
int bluePin = 9;
int angle=0;
Servo serb;
red = 0;
green = 0;
blue = 0;
if (red==255) {
serb.write(angle);
delay(250);
if (red==127) {
serb.write(angle);
delay(250);
delay(250);
Serial.print(red);
Serial.print(blue);
Your loop() takes 9.7 days to run. You have keep looking at it for more than a week to see that the leds are dimmed.
It it supposed to take that long ?
I made your project in Wokwi simulation:
If you want to test if the leds can be used with PWM, then add test code in the setup() function. Let each led go from 0 to 255 with a small delay. Test each led on its own.
@28ri0203
There are several things wrong.
The Servo library disables PWM on pins 9 and 10 so you need to use other pins.
You can't drive 4 LEDs from an Arduino, only one LED.
So pick new pins and try it with just 1 RGB led to see if it works.
