// Connections
int mreset = 10;
int shift = 11;
int store = 12;
int data = 13;
int taster = 9;
int a, tasterstatus = 0;
/ Delays
int tasterdelay = 250;
int fast = 8;
int stage1 = 150;
int stage2 = 150;
int stage3_1 = 400;
int stage3_2 = 750;
int stage4 = 150;
unsigned long time_now = 0;
// Pattern
int leftside[24] = {1, 1, 1, 1, 1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
int ndleftside[24] = {1, 1, 1, 1, 0, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
int ndrightside[24] = {1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0};
int rightside[24] = {1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 0};
btw can i do these Numbers as Hex ?
pinMode(shift , OUTPUT);
pinMode(store , OUTPUT);
pinMode(data , OUTPUT);
pinMode(mreset , OUTPUT);
pinMode(taster , INPUT);
randomSeed(analogRead(0));
digitalWrite(mreset, LOW);
digitalWrite(store, HIGH);
digitalWrite(mreset, HIGH);
digitalWrite(store, LOW);
tasterstatus = digitalRead(taster);
if (tasterstatus == HIGH) {
a++;
delay(tasterdelay);
switch (a) {
case 1:
pattern1();
case 2:
pattern2();
case 3:
pattern3();
case 4:
pattern4();
default:
if (a != 0)
a = 1;
void pattern1() {
time_now = millis();
for (int i = 0; i < 24; i++) {
digitalWrite(shift, LOW);
digitalWrite(data, leftside[i]);
digitalWrite(shift, HIGH);
while (millis() < time_now + stage1) {
delay(tasterdelay);
a++;
loop();
return;
digitalWrite(data, ndleftside[i]);
delay(tasterdelay);
a++;
loop();
return;
digitalWrite(data, ndrightside[i]);
delay(tasterdelay);
a++;
loop();
return;
digitalWrite(data, rightside[i]);
delay(tasterdelay);
a++;
loop();
return;
delay(tasterdelay);
a++;
loop();
return;
delay(tasterdelay);
a++;
loop();
return;
delay(tasterdelay);
a++;
loop();
return;
Hopefully you understand, the pattern1 is basically the same every time
