Lego sorting machine
Hello everyone. I am attempting to build an automated lego sorter. It will feature a conveyer driven by a stepper, using micro servos to sort, a TCS3200 and UNO.
I would like to initally start with sorting only 3 colors. Preferably Red, Green, Blue, and dump all other colors off the edge of the conveyer. I would like to change these as I need so I can sort other color bricks.
It is ok if it is not a 100% method, I need something to cut down hand sorting.
I found 2 codes that I would like to combine, but I need to also add something to tell the stepper to start and stop.
My basis initally was this project:
Sorting machine
Using this code:
#include <Servo.h>
Servo pickServo;
Servo dropServo;
#define S0 4
#define S1 5
#define S2 7
#define S3 6
#define sensorOut 8
int frequency = 0;
int color=0;
int detectColor() {
  // activating red photodiodes to read
  digitalWrite(S2, LOW);
  digitalWrite(S3, LOW);
  frequency = pulseIn(sensorOut, LOW);
  int R = frequency;
  Serial.print("Red = ");
  Serial.print(frequency);//printing RED color frequency
  Serial.print("   ");
  delay(50);
   // activating blue photodiodes to read
  digitalWrite(S3, HIGH);
  int B = frequency;
  Serial.print("Blue = ");
  Serial.println("   ");
  // activating green photodiodes to read
  digitalWrite(S2, HIGH);
  // Reading the output frequency
  int G = frequency;
  Serial.print("Green = ");
  Serial.print("   ");
  delay(50);
  delay(50);
//Readings are different for different setup
//change the readings according your project and readings detected
  if(R<22 & R>20 & G<29 & G>27){
    color = 1; // Red
    Serial.print("Detected Color is = ");
    Serial.println("RED");
  if(G<25 & G>22 & B<22 &B>19){
    color = 2; // Orange
      Serial.println("Orange  ");
  if(R<21 & R>20 & G<28 & G>25){
    color = 3; // Green
    Serial.println("GREEN");
  if(R<38 & R>24 & G<44 & G>30){
    color = 4; // Yellow
    Serial.println("YELLOW");
  if (G<29 & G>27 & B<22 &B>19){
    color = 5; // Blue
    Serial.println("BLUE");
  return color;
  pinMode(S0, OUTPUT);
  pinMode(S1, OUTPUT);
  pinMode(S2, OUTPUT);
  pinMode(S3, OUTPUT);
  pinMode(sensorOut, INPUT);
  //frequency-scaling to 20% selected
  digitalWrite(S0, LOW);
  digitalWrite(S1, HIGH);
  pickServo.attach(9);
  dropServo.attach(10);
  //initial position of servo motor
  pickServo.write(115);
  delay(600);
  for(int i = 115; i > 65; i--) {
    pickServo.write(i);
    delay(2);
  //read color values by calling function. save the values for conclusion in variable
  color = detectColor();
  switch (color) {
    case 1:
    dropServo.write(50);
    case 2:
    dropServo.write(80);
    case 3:
    dropServo.write(110);
    case 4:
    dropServo.write(140);
    case 5:
    dropServo.write(170);
    case 0:
  for(int i = 65; i > 29; i--) {
    pickServo.write(i);
    delay(2);
  delay(300);
  for(int i = 29; i < 115; i++) {
    pickServo.write(i);
    delay(2);
  color=0;
However, with following his tutorial I could not get the correct RGB outputs, so I tried this one:
RGB Sensor
  Rui Santos
  Complete project details at https://randomnerdtutorials.com
// TCS230 or TCS3200 pins wiring to Arduino
#define S0 4
#define S1 5
#define S2 6
#define S3 7
#define sensorOut 8
// Stores frequency read by the photodiodes
int redFrequency = 0;
int greenFrequency = 0;
int blueFrequency = 0;
// Stores the red. green and blue colors
int redColor = 0;
int greenColor = 0;
int blueColor = 0;
  // Setting the outputs
  // Setting the sensorOut as an input
  // Setting frequency scaling to 20%
  digitalWrite(S0,HIGH);
  digitalWrite(S1,LOW);
  // Begins serial communication
  // Setting RED (R) filtered photodiodes to be read
  digitalWrite(S2,LOW);
  digitalWrite(S3,LOW);
  redFrequency = pulseIn(sensorOut, LOW);
  // Remaping the value of the RED (R) frequency from 0 to 255
  // You must replace with your own values. Here's an example:
  // redColor = map(redFrequency, 70, 120, 255,0);
  redColor = map(redFrequency, XX, XX, 255,0);
  // Printing the RED (R) value
  Serial.print("R = ");
  Serial.print(redColor);
  delay(100);
  // Setting GREEN (G) filtered photodiodes to be read
  digitalWrite(S2,HIGH);
  digitalWrite(S3,HIGH);
  greenFrequency = pulseIn(sensorOut, LOW);
  // Remaping the value of the GREEN (G) frequency from 0 to 255
  // greenColor = map(greenFrequency, 100, 199, 255, 0);
  greenColor = map(greenFrequency, XX, XX, 255, 0);
  // Printing the GREEN (G) value
  Serial.print(" G = ");
  Serial.print(greenColor);
  delay(100);
  // Setting BLUE (B) filtered photodiodes to be read
  blueFrequency = pulseIn(sensorOut, LOW);
  // Remaping the value of the BLUE (B) frequency from 0 to 255
  // blueColor = map(blueFrequency, 38, 84, 255, 0);
  blueColor = map(blueFrequency, XX, XX, 255, 0);
  // Printing the BLUE (B) value
  Serial.print(" B = ");
  Serial.print(blueColor);
  delay(100);
  // Checks the current detected color and prints
  // a message in the serial monitor
  if(redColor > greenColor && redColor > blueColor){
      Serial.println(" - RED detected!");
  if(greenColor > redColor && greenColor > blueColor){
    Serial.println(" - GREEN detected!");
  if(blueColor > redColor && blueColor > greenColor){
    Serial.println(" - BLUE detected!");
I found that with my sensor:
Red 39, 226
Green 69, 286
Blue 27,97
Again, I would like to pretty much merge these. I like the ability to change the 0-255 so I can tweak teh code as needed for the colors I am sorting. I am trying to make this thing as basic as I can. I have a very basic drawing of what I am trying to do:
This is the stepper tutorial I would like to use as well:
Stepper tutorial
Thank you again for helping me. I am still a little new to this whole coding thing. I have only modified code for 3D printers.
Hello BRRRT. What are were correct outputs versus your output?
BBBRRRRTTT lol.
That is what was odd to me, the outputs were all over the place using the first code. I was seeing like 2000, 1600, 900 for green, 2000, 2000, 900 for Blue, etc. It was not really quantifiable. The ranges were pinging everywhere. Which is what led to me trying the second code. It was pretty repeatable and accurate.
I assume each color test was on (in) lantern vanta-black material so nothing reflects from another surface.
I wish. I held each piece at different distances and looked at the changes. The pieces are quire large and reflection was minimal on the flat black background.
I looked online at color sensors. Consumer-ready products seem to be cup-shaped and flush with the surface, like your TCS3200, but like the GY-33, have only one LED on the interior of the cup. Have you put the TCS3200 in a light-tight-ish cup? Maybe make the Legos travel through a "dark room."
I have not yet, but as I said before, the second code I posted gave me the correct outputs. The first one was too random. Is the second code not good?
If it works, it is good.
The color is displaying correctly, but my question is how to merge the 2 codes , then drive a stepper to move after the color is recorded?
Combine code. Would you describe how you see that?
Stepper. One of my favorite project references on youtube is DroneBotWorkshop. His examples are concise.
I like Rui Santos, codes, never had any problems with them, so can see that it would be reliable.
Have you tried;
Tom.. :smiley: :+1: :coffee: :australia:
I have done some more research and ill try to explain my idea a little more in depth.
Conveyer should run at a speed of X rpm constantly until the TCS3200 or an IR/ ultrasonic sensor detects a piece to be sorted. The conveyer will stop, color will be determined, then the piece moves further down the line, a servo will flip an arm to dump the piece into the corresponding bucket. Now for some issues I have that maybe you guys can help me sort out as well:
The parts vary in size as well as color. I can hand sort the larger pieces that wont sit on the conveyer correctly. Do I / should I make the conveyer have specific sections to set the pieces on (I.E. lines on the belt) so a sensor can start/ stop and have only X amount of pieces on the belt at a time?
I have attached another terrible MS paint pic and the links for the sensors I would think would work.
Beam Break sensor
Ultrasonic sensor
A flat belt might require a lot of placing and stabilizing. Would cups on the belt to hold the pieces work? When it is time to sort, they can still be flipped out of the cups.
This is a large version of what I was thinking:
Actually... THIS!! This is EXACTLY what I want to do.
