I want a help regarding colour sensor
I have made a colour sorting machine and when I put gems to know colour, It is giving blue as green and vice versa and also not detecting colour exactly please help me. I am providing my code below.
#include <Servo.h>
// ---- TCS3200 Pins ----
#define S0 2
#define S1 3
#define S2 4
#define S3 5
#define sensorOut 6
// ---- Servos ----
Servo topServo; // gate / feeder
Servo bottomServo; // sorter
int frequency = 0;
int color = 0;
// ---- Top servo angles ----
int TOP_CLOSED_ANGLE = 165;
int TOP_OPEN_ANGLE = 60;
int TOP_MID_ANGLE = 110; // mid pause angle, tune by trial
// ---- Bottom servo angles ----
int BOTTOM_CENTER_ANGLE = 90;
int BOTTOM_RED_ANGLE = 60;
int BOTTOM_GREEN_ANGLE = 100;
int BOTTOM_BLUE_ANGLE = 140;
// ----------------- Prototype centroids (from your samples) -----------------
const float BLUE_C[3] = {153.4, 117.6, 78.0};
const float GREEN_C[3] = {197.0, 115.0, 77.0};
const float RED_C[3] = {339.5, 197.0, 127.5};
const float WR = 1.4;
const float WG = 1.0;
const float WB = 1.0;
const float CONFIDENCE_FACTOR = 0.90;
// TCS3200 pins
pinMode(S0, OUTPUT);
pinMode(S1, OUTPUT);
pinMode(S2, OUTPUT);
pinMode(S3, OUTPUT);
pinMode(sensorOut, INPUT);
// Frequency scaling 20%
digitalWrite(S0, HIGH);
digitalWrite(S1, LOW);
topServo.attach(7); // top motor (dropper) on D7
bottomServo.attach(8); // bottom motor (sorter) on D8
topServo.write(TOP_CLOSED_ANGLE); // start closed
bottomServo.write(BOTTOM_CENTER_ANGLE); // sorter in center
Serial.println("3-color sorter ready.");
// ---------- STEP 1: Drop exactly one gem with MID PAUSE ----------
Serial.println("Dropping one gem...");
// Ensure start at closed angle
delay(200);
// Move from CLOSED -> MID slowly
for (int angle = TOP_CLOSED_ANGLE; angle >= TOP_MID_ANGLE; angle--) {
topServo.write(angle);
delay(20); // slower movement
// *** PAUSE at MID angle so gem stays over sensor ***
delay(4000); // increase/decrease for more/less pause
// Move from MID -> OPEN
for (int angle = TOP_MID_ANGLE; angle >= TOP_OPEN_ANGLE; angle--) {
delay(15); // slightly faster if you want
// Small pause while gem is just passing sensor
delay(200); // you can tune this too
// ---------- STEP 2: Read color ----------
Serial.println("Reading color...");
color = readColor();
delay(50);
// ---------- STEP 3: Close gate back (OPEN -> CLOSED via MID) ----------
// Move OPEN -> MID
for (int angle = TOP_OPEN_ANGLE; angle <= TOP_MID_ANGLE; angle++) {
delay(15);
// Optional small pause at MID while closing
delay(100);
// Move MID -> CLOSED
for (int angle = TOP_MID_ANGLE; angle <= TOP_CLOSED_ANGLE; angle++) {
delay(20);
delay(300); // let gem finish falling completely
// ---------- STEP 4: Move bottom servo based on color ----------
Serial.print("Detected color = ");
Serial.println(color);
switch (color) {
case 1: // RED
bottomServo.write(BOTTOM_RED_ANGLE);
case 2: // GREEN
bottomServo.write(BOTTOM_GREEN_ANGLE);
case 3: // BLUE
bottomServo.write(BOTTOM_BLUE_ANGLE);
default: // Unknown / unclear -> center or "reject" bin
delay(800); // time for gem to drop into box
// Return bottom servo to center
// ---------- STEP 5: Wait for next gem ----------
Serial.println("Cycle complete. Place next gem.");
delay(2000); // you place the next gem during this time
// ----------------- readColor() -----------------
int readColor() {
int R, G, B;
// ----- Read RED -----
digitalWrite(S2, LOW);
digitalWrite(S3, LOW);
frequency = pulseIn(sensorOut, LOW, 30000); // timeout 30ms
if (frequency == 0) frequency = 30000;
R = frequency;
delay(30);
// ----- Read GREEN -----
digitalWrite(S2, HIGH);
digitalWrite(S3, HIGH);
G = frequency;
delay(30);
// ----- Read BLUE -----
B = frequency;
delay(30);
Serial.print("Raw R=");
Serial.print(R);
Serial.print(" G=");
Serial.print(G);
Serial.print(" B=");
Serial.println(B);
int cls = classifyColor(R, G, B);
return cls;
// ----------------- classifyColor() -----------------
// returns: 1=RED, 2=GREEN, 3=BLUE, 0=UNKNOWN
int classifyColor(int R, int G, int B) {
// Quick explicit RED rules for very strong red reflections:
if ( (R > 350 && R > 1.5 * (float)G && R > 2.0 * (float)B) ||
(R > 240 && R > 1.25 * (float)G && R > 1.5 * (float)B) ) {
Serial.println("Rule matched: STRONG RED");
return 1;
// compute weighted squared distances to each prototype centroid
float dr = (R - RED_C[0]);
float dg = (G - RED_C[1]);
float db = (B - RED_C[2]);
float distR = WR * dr * dr + WG * dg * dg + WB * db * db;
dr = (R - GREEN_C[0]);
dg = (G - GREEN_C[1]);
db = (B - GREEN_C[2]);
float distG = WR * dr * dr + WG * dg * dg + WB * db * db;
dr = (R - BLUE_C[0]);
dg = (G - BLUE_C[1]);
db = (B - BLUE_C[2]);
float distB = WR * dr * dr + WG * dg * dg + WB * db * db;
Serial.print("Distances -> RED:");
Serial.print(distR);
Serial.print(" GREEN:");
Serial.print(distG);
Serial.print(" BLUE:");
Serial.println(distB);
// find min and second min
float best = distR;
int bestIdx = 1;
float second;
int secondIdx;
if (distG < best) { best = distG; bestIdx = 2; second = distR; secondIdx = 1; }
else { second = distG; secondIdx = 2; }
if (distB < best) {
second = best; secondIdx = bestIdx;
best = distB; bestIdx = 3;
} else if (distB < second) {
second = distB; secondIdx = 3;
Serial.print("Best match = ");
Serial.print(bestIdx);
Serial.print(" (dist=");
Serial.print(best);
Serial.print(") second=");
Serial.print(secondIdx);
Serial.print(second);
Serial.println(")");
// BLUE / GREEN handling + override
float sum = (float)R + (float)G + (float)B;
float rRatio = 0, gRatio = 0, bRatio = 0;
if (sum > 0) {
rRatio = (float)R / sum;
gRatio = (float)G / sum;
bRatio = (float)B / sum;
// If BLUE centroid wins and B is dominant -> keep it BLUE
if (bestIdx == 3 && bRatio > gRatio && bRatio > rRatio && bRatio > 0.36) {
Serial.println("Strong BLUE ratio -> keep BLUE (no override)");
if (best <= second * CONFIDENCE_FACTOR) {
Serial.println("Centroid decision = BLUE");
return 3;
// STRICT OVERRIDE: only very borderline BLUE→GREEN correction
int diffGB = abs(G - B);
float rel = (second > 0) ? best / second : 1.0;
if (bestIdx == 3 && // BLUE won
diffGB <= 5 && // G and B almost same
G > R && // G above R
rel > 0.85) { // distances close (not clear BLUE)
Serial.println("Override rule (strict): BLUE≈GREEN and G>R and close dists -> treat as GREEN");
return 2;
// Normal centroid decision with confidence
if (bestIdx == 1) {
Serial.println("Centroid decision = RED");
return 1;
} else if (bestIdx == 2) {
Serial.println("Centroid decision = GREEN");
return 2;
return 3;
// Fallback: ratio-based tie-breaker
if (sum <= 0.0) {
Serial.println("Fallback: sum==0 -> UNKNOWN");
return 0;
Serial.print("Fallback ratios -> r=");
Serial.print(rRatio, 3);
Serial.print(" g=");
Serial.print(gRatio, 3);
Serial.print(" b=");
Serial.println(bRatio, 3);
if (rRatio > gRatio && rRatio > bRatio && rRatio > 0.38) {
Serial.println("Fallback ratio => RED");
return 1;
if (gRatio > rRatio && gRatio > bRatio && gRatio > 0.28) {
Serial.println("Fallback ratio => GREEN");
return 2;
if (bRatio > rRatio && bRatio > gRatio && bRatio > 0.22) {
Serial.println("Fallback ratio => BLUE");
return 3;
Serial.println("Final decision = UNKNOWN");
return 0;
this is my machine but i have a problem in detecting exact colour please help me as tomorrow will be presentation of my project
Please edit your post to add code tags (<code> editor button). Describe what you expected to happen and what happened instead.
The light sensor reports the reflected/transmitted intensities of light in three bands, which depend very strongly on the illuminating light source as well as the background lighting. So the report is relative.
Human color vision is also relative, so "the exact color" is not a useful concept.
Who made all these comments in the code, and what is the purpose of all the arbitrary corrections to the raw data?
chatgpt gave this
I suggest to simply look at the raw sensor data that the program prints, while pointing it at various different colored objects under different lighting conditions, and use what you've learned from that experiment to decide for yourself how the data will help you to recognize a particular color.
Hi, @vidit019
Welcome to the forum.
Can you post a clear picture of the mechanical setup that you use to detect the colour?
Thanks... Tom.... :smiley: :+1: :coffee: :australia:
What is this:
G = frequency;
Supposed to do???
Usually this kind of code is used to measure distance (sonar based).
Also, there is no need for floats in your color arrays..
Please use meaningful names for your variables...
What is S0???
Why is the data of your centroid so close together? Hope you are not trying to distinguish kaki from beige or ocean green from petrol blue...
I am afraid you cannot fix this in 24 hours...
Best to start fresh (without chat gpt)
By the way, I like the idea behind the distance calculations!
The TCS3200 is a light to frequency sensor, with 3 color bands. The approach is similar to that used in this tutorial: Color Detection Using TCS3200/230 | Arduino Project Hub
However, it is probably best to toss out the chatGPT code and start over.
Take the color recognition sample from the library given by @anon94801460 .
Start from there...
