Lego Steering wheel.
I made a arduino and lego based steering wheel.
Pics: Sry quality, phone.
http://img408.imageshack.us/img408/4305/p29100823272jd7.jpg
http://img511.imageshack.us/img511/4593/p2910082327hw5.jpg
http://img185.imageshack.us/img185/755/p29100823271rx8.jpg
And a crappy 3GP vid i made:
DOWNLAOD IT, Better explaned idea
Sry my english, im spanish and im only 13 hehe
EDIT: I forgot, That thing over the arduino is my Shield
Colorful design :slight_smile: What do you do with it ?
p.s. please don't post such HUGE images. I couldn't see all of it on my screen, and I'm already at 1280x1024. I think 800x600 is a good choice, and you can always post closeups of fine details if need be.
Sorry, i changed the img tag by url.
Ok, i got a question. The unique thing that this do is sending a 17 to 168 DEC value to the com port. Does anyone how to create a vitual joystick with VB and use this to Steer?
I only use for learning some C and Electronics. But i want to use with rFactor or something else.
Src:
int ledPin = 13; //lol
int val = 0; //Potentiometer Value
int pv = 2; // 1 for program 1 and 2 for program 2 (omg obviously)
int larr[5]={123,11,8,10,12}; //123 not used, 11 is the first led pin, 12 is the last led pin. my pins are: 11-8-10-12
  pinMode(ledPin, OUTPUT);
  pinMode(6,  INPUT); //These are my shield's buttons
  pinMode(7,  INPUT); // idem
  pinMode(larr[1], OUTPUT); //Set the led pins for output
  pinMode(larr[2],  OUTPUT); // x4 idem
  pinMode(larr[3], OUTPUT);
  pinMode(larr[4], OUTPUT);
  Serial.begin(9600); //For sending the pot. value
    val = analogRead(2); //reads the pot.
    val = val / 4; //My pot is 0-1023. So i divided it for be 0-255 (255,7 really)
    if (pv == 1) { //Mode selection
     prog1();
    if (pv == 2) {
     prog2();
void prog1(){ //Reading line by line you will understand
     if (val >= 20)
     digitalWrite(larr[1], HIGH);
     digitalWrite(larr[2], LOW);
     digitalWrite(larr[3], LOW);
     digitalWrite(larr[4],LOW);
    if (val >= 52)
     digitalWrite(larr[1], LOW);
     digitalWrite(larr[2] , HIGH);
     digitalWrite(larr[4], LOW);
    if (val >= 93)
     digitalWrite(larr[3], HIGH);
    if (val >= 125)
     digitalWrite(larr[4], HIGH);
void prog2(){//Reading line by line you will understand
    if (val >= 92) {
      if(val <= 100) {
        digitalWrite(larr[2], HIGH);
    if (val <= 160){
    if (val <= 150){
    if (val <= 135){
    if (val <= 117){
    if (val <= 92){
    if (val <= 63){
    if (val <= 39){
   if (val <= 20) {
    Serial.println(val, DEC);
BTW if u want some pics of my shield, only say it, and i will post some pics. No schematics available.
Comments still being allowed .__.
This would be a slightly different approach you could consider:
UsbJoystick library for Arduino
--Phil.
if you're interested in using visual basic for serial port communication try this: http://www.control.com/1026198113/index_html
