Leonardo Servo Control
Hello, im building a Halloween prop using 3 micro servos to drive "eyes" & a "mouth". It is using a stacked setup with Keyestudio ks0248 & ks0258. I've installed both Arduino IDE & VSA. Ive downloaded all drivers & libraries. Using a 5v power supply, ks0248s green light is on, & ks0258s red light is on. Sending the "Hello World" code works fine and everything appears to be functioning correctly.
Anyway, just trying to test everything out and familiarize myself, but the servos don't move. Using the sample sweep, trying every servo option on VSA. You can see the boards lights indicating communication, but then the servos do nothing.
What am i missing? Does something need soldered on the servo shield, or is it plug and play? My laptop created the libraries folder in documents under Arduino and not in the program files Arduino IDE folder, is that normal?
Ive got a little servo tester, and they all function properly. Any help is appreciated.
I moved your topic to an appropriate forum category @ogta.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Please post schematics. Those pictures are of no help.
I copy and pasted the sample code from wiki & transferred from a laptop, the Leonardo lights indicate the transfer, but then nothing happens with the servos.
Please read and use this topic.
Did you check the logic voltage levels used in your system ?
I have not, can you elaborate, or share a link on how to do that? Ive got some elecronic & computer knowledge, but 100% new to Arduino, and assumed everything was plug n play. How do i check logic voltage levels? Thanks in advance
