Lesson 4 LED problem
I am trying to do lesson4 to light an LED I get errors when I try and upload the program given.
I've sent this to service@elegoo.com with no response. Thanks for any help.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x65
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x65
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x65
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x65
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x65
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x65
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x65
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x65
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x65
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x65
Reference, please
Go to your tools menu and be sure you have picked the correct board. It depends on the Arduino you are using but the Nano has several boot loaders and you may have to chose one.
This is what I am working on:
The Most Complete Starter Kit for MEGA V1.0.2021.05.13
Hello
Post the text of the lesson too.
Lesson 4 RGB LED
Overview
RGB LEDs are a fun and easy way to add some color to your projects. Since they are like 3 regular LEDs in one, how to use and connect them is not much different.
They come mostly in 2 versions: Common Anode or Common Cathode.
Common Anode uses 5V on the common pin, while Common Cathode connects to ground.
As with any LED, we need to connect some resistors inline (3 total) so we can limit the current being drawn.
In our sketch, we will start with the LED in the Red color state, then fade to Green, then fade to Blue and finally back to the Red color. By doing this we will cycle through most of the color that can be achieved.
Component Required:
(1) x Elegoo Mega 2560 R3
(1) x 830 Tie Points Breadboard
(4) x M-M wires (Male to Male jumper wires)
(1) x RGB LED
(3) x 220 ohm resistors 50 / 227
Component Introduction
RGB:
At first glance, RGB (Red, Green and Blue) LEDs look just like regular LEDs. However, inside the usual LED package, there are actually three LEDs, one red, one green and yes, one blue. By controlling the brightness of each of the individual LEDs you can mix pretty much any color you want.
We mix colors the same way you would mix paint on a palette - by adjusting the brightness of each of the three LEDs. The hard way to do this would be to use different value resistors (or variable resistors) as we did with in Lesson 2, but that's a lot of work! Fortunately for us, MEGA 2560 R3 board has an analog Write function that you can use with pins marked with a ~ to output a variable amount of power to the appropriate LEDs.
The RGB LED has four leads. There is one lead going to the positive connection of each of the single LEDs within the package and a single lead that is connected to all three negative sides of the LEDs. 51 / 227
Here on the photographs you can see 4 electrode LED. Every separate pin for Green or Blue or Red color is called Anode. You will always connect “+” to it. Cathode goes to “-“ (ground). If you connect it other way round the LED will not light.
The common negative connection of the LED package is the second pin from the flat side. It is also the longest of the four leads and will be connected to the ground.
Each LED inside the package requires its own 220Ω resistor to prevent too much current flowing through it. The three positive leads of the LEDs (one red, one green and one blue) are connected to MEGA 2560 output pins using these resistors. 52 / 227
COLOR:
The reason that you can mix any color you like by varying the quantities of red, green and blue light is that your eye has three types of light receptor in it (red, green and blue). Your eye and brain process the amounts of red, green and blue and convert it into a color of the spectrum.
In a way, by using the three LEDs, we are playing a trick on the eye. This same idea is used in TVs, where the LCD has red, green and blue color dots next to each other making up each pixel.
If we set the brightness of all three LEDs to be the same, then the overall color of the light will be white. If we turn off the blue LED, so that just the red and green LEDs are the same brightness, then the light will appear yellow.
We can control the brightness of each of the red, green and blue parts of the LED separately, making it possible to mix any color we like.
Black is not so much a color as an absence of light. Therefore, the closest we can come to black with our LED is to turn off all three colors. 53 / 227
Theory (PWM)
Pulse Width Modulation (PWM) is a technique for controlling power. We also use it here to control the brightness of each of the LEDs.
The diagram below shows the signal from one of the PWM pins on the MEGA 2560.
Roughly every 1/500 of a second, the PWM output will produce a pulse. The length of this pulse is controlled by the 'analog Write' function. So 'analog Write(0)' will not produce any pulse at all and 'analog Write(255)' will produce a pulse that lasts all the way until the next pulse is due, so that the output is actually on all the time.
If we specify a value in the analog Write that is somewhere in between 0 and 255, then we will produce a pulse. If the output pulse is only high for 5% of the time, then whatever we are driving will only receive 5% of full power.
If, however, the output is at 5V for 90% of the time, then the load will get 90% of the power delivered to it. We cannot see the LEDs turning on and off at that speed, so to us, it just looks like the brightness is changing. 54 / 227
Connection
Schematic 55 / 227
Wiring diagram
56/227
Code After wiring, please open the Sketch in folder path: Tutorial > English > code > Lesson 4 RGB LED > RGB_LED, and click UPLOAD to upload the program.
See Lesson 2 for details about program uploading if there are any errors.
The sketch starts by specifying which pins are going to be used for each of the colors:
// Define Pins
#define BLUE 3
#define GREEN 5
#define RED 6
The next step is to write the 'setup' function. As we have learnt in earlier lessons, the setup function runs just once after the Arduino has reset. In this case, all it has to do is define the three pins we are using as being outputs.
pinMode(RED, OUTPUT); pinMode(GREEN, OUTPUT); pinMode(BLUE, OUTPUT);
digitalWrite(RED, HIGH); digitalWrite(GREEN, LOW); digitalWrite(BLUE, LOW);
} 57 / 227
58 / 227
This function takes three arguments, one for the brightness of the red, green and blue LEDs. In each case the number will be in the range 0 to 255, where 0 means off and 255 means maximum brightness. The function then calls 'analogWrite' to set the brightness of each LED.
Try adding a few colors of your own to the sketch and watch the effect on your LED.
Example picture Before we take a look at the 'loop' function, let’s look at the last function in the
sketch.
The define variables
redValue = 255; // choose a value between 1 and 255 to change the color.
greenValue = 0;
blueValue = 0;
Hi @rcd127. In order to gather more information that might help us to troubleshoot your problem, I'm going to ask you to post the full output from the upload when in verbose mode.
Please do this:
  1. Select File > Preferences from the Arduino IDE's menus.
  2. Uncheck the checkbox next to Show verbose output during: [] compilation
  3. Check the checkbox next to Show verbose output during: [] upload.
  4. Click the OK button.
  5. Attempt an upload, as you did before.
  6. After the upload fails, you'll see a button on the right side of the orange bar in the Arduino IDE: Copy error messages. Click that button.
    This copies the full output to the clipboard.
  7. Open a forum reply here by clicking the Reply button.
  8. Click the </> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block
  9. Press Ctrl+V.
    This will paste the error output from the upload into the code block.
  10. Move the cursor outside of the code tags before you add any additional text to your reply.
  11. Click the Reply button to post the output.
Arduino: 1.8.12 (Windows 10), Board: "Arduino Uno"
Sketch uses 1422 bytes (4%) of program storage space. Maximum is 32256 bytes.
Global variables use 15 bytes (0%) of dynamic memory, leaving 2033 bytes for local variables. Maximum is 2048 bytes.
C:\Users\Rich Davidson\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\Rich Davidson\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\Rich Davidson\AppData\Local\Temp\arduino_build_749873/RGB_LED.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\Rich Davidson\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xcf
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xcf
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xcf
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xcf
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xcf
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xcf
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xcf
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xcf
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xcf
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xcf
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
type or paste code here
From the "MEGA" in that starter kit name, I would guess that the kit contains a clone or derivative of the Arduino Mega board (ATmega2560 microcontroller-based).
Is that the board you are using?
I am using a EELEGOO MEGA2560 R3
OK, so the problem is that you have selected the wrong board from the Tools > Board menu in the Arduino IDE:
Select Tools > Board > Arduino AVR Board > Arduino Mega or Mega 2560 and then try uploading your sketch again.
This fixed it it was set to the wrong board.
