Librarie Locations
I moved my sketches from a windows 7 computer to a Windows 10 computer and now I get "No such file or directory" can't find the library directory. The libraries are in the Windows 10 computer. Where exactly should the libraries be?
The libraries that you installed should be in folders in the libraries folder of the sketchbook folder. You can see where the sketchbook folder is by looking in File/Preferences in the IDE
That it not its name
Look in File/Preferences
Open the Arduino IDE
Click on File in the menu
Click on Preferences
I found it. Looking in the wrong places.
Solved the problem. I changed the library name from Upper case to lower case and it found it. I didn't know it was case-sensitive.
Thank you for your help.
I am glad you found it
Are you using Windows, Mac or Linux ?
Windows
I think the default location for libraries may have been altered from early versions , or you might not have set it when upgrading - I’ve ended up with libraries in two places because of this !
