The MCP4725 is excellent replacement for digital resistors MCP413x / 415x / 423x / 425x. Ideal for creating digital controls for analog power supplies.
Supports all sensor features:
Quick recording. Only 16-bit is written directly into the chip, bypassing all registers, nothing is saved in the eeprom.
Write to the register. The 24-bit is written to the register, nothing is saved in the eeprom.
Eeprom record with checking the busy flag. The 24-bit is written in the register and in eeprom.
Three types of sleep. With pull-down to the ground using the built-in resistors: 1KΩ, 100KΩ and 500KΩ.
Read current and saved voltage and sleep type.
General reset. All devices on the i2c bus supporting General Call will be reset.
General waking up. All devices on the i2c bus supporting General Call will wake up.
The DAC is slow, generates 16Hz 9-bit sine wave on 16MHz Arduino Nano - not good for audio application.
Link - github.
